Wireless lan linux ra0 --> eth2?
shock ::
Živijo,
te dni se malo igram z WLAN-om v Clarkconnectu 3.1 (baje jedro centOS 4). Driverje in navodila za inštalacija driverjev je na tej povezavi. Saj je vse lepo in prav ampak me moti da spozna mrežno pod interface ra0, jaz pa bi rad imel jo pod eth2. Pod /etc/modprobe.conf sem dodal vrstico "alias eth2 rt2500" in pod /etc/modules.conf pa sem spremenil vrstico, kjer je bilo "alias ra0 rt2500" v "alias eth2 rt2500". Pa še vedno co dam iwconfig mi izpiše naslednje:
lo no wireless extensions.
eth0 no wireless extensions.
eth1 no wireless extensions.
ra0 RT2500 Wireless ESSID:""
Mode:Ad-Hoc Frequency=2.412GHz Cell: 7E:EB:1E:9D:88:C3
Bit Rate:6Mb/s
RTS thr:off Fragment thr:off
Encryption key:off
Link Quality=88/100 Signal level:-184 dBm Noise level:-256 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
sit0 no wireless extensions.
ppp0 no wireless extensions.
A mi kdo kako idejo da spremenim iz ra0 v eth2?
  • spremenil: shock ()
cryptozaver ::
V /etc/sysconfig/network-scripts imas datoteke ifcfg-eth0, ifcfg-lo itd. Preimenuj ifcfg-ra0 v ifcfg-eth2
cryptozaver ::
aja pa poglej se v /etc/sysconfig/networking/devices in /etc/sysconfig/networking/profiles/default. Preimenuj se tam!
shock ::
ok da mlo pokažem kakšno je stanje pri meni. V datoteki /etc/sysconfig/hwconf imam sledeće napisano
class: NETWORK
bus: PCI
detached: 0
device: eth2
driver: unknown
desc: "RaLink Ralink RT2500 802.11 Cardbus Reference Card"
vendorId: 1814
deviceId: 0201
subVendorId: 1814
subDeviceId: 2560
pciType: 1
pcidom: 0
pcibus: 0
pcidev: 9
pcifn: 0
v datoteki /etc/sysconfig/network-scripts/ifcfg-eth2 pa
TYPE=Wireless
DEVICE=eth2
BOOTPROTO=static
IPADDR=192.168.2.123 # replace with proper IP address
NETMASK=255.255.255.0
GATEWAY=192.168.2.1 # replace with proper gateway address
DOMAIN=
IPV6INIT=no
ONBOOT=yes
USERCTL=yes
#ESSID = any # replace with proper ESS ID
#CHANNEL = 3 # set to proper channel
#MODE = Ad-Hoc # don't know what happens if set Adhoc
#RATE=54Mb/s # could choose other rates
ko pa hočem zagnt ifup eth2 pa mi napiše to:
]# ifup eth2
rt2500 device eth2 does not seem to be present, delaying initialization.
Nič več mi ni jasno.
shock ::
Aja če pa inicaliziram ra pa dela normalno
# ifconfig ra0 up
]# ifconfig ra0
ra0 Link encap:Ethernet HWaddr 00:0E:2E:5C:C3:6F
inet6 addr: fe80::20e:2eff:fe5c:c36f/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:627 errors:1 dropped:1 overruns:0 carrier:0
collisions:11 txqueuelen:1000
RX bytes:0 (0.0 b) TX bytes:26708 (26.0 KiB)
Interrupt:11
Ubuntu in adsl
Oddelek: Operacijski sistemi
202741 (2457) gregs
wireless
51571 (1469) 'FireSTORM'
Internet dela ali ne dela (lnux)
272521 (2190) root
red hat 9 in mrežna kartica sis900
81403 (1352) dr.J
internet & linux
71977 (1863) simon
