Prenosnik HP
Prenosnik HP
blaz202 ::
ŽIV!
Stvar je taka: odločil sem se za nakup prenosnika.
Vem da na to temo obstaja veliko tem pa vendar se jaz odločam med nekaj že izbranimi modeli.
Uporabljal ga bom za izdelavo zapiskov, za na faks, ogled kakšnega filma, poslušanje mp3, igranje kakšne igrice, internet,...
VSI SPODNJI MODELI SO PREDSTAVITVENI!
Na voljo so naslednji modeli:
HP Compaq nx6110 Centrino 1.6G
PROCESOR PENTIUM M 360 730 (1.6G) L2 2MB Centrino
POMNILNIK 512MB DDR 333MHZ-DO 2048MB
TRDI DISK 40GB SMART ATA
DVD/CD-RW ENOTA, NI DISKETNE ENOTE
INTEL GRAPHICS ACCELERATOR 900 do 128MB
ZASLON 15" TFT 1024X768 XGA
MODEM 56K V.92, 10/100 UTP, WLAN 802.11 b
ZVOčNA KARTICA Z VGRAJENIMI JBL PRO ZVOčNIK
BATERIJA Six-cell Lithium-Ion
OS WINDOWS XPP
Priložene slo nalepke za tipkovnico
VMESNIKI:2XUSB 2.0, NI PARALEL, 1XRJ11, 1XVGA, Firewire, 2XAUDIO, 1x PCMCIA Type I/II/I
DIMENZIJE: 30.3X328.6X267, TEžA 2.75KG
GARANCIJA 1 LETO
CENA: 219,900.-
PROCESOR PENTIUM M 360 740 (1.6G) L2 2MB Centrino
TRDI DISK 60GB SMART ATA
DVD+/-RW ENOTA, NI DISKETNE ENOTE
OS WINDOWS XPH
GARANCIJA 1 LETO
CENA:239,900.-
POMNILNIK 1024MB DDR 333MHZ-DO 2048MB
COMBO ENOTA, NI DISKETNE ENOTE
OS WINDOWS XPP
GARANCIJA 1 LETO
CENA:279,900.-
HP Compaq nc6220 Centrino 1.86G
Procesor IntelPentium-M 750 1.86GH
915GM Express Chipset, 533-MHz FSB, 2-MB L2 c
Pomnilnik 512MB DDR2 400MHz - do 2GB
60.0GB SMART ATA HDD 5400rpm
DVD/CD-RW combo (Multibay), bluetooth, WLAN
brez FDD, dual pointing (tuouchpad, point sti
Grafika Intel Graphics Accelerator 900 do 128MB
Zaslon 14.1'' TFT 1024x768 XGA
56Kbps software modem, mreža 10/100/1000 UTP,
Baterija High Capacity LiON 6-Cell, do 5 ur
OS WIN XP Pro Angleški
Priložene slo nalepke s šumniki za tipkovnico
Vmesniki: 3xUSB 2.0,1xSerial,
1xmodem RJ11,RJ45, VGA, 2xAudio,
docking, travel battery conector
PCMCIA 1x tip I/II, Ambient light sensor,
Infrared, S-Video TV-out, SD/MMC slot,
Dimenzije:26.5x315x257 teža od: 2,13Kg
Garancija 1 leto
CENA:299,900.-
Zadnji model jemljite z rezervo, ker ne vem če bo na voljo.
Kaj mislite o teh modelih?
Kaj menite o predstavitvenih modelih?
V kolikor ste lastnik, kakšne so izkušnje?
Kaj menite glede cene?
Kaj bi drugega priporočili?
VNAPREJ HVALA VSEM!
MitkoVIP ::
heheh jz nebi nobenga od teh mel.za 310k mas NX8220 pa je cist hud.jz ga mam pa sm res zadovoln za ta dnar,tko da se ti ga splaca pogledat ce si zainteresiran. osebno mi pa noben od teh ni vsec ker sem vse vidu pa mi zaslon ni biu vsec. pac stavr okusa. LP ;)
Zheegec ::
Sem slišal o teh "predstavitvenih", ampak IMHO raje kar novega kupi. Recimo prvo konfiguracijo dobiš za 10K več v trgovini.
