Forum » Kaj kupiti » Nakup namiznega PC-ja
gddr85 ::
če bo delu na indesign, illustrator potem je dovolj tud gtx550 1gb, če pa kej drugega npr. 3d itd potem pa r9270x ne bi bla slaba
GenZNPC ::
750 pa i5 je že druga pesem. Naj nekdo nardi sestavo, men se neda :D
sicer pa:
sicer pa:
Q:
I guess I misunderstood what I read (or the people that wrote it were mistaken). They were saying that OpenCL was better and faster than CUDA. I also read that OpenCL is able to use the GPU and CPU at the same time.
A:
Well yes, it can. However, the performance gain is not really worth the feature loss - Cycles' OpenCL kernel is a bit of a stub, missing most of the more advanced features because there just hasn't been a lead platform where OpenCL is preferable to all other solutions - the CPUs have their own dedicated C++ implementation, and Nvidia GPUs have CUDA.
AMD GPUs which should be the lead platform for OpenCL just don't work at the moment because the AMD OpenCL compiler has been optimized for much smaller kernels to the point where it just can't cope with something as big as Cycles (it tries to inline just about everything to get rid of function calls, but since Cycles is so big, it runs out of RAM before it can complete the task). If you pick up one of the older builds (around 2.61 or 2.62 i think) and have a lot of of RAM (not sure, either 24 or 32GB )you just might get it to render something after waiting a long time for the compiler to finish.
skibidi
klkkkkkkkkkk ::
iloveboobz je izjavil:
z 750 gre potem tudi i5..
Ubistvu je FX 8320 bolj future profe ... vendar jaz nebi kupil GTX 750.
PS: Kakor sem prej govoril glede xeon-na in i5 mislim enako za FX 83*** vs i5.
GA-990XA-UD3, FX 6300 4.6GHz, R9 270X, 8Gb Ram, 1TB, G-550W, Win7
- spremenilo: klkkkkkkkkkk ()
wade ::
Se pravi če se ne dela v 3D zamenjam R9 270X in bo verjetno še tale preveč?:
Grafična kartica ZOTAC GeForce GTX 750Ti 2GB DDR5
razlika med procesorjema AMD FX-6300 in AMD FX-8320 3,5 GHz BOX AM3+ upraviči višjo ceno?
A je tema o prenosnikih tud tolk aktivna, al bolš da tuki vprašam kaj je najboljšega do 400€, mogoče pri funtechu, da se vse skupaj kupi?
- spremenil: wade ()
klkkkkkkkkkk ::
GTX 750Ti nemoreš primerjati z R9 270 ker je pač R9 270 v drugem rangu. kakor koli gledaš je GTX 750Ti boljša samo v P/W (kar se tiče gaminga)... Nop če gledaš celotno porabo PC-ja ima z i5 ima celo R9 270 boljši P/W.
trnvpeti ::
klkkkkkkkkkk je izjavil:
govora je graficnem oblikovanju, in se to ne 3d
klkkkkkkkkkk ::
jap sem opazil :( Zdej, če boš samo oblikoval je GTX 750 dovolj.... Zdej, če bo pa še gaming pa vzameš neki boljšega.
dottor ::
Malo mnenja za tole. Ko odplačam fotoaparat mam namen končno it zase v nakupe. Odmislu sem začasno AMD konfiguracijo in LGA2011-3 in bi uzel naslednje:
NTEL Core i7 4790K
ASUS MAXIMUS VII RANGER
G.Skill Ares F3-1600C9D-16GAR 16GB (2x8GB) PC12800 DDR3
SAMSUNG 840 EVO series 250GB 25/S600
in 2x R9 280X iz bolhe (verjetno sapphire).
Obdržal bi Armor+ ohišje, Antec 750 New, 500GB diska, DVD enoto. Kar se tiče hlajenja samega procesorja bi kasneje uzel kak H80 al kej podobnega z single 120 radiatorjem.
