Forum » Programska oprema » Haimachi
Haimachi
slovis ::
HAIMCAHI Tezave
Pri zagonu Haimachija naletim na sledeče težave:
vse deluje normalno dokler ne zacne program nastavlati "setting up.."
potem javi sledeco napako:
configuration problem is most likely caused by your firewalling software blocking DHCP traffic on Hamachi adapter.Please make sure that UDP traffic from local port 68 to port 67 at 5.0.0.1 is allowed.Alternatively you can try completly disabling the firewall on hamachi adapter.
firewall v windowsih sem sklopil in se vdno nic.
Ce ima kdo kaksno idejo kako to odpraviti naj prosim napise!
Lp slovis
Lp slovis
| » | Vprašanje o povezavi preko Hamachi-jaOddelek: Pomoč in nasveti | 1586 (1007) | ScottDJ_ |
| » | Windows network share preko interneta?Oddelek: Omrežja in internet | 3202 (2900) | Mr.B |
| » | Tekkit server errorOddelek: Pomoč in nasveti | 1293 (1129) | andrej02 |
| » | hamachiOddelek: Igre | 6905 (3971) | ziga14 |
| » | Oddaljeni restart in logonOddelek: Pomoč in nasveti | 1884 (1648) | Tr0n |
