Forum » Programiranje » [JAVA] netbeans
[JAVA] netbeans
bijonda ::
Hallo!
Evo mene nazaj. Sem mislila da mi bo sama ratlo pa se nicesar vec ne spomnim.
Glavni program je
Drugi razred je :
V netbeansu pa probam napisati WS, ki mi pa javlja napako pri progarmu:
Javlja mi napako:
C:\Documents and Settings\student11\Desktop\DocWS\DocWS\src\java\org\me\doc\DocWSImpl.java:2: 'class' or 'interface' expected
package org.me.primer;
1 error
Kako bi jo lahko odpravila.
ALi mogoce pozna kako slo. stran kjer je opisano delo z netbeansom, ker meni tuki nobeden ne more pomagati, ker s tem se neobeden ni delu!
Please help me!
Lap dan!
Ciao ciao Bijonda
Glavni program je
import HLIWrapper.*;
import java.io.*;
import java.util.*;
public class DMS implements DMSMsgCodes {
// spremenljivke oz atributi
static String koda;
static String izdaja;
static String opis_dokumenta;
public Vector MyDocs() {
Vector polje = new Vector();
Db db = null;
BindV bindv = null;
Hli hli = new Hli();
String DbName = new String("pro_base");
String UserName = new String("wilson");
String HostName = new String("ntdms");
String PCSrvrName = new String("sherpasv");
String Password = new String("welcome");
try {
db = hli.ConnectDb(HostName,PCSrvrName,DbName, UserName, Password);
db.Bind("group1");
db.dms_execute("LIST RECORD DOCUMENT\\*\\* /WHERE=\" owner =" +
"\"\"zfur\"\" and reclevel=\"\"CREATED\"\"\" name4,recalt,desc");
for (;;) {
// Get the next set of results.
bindv = db.dms_fetch("group1");
if (db.dms_msgcode() == DMS_EOF) // End of results
break;
if (db.dms_msgcode() != DMS_OK){ // Error
System.out.println(db.dms_msgtext());
continue;
// dobimo vrednosti spremenljivk
koda = bindv.record_name4(0);
izdaja = bindv.record_recalt(0);
opis_dokumenta = bindv.record_desc(0);
Dok dokument = new Dok(koda, izdaja, opis_dokumenta);
polje.add(dokument);
catch (DMSException e) {
System.out.println(e);
if(db.dms_msgcode() == DMS_NOSUCHDB)
System.out.println("Please modify the DbName in this" +
" program and try this again.");
// vrne vektor
return polje;
// zacetek izvajanja
public static void main(String[] args){
DMS l = new DMS();
Vector w = new Vector();
w = l.MyDocs();
for(int ii = 0; ii < w.size(); ii++) {
System.out.println(((Dok)w.elementAt(ii)).podatki());
HLIWrapperUtils.cleanup();
Drugi razred je :
* @author student11
public class Dok {
private String koda;
private String izdaja;
private String opis_dokumenta;
public Dok(String koda, String izdaja, String opis_dokumenta) {
this.koda = koda;
this.izdaja = izdaja;
this.opis_dokumenta = opis_dokumenta;
public String podatki(){
return koda + " " + izdaja + " " + opis_dokumenta;
package org.me.doc;
* This is the implementation bean class for the DocWS web service.
* Created 2005.10.6 16:10:19
* @author student11
public class DocWSImpl implements DocWSSEI {
org.me.primer.DMS dMS;
org.me.primer.Dok dok;
// Enter web service operations here.
// (Popup menu: Web Service->Add Operation)
* Web service operation
public String Vrni(java.lang.String v) {
// TODO implement operation
return podatki;
Javlja mi napako:
1 error
Please help me!
Lap dan!
Ciao ciao Bijonda
- spremenil: kopernik ()
kopernik ::
Zadnji razred spremeni v :
package org.me.doc;
import org.me.primer.*;
* @author student11
DMS dMS;
Dok dok;
public String Vrni(String v) {
return v;
kopernik ::
Informacij o razvojnih okoljih (tudi o netbeansih) je ogromno, resda večinoma v angleščini. Če ti angleščina povzroča težave, potem pa slovar v roke :-) Mislim, da slovenskih informacij ni prav veliko ...
| » | Davčne blagajne (strani: 1 2 3 4 … 24 25 26 27 )Oddelek: Programiranje | 392183 (132186) | Macketina |
| » | Web services - Neveljavni karakterji v XMLOddelek: Programiranje | 6321 (5433) | boolsheat |
| » | [JAVA] branje iz datotekeOddelek: Programiranje | 2827 (2462) | Bela01 |
| » | [JAVA] zaustavitev niti (threadov)Oddelek: Programiranje | 3698 (3698) | morbo |
| » | [Java] Shranjevanje podatkov in datotekOddelek: Programiranje | 1593 (1546) | Vesoljc |
