Forum » Kaj kupiti » Nakup namiznega PC-ja
GenZNPC ::
Na hoh.de deset evrov manj 856EUR z
-malenkost boljši ram (CL9),
-grafična Ti,
-matična z C2,
-ohišje dva ventilatorja + regulator
Plus še to kaj bodo ostali svetovali.
-grafična Ti,
-matična z C2,
skibidi
- spremenil: GenZNPC ()
birtija ::
Rabim par predlogov za:
-fizično majhen računalnik
-sposoben predvajat 1080p
-tih
-samo internet in pisarna
-brez grafične posebej
-cenovno ugoden
Hvala!
-tih
-cenovno ugoden
Hvala!
Hayabusa ::
Zakaj tako močen procesor, za tako grafično? Ali boš delal tudi kaj drugega, kot igral igre?
Autodesk inventor
Streljaš po komarjih z S-400 raketnim sistemom namesto s časopisom.
Več kot 2 jedri ne vem če podpira kateri 3d program (npr pro/e jih podpira, catia pri renderiranju).
http://usa.autodesk.com/adsk/servlet/ps...
Due to the lack of multi-threading, Inventor is not capable of using more than 50% of the CPU on a dual-core computer, so there is no significant performance gain over a single CPU computer.
The only way to take advantage of a dual-core processor when using Inventor is to run multiple Inventor sessions on your computer.
Raje izberi i3/5 ali celo intel pentium procesor, razlike bodo minimalne.
-tih
-cenovno ugoden
Hvala!
Daj max. ceno.
- spremenilo: Hayabusa ()
GenZNPC ::
To je res, ampak verjetno nebo imel samo inventorja odprtega naenkrat.
Sicer pa:
Sicer pa:
If your doing just AutoCAD than an i5 (or even a fast i3) will do everything you need; if your like me and have a couple drawings open, a database, and a few pdf's, email etc than you would be better off with an i7 I think your right in that CAD is "limited" in how it multi-threads.
the i7 was faster and drafting was smoother than the i3, but the overall system load was nearly the same while drafting and price/performance ratio really favors the i3 (at the time of my testing). Also to really take advantage of the i7 I would need an SSD, as my WD Raptor was bringing down overall system performance.
skibidi
vaščan ::
12DINT21894 INTEL Pentium G2120 3.1GHz 3MB BOX LGA1155 51,15 EUR 5% 22% 62,40 EUR odstrani
11OINT1480 INTEL DQ77KB 124,19 EUR 5% 22% 151,51 EUR odstrani
14MJCO0922 CORSAIR CMV4GX3M1A1333C9 4GB PC10600 DDR3 26,35 EUR 5% 22% 32,15 EUR odstrani
10DLIAN0200 Lian Li PC-Q05B črn 54,91 EUR 5% 22% 66,99 EUR odstrani
2,5" SSHD Seagate Desktop SSHD 1 TB, 64 MB, SATAIII (ST1000DX001) Spletna cena:90,47 EUR
skupaj- 400eur pa še en kabel za napajanje rabiš kot za laptopa to se ga da tud zastonj staknit ali pa za male denarce.
- spremenilo: vaščan ()
u serious ?
pentium sistem za 400€ ?
malo debelejši sistem se dobi za dosti manj... še vedno itx
Hayabusa ::
Kaj takega mogoče ?
Sestavljen minipc:
http://www.hoh.de/detail/index/sArticle...
Sestavljen minipc:
iloveboobz je izjavil:
-tih
-cenovno ugoden
Hvala!
kej na 1150 + miniitx bi blo kr ok.
APU mu ponudi.
Hayabusa ::
Amd
brez rama in diska !
birtija ::
Amd
Zadnji + Ram + disk bi bilo zanimivo. A je tole možno dobit v SLO?
Kateri Ram bi šel zraven?
E450 -- nope nope... razn če bi blo izkjučno za gledanje filmov. ampak za to obstajajo namenske naprave, ki so cenejše. Ram predvidevam da je sodimm...
Hayabusa ::
http://www.sapphiretech.com/presentatio...
Memory 4 GB DDR3 So-DIMM
Storage 320 GB SATA 2.5'' Hard Driver
birtija ::
A si mislil tole?
http://www.hoh.de/pc-systeme/nach-einsa...
In zakaj ne AMD E-450?
Filmi so bolj postranska zadeva. Predvsem internet in pisarna, kak Youtube na najboljši ločljivosti.
Cena pa največ do 250 na moj dom.
Sem videl, da je tole zgleda starejši model, brez USB 3.0 in wireless n.
- spremenil: birtija ()
birtija ::
Sem vmes pogledal film, pa ima USB3.0 in n wireless. Moja napaka.
A si mislil tole?
birtija ::
močno odsvetujem e-450, ker je to sila podhranjena zadeva.
250€ je max budget ?
250 max, ker bi bilo interneta 80% in 20% pisarne (word in exel), drugega pa skoraj nič.
