Kateri prenosnik?
Kateri prenosnik?
Steinkauz ::
Ok a ma kdo HP Pavilion dv6, ker nameravam kupit tole:
http://cgi.ebay.de/HP-Pavilion-dv6-2020...
Tle http://www.notebookcheck.net/Review-HP-... prebral, da je precej glasn:
Due to the dv6-1199eg's observed reserve capacities, we would at least have wished for a pleasant, quiet operating of the notebook, but there could be no talk of it in the test. Our test model's vent ran permanently even when idling without load, and it was always present and also subjectively considerably audible at 38.8 dB(A). The hard disk's clicking was also audible, but could not be measured in consequence of the vent's comparably high volume. The vent again moved up a gear under load and reached up to 43.7 repectively 44.8 dB(A).
To se mi zdi fuuuuulll ;((:8)
Oziroma baje so vsi dv6 glasni. A se da kej v biosu štimat al pa kej?
Ker drugače je ta prenosnik čista zmaga za tak dnar.
stojko1 ::
zakaj pa z AMD procesorjem ... katastrofa !
raje si potem daj 200 eur več in si kupi z i7 procesorjem !!!
drugače pa niso glasni!
do koliko pa kupujes računalnik ? koliko imas proračun ?
stojko
  • spremenil: stojko1 ()
Steinkauz ::
Lahko en dober argument, zakaj bi bil katastrofa?
Al si fanboy?
http://www.cpubenchmark.net/cpu_lookup....
Ostali za tak dnar majo T4200. Če mi daš teh 200eur več, takoj kupm!!!!!1111enaena
700eur max, mam kišto za ostalo.
  • spremenilo: Steinkauz ()
stojko1 ::
http://www.notebookcheck.net/Mobile-Pro...
das 200 eur .... zbereš i dobiš kolega i7!!!!!!
pa ti razmisli .....
stojko
Steinkauz ::
900/700= 30% več.
Zdej če teb 200eur ni nč, super, drugač pa čakam na bolj konstuktivna mnenja.
Dejansko so 300eur več.
Skor 50% več LOL!
Steinkauz ::
No sem še mal pobrskal in najdu še bolš:
http://www.comtech.de/product_info.php?...
oziroma 100eur manj pa samo 100gb disk manj:
http://www.easynotebooks.de/xanario_pin...
pa najboljši proc od vseh štirih. Majka :)
stojko1 ::
ta toshiba za 599eur :)
stojko
stojko1 ::
ta zadeva se mi pa zdi za klubsko ceno 669 EUR super strojček !
stojko
kmetek ::
Kaj so to eni novi modeli Hpja?
HP PB 6545b M600 320G 2G W7PR (NN192EA#BED)
Zaslon: 15.6'' LED 16:9 (HD+ 1600x900) nesvetleč
OS: Windows 7 Professional SLO/ANG 32bit
CPU: AMD Turion II Ultra DC M600; 2.4 GHz; 2MB L2
RAM: 2 GB DDR2; HDD: 320 GB 7200rpm; DVD+/-RW SM
VGA: integrirana ATI Radeon HD4200 Dx10.1
Leks ::
@stojko1
povej mi ali je prenosnik identičen temu na sliki, ker mislim da ima tale model tiste rožice gor.
Vsaj večji model 3660 sem prejšnji teden videl in ima takšne rožice gor.
stojko1 ::
da rožice ima gor !
stojko
house ::
Kaj pravite na tale prenosnik HP PAVILION DV7-2177 za 949€:
17.3'' zaslon - HD LED zaslon (1600x900)
intel CoreDuo P7550 2.26GHz
4G pomnilnik
500GB SATA
ATI HD4650 1GB
Blu-ray Disc
vgrajena spletna kamera
vgrajeni zvočniki Altec Lansing
HDMI izhod
e-SATA vhod
čitalec kartic
8 celična baterija
daljinski upravljalnik
Bluetooth
Windows Vista Home Premium
Se ga splača kupiti oziroma obstaja kaj enakega (boljšega) za manj denarja ali enako ceno?
Hvala!
Gost ::
Ja obstaja kaj boljšega. Jaz sedaj res ne bi kupoval prenosnika z prednaloženo Visto. Zunaj je že sedmica.
BALAST ::
Kaj misliš da bodo po dobrem mesecu od uradnega izida sedmice vse prenosnike poslali na nadgradnjo?