Janez Janša, 29.04.2014
anze20 ::
Lej, karkoli boš vzel, nej ti ne bo škoda dat še 30 jurjev za podaljšanje garancije na tri leta. Ker men se je zgodilo pred 2 leti, da sem kupil HP-ja za 380 000, pa mi je plošča crknila po 1 letu in 2 mesecih.
Anze
alex32 ::
Hi,
bodi pozoren na malenkosti, vecina teh modelov nima vgrajenega BLUETOOTH, čeprav bi moral biti po tovarniških podatkih ...
blaz202 ::
Živ!
To naj bi bili predstavitveni modeli ki naj bi ne bili uporabljeni. Osebno mislim da gre za nek uvoz iz tujine ker ni slovenske tipkovnice.
Alex32 kaj pa ti misliš s tistimi malenkostmi- je lahko to kaj narobe?
alex32 ::
blaz202: mal so oskubljeni in kot je nekdo napisal, brez Slo tipkovnice ... modri zob manjka, pa wlan je samo b ... to ze nanese ... odvisno za kaj rabis pc ...ostalo pa je Ok
  • spremenilo: alex32 ()
billy ::
Ma ti predstavitveni so bedarije. Razen, če bi bila res konkretna razlika v ceni kar pa ni. Recimo pri nas dobiš kaj takega:
Procesor: AMD Turion 64 ML-28 1.6-GHz,
Zaslon 15.0' TFT XGA (1024x768)
Pomnilnik:512MB DDR 333MHz
(razširljiv do 2 GB, ni proste reže)
Trdi disk 60 GB
DVD +/- RW enota Double Layer Technology
Integrirana ATI MOBILITY RADEON X300 do 128 MB RAM
Mrežna kartica 10/100/1000 in analogni modem V.92
Brezzična mrežna kartica WLAN 802.11G, Bluetooth
Vmesniki: 1xVGA, 1xS-Video, 1xFireWire, 3xUSB 2,0, port replikator
Čitalec 6 v 1, PC Card Type II, čitalec prstnih odtisov
Reža za kartice ExpressCard/54., vmesnik za potovalno baterijo
Li-Ion baterija (do 3h)
Dimenzije: 32,8 x 26,7 x 3,17 cm – 2.72 kg
Windows XP Professional (možnost tudi SLO verzije)
Garancija 1 leto
Cena: 265.000,00 SIT
Podaljšanje garancije na 3 leta stane pa še dodatnih 36 tisoč.
bepapa1 ::
Prenosnike HP imajo ugodno v spletni trgovini Rolan
poldi
Zheegec ::
Billy, točno tak prenosnik je v BOF Lj 250K :D
mzidy ::
Brat bo kupil TEGA kar se mi ne zdi tako slaba naložba:)
mat11 ::
Ker sem odstopil se bi verjetno dalo še dobiti ta nootbok :
HP Pavilion dv4246 EA
15,4 zaslon
Intel Pentium 725 1,6ghz
1024 ddr
100gb 4200obrt
128ati Mobilty radeon x700
DVD pekač dual
za ceno 1162 evrov , akcija se začne v sredo v Metroju, enega imam zaenkrat rezerviranega(imam predračun), ga pa bom če se ne bo noben javil odjavil.
mat
  • spremenil: mat11 ()
mzidy ::
Ka ni Centrino?:\
billy ::
Alien, ima ja..ampak z windows XP Home različico, tisto kaj sem jaz pastal je professional, ki pa je žal "nekoliko" dražja.
billy ::
mzdiy, ni slaba naložba, se pa da dobit kje še malček ceneje...
Zheegec ::
No, za Pro verzijo pa jaz ne bi dal niti tolarja zraven - razlike praktično ni, podpora SMP pa QOS pa se pri temu prenosniku pač ne pozna >:D
Je pa res, da je zato dražji.
Anyway, tale HP očitno res nima Centrino nalepke ko je tako poceni. Super nakup potem :D Škoda samo da ima 4200Rpm disk, ampak vseeno je dobra mašinica. Pri nas dobiš šele tam za 340K kaj boljšega od tega. A operacijski je zraven?
