Haimachi
Haimachi
slovis ::
HAIMCAHI Tezave
Pri zagonu Haimachija naletim na sledeče težave:
vse deluje normalno dokler ne zacne program nastavlati "setting up.."
potem javi sledeco napako:
configuration problem is most likely caused by your firewalling software blocking DHCP traffic on Hamachi adapter.Please make sure that UDP traffic from local port 68 to port 67 at 5.0.0.1 is allowed.Alternatively you can try completly disabling the firewall on hamachi adapter.
firewall v windowsih sem sklopil in se vdno nic.
Ce ima kdo kaksno idejo kako to odpraviti naj prosim napise!
Lp slovis
Vprašanje o povezavi preko Hamachi-ja
71586 (1007) ScottDJ_
Windows network share preko interneta?
Oddelek: Omrežja in internet
203202 (2900) Mr.B
Tekkit server error
121293 (1129) andrej02
hamachi
Oddelek: Igre
236905 (3971) ziga14
Oddaljeni restart in logon
131884 (1648) Tr0n