če te ne moti malo večja škatla (mATX), lahko vzameš kamot tole:
sn pa dau noter ssd namesto hddja, ker bo stvar tišja + office računalnik več kot 60GB pomoje niti ne rab.
lahko pa še kak EUR prhraneš tako, da vzameš tole (stara platforma + hdd)
čeprav osebno ti svetujem prvi konfig, razn če te moti odsotnost placa
1. Procesor Intel Pentium G3220 BOX, Haswell
2. Ohišje LC 1410mi Mini ITX / Micro ATX 200W
3. Matična plošča GIGABYTE GA-B85M-HD3, DDR3, SATA3, USB3, HDMI, LGA1150 mATX
4. Pomnilnik Kingston DDR3 4GB PC1600 (KVR16N11S8/4)
5. SSD disk Kingston SSDNow V300 Series 2,5 SATA 6G - 60 GB SV300S37A/60G
251,69 EUR funtech.si
1. Ohišje LC 1410mi Mini ITX / Micro ATX 200W
2. Pomnilnik Kingston DDR3 4GB PC1600 (KVR16N11S8/4)
3. Matična plošča ASRock B75M-GL R2.0 LGA1155 ATX
4. Intel Pentium G2020 BOX procesor
5. Trdi disk WD 500GB SATA 6GBs 7200 16MB (WD5000AAKX)
226,57 EUR funtech
- spremenil: iloveboobz ()
Hayabusa ::
za 200E:
https://slo-tech.com/forum/t579063/p414...
Diske prodaja theGamer https://slo-tech.com/profili/98374
kateri del stavka, da more bit kišta majhna ti ne razumeš ?
vzami enga izmed mojih buildov (najbolš kr prvega) in boš presenečen, kak je lahk zadeva snappy. pa tist lcpower ohišje tut ni tako veliko
trnvpeti ::
http://www.mimovrste.com/artikel/274019...
pa 4G rama notri 35e, pa hybrid/ssd 70e, pa si na 250
... in dobiš pol manj zmogljiv procesor in nobene možnosti za nadgradnje (v moj build lahko vržeš ssd + hdd, boljši procesor, navadn dvd pekač, lowprofile grafo..) na račun manjše škatle... hmmm
trnvpeti ::
za pisarno ne bos obcutil nobene razlike v zmogljivosti cpu
nadgradnje v tem primeru ne bos rabil
in kaj če potrebuje dvd pogon ?
2x bolši cpu za isto ceno ? kdo za vraga nebi tega vzel...
pa tut glasnost tele zadevce je vprašljiva, ker ma gotovo laptop hlajenje...
tak da razn, če OP absolutno rab tiny tiny build, z mojim nima kej sfalit.
trnvpeti ::
hlajenje ni problem pri 25x25x5cm
matx je standard, ohisje naredit pa tudi ni problem
1007u bi lahko hladil z 5cm visokim pasivnim hladilnikom
trnvpeti ::
http://funtech.si/si/vsi-oddelki/komp/o...
recimo miniitx ohisje, 220x200x60
in ni problem hladit niti i5/i7
samo malo vecjo, da notri gre matx
mogoce se maticna matx z mSata
potem se pa bunijo, zakaj ne prodajajo pcjev
klkkkkkkkkkk ::
pač takih zadev ni, kaj čmo...
za take zadeve maš telefon :) tablice itd.
Za kj več imaš prenosnike, ki so nžalost glasni oz. glsnejši proti namiznemu računalniku...
ne vzemt kište, ki so zaprte razn, če jo boš na pol leta lepo odpru in spucal
http://www.dinokomp.at/produkt/chieftec...
- spremenilo: klkkkkkkkkkk ()
In kako to veš?
GenZNPC ::
Se strinjam. Jaz nisem mogel ne na asrock ionu in ne na eeeju z dvojedrnim atomom na 2ghz normalno usposobit predvajanje 1080p posnetka na win7 v firefoxu na youtubu. Pravtako ni bil sposoben predvajati nekatere 1080p filme tekoče...
skibidi
pa že sama uporaba takiga sistema je netekoča, da o kakem browsanju po flash straneh ne govorim....
stay away... za podobn denar dobiš pentium sistem, ki pohrusta te amdje z levo jajco..
GenZNPC ::
Jaz sem takrat lepo nasedel reklami, da na tej mašinci bo pa skor vse delalo za multimedijo. Od takrat več no go... Res pa je da sem iona dobil za 200€ v neki akciji :D
skibidi
klkkkkkkkkkk ::
http://www.dinokomp.si/produkt/be-quiet...
zkaj je 650W 170 EUR
1000w je pa cenejši za 1EUR
klkkkkkkkkkk ::
napaka imo
upam... če se ga bo dal dobit za 100EUR potem ga vzamem :) .... rvno razmišljam HX650 ali pa tale...
sem mel podobmo zmogljivga atoma in je zadeva pain in the ass za uporabljat.
Žal te moram in ostale razočarati ker nimate prav.
Youtube/filmi 1080p na mojem E450 delajo odlično. Če imate pa take izkušnje z Atomom vam pa žal ne morem pomagati.
GenZNPC ::
Mogoče zato: E450 (avgust 2011), Atom 525 (june 2010), Atom 330 (sept 2008). Jaz mam zadnja dva, kupljena takoj ko sta prišla na trg. Pač rekli so da bo šli, pa ni :D
skibidi
seveda, ker jih pospešuje gpu.... kaj pa sicer ?
nope. gladko browsanje in več kot 480p yt je dream kot kaj druga. In to dvojedern atom navit na 1.8GHZ...
k sreči je stvar letela iz hiše k novemu lastniku...
Ne ne to govorim za E-450.
Dvojederenga atoma sem mel na morju, mu je blo muka na momente bilo predvajati 460p.
amd rešuje samo onboard grafika, ki je zmožna pospeševat te zadeve, CPU del je pa sicer isto zanič kot pri atomu...
No no. Tok pa spet ni šrot.
Evo test Ivy Bridge E
http://anandtech.com/show/7255/intel-co...
Malo sem pogledal pa opazil, da novejši programi lepo izkoriščajo FX-8350