@mzidy: Meni se je ta prenosnik vedno zdel super. Monitor sicer ravno ni odličen, je pa 15.4" 16:10 format, kar je že nakaj. Sicer tega prenosnika ni več za dobiti, ampak če še imajo stare zaloge ga kar nabavi hitro. Priporočam nakup Carepacka za HP, da imaš 3 leta garancije.
Sicer je sedaj za 330K na voljo isti model, samo da ima P-M 1.73GHz in Double Layer podporo, kar se pa za 20K več seveda ne splača dokler se še tega dobi.
  • spremenil: Zheegec ()
mzidy ::
billy: Kje pa se dobi še ceneje?
ALIEN3001: hvala za mnenje, jutri ali pojutrišnjem gremo ponj8-)
Zheegec ::
Billy pa vedno napiše, da se dobi ceneje :D
Daj link no, prosim - samo ne na "predstavitvene modele".
billy ::
reklame se ne bo delalo, privat pa lahko vse izveste ;)
PS, morm malo BOFu v zelje hodit ;)
Zheegec ::
Ma daj povej, da potem gre človek tja kupit, madona.
Saj S-T ni online trgovina, pišem samo o tistih stvareh ki jih poznam pa glede na to kaj mislim da se splača pač svetujem. Če imaš kje kakšen link do poceni Toshib, HP, Asusov, Acerjev, Sonyjev pa IBMov, (vse ali karkoli od naštetega) povej!
blaz202 ::
Živ!
Zanima me če se splača na račun hitrejšega procesorja "žrtvovat" ram in velikost diska,..?
primer:
prenosnik 1:
Procesor Intel Pentium M 740 (1.73GHz) Centrino
Trdi disk 40-GB 5400 rpm
Enota DVD/CD-RW (multibay)
512-MB (400 MHz) DDR-2Gb Max.
A TI Mobility Radeon X600 64MB VRAM
8-cell Lithium-Ion baterija
Ambient Light, Docking, Travel Battery Conect
prenosnik 2:
Cena je ista.
Potem pa naj mi še nekdo razloži kaj pomeni:"Ambient Light, Docking, Travel Battery Conect "
billy ::
Absolutno. Prenosnik je tako namenjen za pisarniško delo ne. Za kar takega je 40G več kot preveč. Procesor pa nima ravno neke jake veze ko "obdeluje" tabele oz dokumente.
Več rama pa vedno pripomore k hitrejšemu delovanju.
PS, allien...ne še ;)
Zheegec ::
Raje povej firmo prenosnika, ne samo konfiguracijo - drugače pa je pri prenosniku procesor gotovo najmočnejša komponenta, torej ni "ozko grlo".
Billy: spominjaš me na Ramzesa v temi o vesoljcih :D
blaz202 ::
FIRMA: HP
mzidy ::
billy: Bi ti bil zelo hvaležen, tudi če bi mi samo na zasebna sporočila dal link ali sporočil ime Firme kjer je dotični prenosnik cenejši(pa upam, da nad 5 al 10kSIT):)
  • spremenil: mzidy ()
blaz202 ::
Aja še cena 280.000 sit z ddv.
Kaj mislite?
B|az ::
Pozanimi se glede cen in kaj ima... nato kupi. Zakaj potrebuješ modri zob? Zakaj Slovensko tipkovnico? Jaz imam HPCompaq nx6110, ima Slovensko tipkovnico, nima modrega zoba... naprimer. Je super za kakšno igrico, mp3je, muziko, filme in internet. Mrezna kartica pa ni b ampak je g.
Glede cen... ce bos hotel imeti več stvari notri, več boš plačal.
Lep pozdrav.
B|az ::
Jao jao ALIEN3001.
Samo firma tebe zanima, sicer pa saj v BOF-u imas vsega po malem ane? Priporoči.
Lep pozdrav.
Zheegec ::
Pri prenosniku res ni važna samo konfiguracija, recimo jaz osebno ne bi imel kakšnih čudnih plastik ohišij, če bi kupoval prenosnika. Že zaradi izgleda ne, pa še druge stvari so tukaj (če mi poveš model najbrž že kaj vem o ohišju, tipkovnici in monitorju).
A to gledaš kakšno NC serijo, ker večina teh ima priključek za dodatno baterijo (travel battery connect) in port replikator (docking station) - seveda ni nujno no.