NTEL Core i7 4790K
za tak denar raje xeona..
pa seveda mx100 256GB ssd
- spremenil: iloveboobz ()
dottor ::
Pač 4790K pri singlecore aplikacijah in igrah zna pri 4GHz oz 4.4GHz Turbo bit kar pošast...
hja, sam je xeon 1230V3 overall večja pošat, ker imaš 8 niti :)
pa še razliko v cenejši plati lahko vložiš kam drugam :)
je za razmislat, ker so tile xeončki precej poceni.
matic492 ::
@hojnik, si spregledal, saj je napisal da bi vzel I7 :D
ah pa res, moja slaba...
no z xeonom bi pa prišparal ~100€ :)
pa haswell refresh i7ka pride šele konc junja ven :)
dottor ::
Itak imam za zbrat 1300€ za izplačat fotoaparat in neki opreme in pol pride na vrsto to. Se pravi okoli avgusta-septembra. Okoli 800€ je CPU+MB+RAM+SDD, grafične pa okoli 350€ kar znese skupaj ~1300€ skupaj z H80i. se pravi 2 plači bo treba dat na stran za tole
lahko daš precej manj, če vzameš manj gimicky plato (resno asus?!), xeonča, 8GB rama, crucialov ssd...
kasnej še pa vedno lahko pokneš noter broadwella in +8GB, če bi blo premal..
Intel Xeon E3-1230v3 Bx, LGA1150
Gigabyte GA-Z97X-Gaming 3, Sockel 1150, ATX
8 GB Kingston 1600MHz DDR3 CL10 DIMM HyperX black Series
Corsair Hydro Series H80i
Crucial MX100 SSD 256GB (2,5", 7mm)
567,32 EUR hardwareversend.de
evo še grafa iz bolhe http://www.bolha.com/racunalnistvo/graf...
pa maš komp za eno plačo že :)
Kasneje pa dodaš še eno 280x in +8GB rama če je potreba... Zakaj bi dal 1300EUR, če ni treba..
dottor ::
Jaz kupujem računalnike za obdobje 5-8 let, zato dam že v štartu malo več denarja in imam dlje časa mir in ni treba nič dograjevat.
gddr85 ::
sej tud tale Gigabyte GA-Z97X-Gaming 3 ni dost manj gimicky, edin to je da so ji namest pci x1 stlačil notr en pci slot.
je pa kr cenej :)
hja no, karkoli kupiš sedaj, nebo za 8 let :)
zato pač nabaviš nekaj vmes, ko bo za 3-4 leta in potem menjaš (čeprav xeon bo za precej dalj časa kot 4 leta). Itk prihaja DX12, kar pomen, da bojo trenutne grafe slej ko prej za v smeti (tako kot so sedaj dx10).
gddr85 ::
je pa kr cenej :)
zato pač nabaviš nekaj vmes, ko bo za 3-4 leta in potem menjaš. Itk prihaja DX12, kar pomen, da bojo trenutne grafe slej ko prej za v smeti (tako kot so sedaj dx10).
ne ga strašit...
pač to je realnost za naslednjih 8 let. Zato je pač neumno sestavljat za tak rok.
wade ::
lc600 z ohisjem
asrock h81-dgs
i5 4440
8g rama
brez graficne, hd4600 je dovolj
m500 120G
1T wd blue
funtech skupaj 437eur
Je i5 hitrejši procesor? Potem če je že hd4600 dovolj, je to verjetno cenejša varianta in brez iger ter 3d grafike nič ne izgubim v primerjavi s:
Matična plošča GIGABYTE GA-970A-DS3P, DDR3, SATA3, USB3, AM3/AM3+ ATX
2. Trdi disk WD 1TB 7200RPM 64MB 6GB/S BLUE WD10EZEX
3. Ohišje Antec VSK4000E ATX Mid-Tower
4. SSD disk CRUCIAL M500 120GB 2.5" SATA3 MLC 7mm
5. Pomnilnik Crucial DDR3 4GB 1600MHz CL11 SR CT51264BA160BJ x2
6. Napajalnik XFX Core Edition PRO V2 450 Watt
7. Procesor AMD FX-6300 3,5 GHz BOX AM3+
8. ZOTAC GeForce GTX 750Ti 2GB DDR5
Za i5 potem asrock matično, rame pa te crucial 4GB 2x, ostalo je pa isto..
