Forum » Igre » Americas Army problem: Error setting display mode
zeleni jurij ::
U glavnem k zaženem AA se mi pojav problem. Bl natančen napiše tole:
Build AmericasArmy_Build_[2004-06-01_02.01.01]
OS: Windows XP 5.1 (Build: 2600)
CPU: AuthenticAMD PentiumPro-class processor @ 1673 MHz with 255MB RAM
Video: RADEON 9000 SERIES (6575)
Error setting display mode: CheckDepthStencilMatch failed. (D3D_OK). Please delete your armyops.ini file if this error prevents you from starting the game.
Tud poj k sm zbrisov armyops.ini mi isto napiše. Če je kdo kej bl pametn kukr jez mi nej plis pumaga.
"Ponujam lahko le kri, trdo delo, solze in znoj."
Winston Churchill
davco17 ::
Jest mam pa podoben problem :
Build AmericasArmy[BuildDate:08-30-07_BuildVersion:2.8.2]
CPU: AuthenticAMD Unknown processor @ 2314 MHz with 2047MB RAM
Video: ATI Radeon X1550 Series (6683)
Failed to enter Entry: Can't find file 'Entry'
History: UInput::StaticInitInput < - UGameEngine::Init < - InitEngine
Ce gdo ve kak ta error odpravit.
Hvala
Hvala
| » | Flamebait: Vista sux (res?)Oddelek: Operacijski sistemi | 2408 (1863) | oldguy |
| » | je grafična fučOddelek: Pomoč in nasveti | 1441 (1243) | nitro2 |
| » | Unreal 2004 problem???Oddelek: Pomoč in nasveti | 1207 (1150) | dobnik |
| » | Navijanje bartona 2500+Oddelek: Navijanje | 1346 (1190) | kihc |
| » | UT 2003 problemOddelek: Pomoč in nasveti | 1287 (1173) | SmoKey |