[edit] Aja, gledam specifikacije - prvi je NX8220? Če mene vprašaš zelo huda mašinica, sploh nova (tolk zelo nova niso več no) HP ohišja so mi všeč.
link_up ::
hello,
ok malce si bom sposodil temo, upam da ne bo kdo hud :)
torej tudi sam nameravam kupiti prenosnik do 300k. Se najbolj pri srcu mi je hp nx6110 YPY501EA. Neka cudna izvedba z zame zanimivimi jetri :D
Torej hardware:
Intel Pentium-M 740 (1.73GHz) 2MB L2 cache·Pomnilnik
512MB DDR 333MHz do 2048MB (en prosti slot)
DVD+/-RW, (DL)
Grafična karica Intel Media Graphics Accelerator 900 do 128MB shared
Zaslon 15.1'' TFT XGA 1024 x 768
Modem 56k V.92
LAN 10/100, WLAN 802.11 b/g
Bluetooth·Baterija High Capacity LiON 6-celična
OS WIN XP PRO Edition Angleški, SLO Language pack
Vmesniki: 2xUSB 2.0, 1xmodem RJ11, RJ45, VGA, 2xAudio·Firewire 1394, 1x PCMCIA Type I/II/III
Dimenzije: 30.3x32.6x267, teža: 2,75Kg
//edit: cena je 302.000 SIT
tukaj se mi zdi vse ok. Sam potrebujem prenosnik le za delo. Moti me le malce, da nima com porta, ker vcasih se bi bilo potrebno priklopit diektno na konzolo(gledam usb2com varjante, vendar nekateri govorijo da ne delujejo vedno) in ekran. Sam sem ga sicer gledal v framebufferju in se mi zdi slika pri 1024x768 ok...nic posebnega vendar tako, kot na mojem starem sony 15sf2 crt monitorju :) Kje se torej najbolj opazi slab ekran? Pri gledanju, ko sije sonce ali pri igranju iger? Prosim za odgovor, ker ocitno gledam v napacno smer :(
ok..hvala za odgovore
In and Out
  • spremenilo: link_up ()
_marko ::
->za 310k mas NX8220 pa je cist hud
Ja, kje???
P.S. A ve kdo koliko se se grejejo HPji in kako je to tiho?
The saddest aspect of life right now is that science
gathers knowledge faster than society gathers wisdom.
  • spremenil: _marko ()
Zheegec ::
Jao, za 300K imaš že NX6125 s Turion64 2.2GHz, 1x512MB RAM, 80GB 5400Rpm, x300 do 128MB, BT, FW, WLAN, Tv-out, 3xUSB pa 15.1" 1400x1050 ekranom (BOF, BB, Enaa,... za 299.990).
Tale NX6110 se seveda NE splača.
Na splošno se HP malo grejejo ("zgornji" del prenosnika pri tipkovnici ni topel), pa tudi glasni niso, seveda če je noter nek normalen procesor, ne pa kakšen Pentium 4 ali AthlonXP-M
link_up ::
alien...ko noc in dan...jst sm prasal glede ekrana...konfiguracija mi ustreza, ker ne rabim multimedijskega high-end procesorja in ostale graficne crap navlake, ki zre baterijo...no vseeno, hvala za mnenje :D
In and Out
CWIZO ::
Obujam staro temo, vem. Vendar me zanima nekaj glede dveh HPjev tako da...
Na mimovrste, sem našel teladva prenosnika.
Prvi ima hitrejši procesor, 20GB več diska in pa BrightView.
Računalnik bi uporabljal za programiranje (Visual Studio 2005, PHP, MySQL) za surfanje po netu, in na faksu (FRI) za zapiske in vaje (nekako bi z njim nadomestil moj PC, ki je star že 6 let). Skratka ne rabim grafične pošasti. Rad bi pa imel nekaj kar mi bo zdržalo ene 3, 4 leta. Je to potem sploh primerna izbira?
hancic.info
I can't uninstall it, there seems to be some kind of "Uninstall Shield"...
Nakup prenosnika do 300.000 SIT!
93433 (2992) unkn0wn
NEC versa M350
61552 (1447) zee
15.4 vs 15
202316 (1951) nurmaln
Hp prenosnik nx6110 360
173030 (2894) carlito149
nakup prenosnika nekje do 400kSIT
61996 (1842) dejvidlj