Aja, se splača dat kaj več denarja za ohišje, če ceniš tišino? Če, katero?
dottor ::
Verjetno bom šel kar v nakup builda ki sem ga prej napisal. Lahko je neumnost kupovat na tako dolgi rok ampak nimaš kej...
5 let ti bo kamot zdržak xeonček + še ena 280X..
sj razn frekvence razlike med xeonom pa i7 tak ni..
FlyingBee ::
čez 5 let bo 280x stara 8 let, tako da pravzaprav mu sestavljaš za 8 let, sam da ni 280x ravnokar izšla
Watain ::
Pozdravljeni še enkrat!
Hojnikb in ostali: Prosim argumentirajte če je zdaj kaj boljše..
Intel Xeon E3-1230 V3 3,3 GHz (Haswell) S1150 - BOX
MSI Z97 Gaming 5, Intel Z97 Mainboard - S1150 7917-001R
Pomnilnik Kingston HyperX Beast 16GB 2400MHz DDR3 KHX24C11T3K2/16X
Trdi disk Seagate Barracuda 3TB SATA3 6GB/s 7200 64MB 3,5" ST3000DM001
SSD disk CRUCIAL MX100 256GB 2.5" SATA3 MLC 7mm, CT256MX100SSD1
LG GH24NSB0 DVD-RW zapisovalnik, SATA, črn
Napajalnik XFX TS-Series 650 Single Rail, 80Plus Gold - 650W P1-650G-TS3X
ASUS GeForce GTX 780 DC2OC, 3072 MB DDR5, DP, HDMI, DVI 90YV04H0-M0NA00
Tole gračino sem dal zraven ker je gtx780 in kolko sem uspel prebrat po forumih je gtx bolj
zanesljiv od r9 290x...izkušnje/mnenja/razmišljanja, go!
Ohišje pa ne znam pametno in poveni najti,plus kakšna hlajenja za grafično procesor?! Pomoč prosim...
Cena mi je pa padla na 1340 + ohišje...se pravi je že zdaj 200€ manj...
FlyingBee ::
če nisem kaj spregledal imaš to PC za igre, torej bo 8gb rama dovolj, potem ohišje in napajalnik pa malo po review straneh preberi, npr.:
ohišje: http://www.techpowerup.com/reviews/?cat...
CPU hladilnik: http://www.techpowerup.com/reviews/?cat...
nebi pa škodilo, da si še napajalnike pregledaš: http://www.techpowerup.com/reviews/?cat... , dost sigurna odločitev je XFX 650W, čeprav bo 550 dovolj, ima 650 daljše kable kar poveča možnost izbire ohišij in še ni najboljše, da je napajalnik preobremenjen
- spremenil: FlyingBee ()
Watain ::
Je res 8GB rama dovolj? recimo gledal sem tale review :
http://www.game-debate.com/games/index....
In je 8GB rama ocenjo recimo 9...
Hojnikb: Kaj pa je razlika v plati? zakaj h97? je boljša? al kak?
Pa rad bi videl da ma dovolj razširitve(da bi lahko ostala za nekaj časa tudi če bom komponente menjal/dodajal(rami recimo)
Stojansto: Za igre ja,prav si videl.
Hvala za linke, bom malo povohal...Če maš pa osebno kakšne favorite pa prosim, z besedo na dan.
FlyingBee ::
ja, vsekakor 8gb dovolj, ravno ram je najlažje nadgradit v prihodnje
"z" oznaka pred 97 pomeni, da je za navijalske procesorje s "k" pripono, ker pa si na xeon-u pristal, "z" ne rabiš in bo "h" več kot v redu, pazi da ne bo mATX ali celo manjša, ker potem je PCIE reža preblizu CPU socketa, torej mora biti ATX format
glede ohišji lahko v tej temi prebereš razno razna prepiranja kaj je že dovolj dobro ali pa da za ohišje čim manj denarja, pa raje v komponente več, vendar predvsem bodi pazljiv na naslednje podatke:
- max. višina CPU hladilnika, ki ga ohišje še sprejme
- max. dolžina grafične
- cable management - zelo dobrodošlo je, da se da lepo kable za matično speljat, še posebej kabel 8-pin, ki je na modernih ploščah levo zgoraj nad CPU socketom, napajalniki pa v modernih ohišjih levo spodaj s kabli na sredini ohišja, torej če gre kabel spredaj gor, gre ravno po diagonali čez CPU hladilnik, če je kabel do 55cm dolg
- koliko ventilatorjev vsebuje in kakšna kvaliteta je le-teh, recimo 4 ventilatorji so super na prvi pogled, vendar ni rečeno da bo to najboljša rešitev, kar se tiče glasnosti in tvoje izkušnje s tem PC-jem, če ga nimaš daleč od ušes pod mizo
Razdalje je na mATX in ATX enaka, namreč ATX ohišja sprejemajo mATX plate, razdalje pa je določena že z ohišjem, ker mora ven gledati. Je čisto vseeeno, če se mATX kupuje.
Za dolžino grafe so pa najbolj ziher towerji, pri čemu manjšemu pa je res treba preverit maksimalno dolžino v specifikacijah, mislim da bi morale bolj ali manj vse grafe iti tudi v midi in podobno tip ohišij.
- spremenil: Lonsarg ()
FlyingBee ::
mislim le na razdaljo med CPU socketom in prvo (najhitrejšo) PCIE režo za grafično in sicer v povezavi s CPU hladilnikom, ki se zna v primeru 140mm ventilatorja, že stikat z grafično kartico (bad idea)
Watain ::
No zdaj zgleda vse skupaj nekako takole:
-Intel Xeon E3-1230 V3 3,3 GHz (Haswell) S1150 - BOX
-MSI H97 Gaming 3, Intel H97 Mainboard - S1150 7918-002R
-KINGSTON HyperX Beast 8GB (2x4GB) DDR3 2400 CL11; XMP KHX24C11T3K2/8X
-Trdi disk Seagate Barracuda 3TB SATA3 6GB/s 7200 64MB 3,5" ST3000DM001
-SSD disk CRUCIAL MX100 256GB 2.5" SATA3 MLC 7mm, CT256MX100SSD1
-LG GH24NSB0 DVD-RW zapisovalnik, SATA, črn
-Napajalnik XFX TS-Series 550 Single Rail, 80Plus Gold - 550W P1-550G-TS3X
-ASUS GeForce GTX 780 DC2OC, 3072 MB DDR5, DP, HDMI, DVI 90YV04H0-M0NA00 (Glede grafične kartice sem še
vedno skeptičen...prosim za pomoč ; gledamo razmerje cena/zmogljivost/kvaliteta.
Pri ohišjih sem še vedno v iskanju...trenunto gledam neke midi-towerje : primeri ;
-Aerocool V3X Advance Evil Black Edition Midi-Tower - črna/oranžna EN57394
-Zalman Z3-Plus Midi-Tower Črn ali bel...
-Gigabyte GZ-G3 Plus USB3 ATX ohišje, črno
FlyingBee ::
v kateri trgovini si to sestavil?
če se ohišju ne misliš posvečati potem kar Zalman Z3 Plus
če 650 ali 750 W ni precej dražje od 550 potem raje zmogljivejšega, napajalniki se najlepše počutijo kadar so med 40 in 70% obremenjeni
grafična bi bila sapphire 290 trix enako zmogljiva (izmenjujeta si vodstvo v različnih igrah), vendar cenejša in ni rečeno, da boš sploh imel kakšno težavo z njo, verjetno nobene kot tudi z driverji ne
nerabiš tak dragih ramov; že najcenejši 1600MT bodo vrh glave (itk uradno več kot 1600mt ni podrto)
Watain ::
Sestavljam v Funtech-ovem konfiguratorju :) Koliko sem bral po forumu sem slišal do so vredu glede na konkurenco.
-Napajalnik XFX XXX Edition Pro 80Plus Bronze 850Watt
-Sapphire Radeon R9 290 Vapor-X Tri-X OC, 4096 MB DDR5, DP, HDMI 11227-04-40G (Tale je dobra??)
Kako to misliš ne posvečat ohišju? Rad bi videl da ni preveč drag, pa da ma ventilatorji ki bi vse skupaj lepo
hladil, pa da so kvalitetni kot si prej omenjal...Pa da nekak zgleda,hehe
Hojnikb: Pa vidim da se tile kingstonovi HyperX Beasti hvalijo :o pa mislil sem da je 2400MHz pač vredu...?! confused
Bergyb ::
Ste se že kaj menl glede RAMa, razen velikosti?
DDR3 test v cinebench:
1333 CAS 9: 77.89
1600 CAS 9: 78.03
1600 CAS 8: 80.73
1866 CAS 9: 81.42
2400 CAS 11: 79.61
Ni neke grozne razlike razen v ceni. To seveda omenjam, da ne bi npr. deval 40€ več za hitrejši RAM, ki ni nujno hitrejši. Glede na to, da je procesor Intel, pa je priporočljivo, da ima XMP za optimalno delovanje.
8GB RAMa bo dovolj še kar nekaj časa za igre, trenutno ga velika večina še 3GB ne izkorišča (windows zaseda okoli 1.2GB).
1333 CAS 9: 77.89
1600 CAS 9: 78.03
1600 CAS 8: 80.73
1866 CAS 9: 81.42
2400 CAS 11: 79.61
FlyingBee ::
tale asus 290 v funtechu je precej cenejša od vapor-x pa še BG4 zraven dobiš http://funtech.si/si/vsi-oddelki/komp/g...
kar daj tega za 38 EUR Zalman Z3 plus http://funtech.si/si/vsi-oddelki/komp/o...
napajalnik potem XFX 650W TS gold http://funtech.si/si/vsi-oddelki/komp/n...
ram Crucial Tactical ali Sport 1600 recimo, 2x 4gb
vsekakor pa se pri sestavi celega PC-ja potem iz DE res splača, ko pridemo do končne konfiguracije v funtechu pa lahko še preko idealo na hardwareversand sestavimo isto pa primerjamo
Bergyb ::
Grafična je dobra, jaz bi raje pogledal na bolho za eno rabljeno "SAPPHIRE R9 290 TRI-X 4GB GDDR5 OC", katero bi moral dobiti za 350/370€, ker jih minerji prodajajo.
Takšna grafična bo imela še vsaj leto in pol garancije, uporabljena pa je bila 2-3 mesece, dokler ni prodajalec ugotovil, da rudarjenje ni zanj.
Watain ::
Kaj je pa potem boljše od tega recimo!?:
-RAM DDR3 8GB PC3-14900 1866MHz CL9 Crucial BX Tactical BLT8G3D1869DT1TX0CEU
-RAM Crucial BX Sport DDR3 8GB Kit (2x4) 1600MHz CL9 BLS2CP4G3D1609DS1S00CEU
-RAM Crucial BX Sport XT DDR3 8GB 1866MHz C10 BLS8G3D18ADS3CEU
Vprašanje glede napajalnika: A ni boljše tisti 850W ki sem ga linkal od tega 650W ? samo vprašam seveda..
kak je pa z tole grafično :
MSI Radeon R9 290X Gaming 4G, 4096 MB DDR5, DP, HDMI, DVI V308-001R (tale je 290X ...?)
-RAM Crucial BX Sport DDR3 8GB Kit (2x4) 1600MHz CL9 BLS2CP4G3D1609DS1S00CEU te vzam
650W maš vrh glave..
FlyingBee ::
pri ramih lahko kar tako izbereš mora biti DDR3, 1600mhz, cl9, 1,5V, znamka in kakšen hladilnik ima pa se sam odloči, visoki hladilniki znajo bit problem za non-stock ali non-water CPU coolerje
850W je več od 650W in, če se gre za isto znamko in 80+ eff. potem je vsekakor 850W boljši - TS in starejša izvedenka XFX je oboje od Seasonic in to je kvaliteta
grafična je zopet kakor se odločiš, 290x je hitrejša od 780 in 290, MSI, ASUS, Sapphire so vse dobre znamke in imajo dobro hlajenje