Malo morgen! Proizvajalci bi imeli še večjo izgubo, kot jo že sedaj imajo zaradi "krize", ima pa vsaka znamka svojo opcijo, da ti pošljejo inštalacijski CD od sedmice na dom, eni brezplačno, drugi za znesek do 20EUR.
Da bodo vsi prenosniki na tržišču imeli sedmico bo preteklo še mnogo let. Najcenejši prenosniki pa bodo seveda iz stare zaloge in se bo kupec moral sam poigrati z namestitvijo.
NazgulRR ::
HP ti pošlje cd za sedmico na dom za 39,90EUR. +cel kup trialware-a se inštalira zraven.
Blazx ::
Mene pa zanima kater prenosnik se mi splača kupt v rangu 450-550EUR.
Rabil bi ga za šolo, za po netu normalno, filmi, muska... brez kakšnih zahtevnih igrc, ker zato mam običn računalnik. Mogoče za kakšno nezahtevno igrco... :)
Ogledane imam tele:
http://www.bigbang.si/racunalnistvo/rac...
Al pa če imate kakšne bolše predloge, mi prlimejte kakšn link prosm... :)
Hvala vsem, že vnaprej.
Zheegec ::
Kmalu se zna pojaviti Lenovo N500 za 400EUR...
Janez Janša, 29.04.2014
stojko1 ::
stojko
Steinkauz ::
Pri kompih kupljenih od julija naprej lahko visto for free nadgradiš na win 7.
Vsaj tako je blo rečeno
JayKay ::
jaz sem na srečo najdo ta W7 Pro :)
oglasujejo kot upgrade, dobiš pa FPP kodo :)
  • spremenil: JayKay ()
Gost ::
Ne vem, zakaj bi bil to problem potrošnika z omejenimi sredstvi, če lahko pa dobi za enako ceno zadnjo verzijo os-a že zraven.
house ::
Lahko daste kakšno povezavo prosim?
Blazx ::
Kakšno imate kaj mnenje o tem prenosniku? Glede na ceno...
Matko ::
Je poleg Toshibe in ASUS-a še katera firma, ki ima vsaj 2 leti garancije za PRAVNE OSEBE?
house ::
  • spremenilo: house ()
urosz ::
Pavilion je najboljši med temi 6
house ::
A je velika razlika med 40cm zaslonom in 17'' zaslonom...?
JayKay ::
17 x 2,54 = 43,18 cm
Leks ::
poglej si tudi tega PRENOSNIK ASUS PRO64VG-JX110V, ali model brez Win.
Blazx ::
Ogledan imam tale prenosnik, pravijo da je kar uredu... A se splača kupt za tako ceno?
http://www.mimovrste.com/artikel/275020...
Blazx ::
še nekaj... Operacijski sistem: Bootable linux, kaj sploh je to?
A se da potem Windows 7 gor dat?
nurmaln ::
ja, da se
Climber ::
Pozdravleni,
brat ma namen ta teden kupt prenosnik 17". Zanima kera grafična je boljša:
NVidia GT-120M (512MB DDR2 VRAM) al pa
ATI Mobility Radeon HD 4330, 512 MB
Kolk je razlika med 6 in 8 celično baterijo?
Gigabyte GA-P35C-DS3R, Intel Q6600 8Mb, Radeon 4550 512Mb,
2GB OCZ Platinum 800Mhz, WD 500Gb Sata II 16Mb, NEC 5720, LC Power 6550G,
Thermaltake Xaser III blue.
ant ::
house ::
Kateri računalnik pa je boljši od teh dveh (glejte samo karakteristike, cene so druge - spodaj, ker ne bo preko spleta kupljeno):
http://www.lovecnacene.si/nerazvrsceno-...
S tem da se pri prvem dobi še HP torba zraven in WIN7 (739EUR), drugi pa ima Visto in nič ne dobiš zraven (799EUR)...
Leks ::
pri HPju pripravi še 100EUR za podaljšanje garancije na 3 leta (srčno priporočam).
house ::
To imam tako v načrtu - podaljšanje garancije! A je HP tako 'pokvarljiv' drugače? Še vedno pa me zanima, kateri od zgornjih dveh navedenih prenosnikov je boljši...?!
stojko1 ::
da kvarijo se . ....
najbolje bos prišel skozi če kupiš toshibo l505-111 + big bang garancijo se zgodi 3 leta !!! fantastična zadeva !!!
stojko
lopov ::
Mnenje o tem laptopu -- Dell Studio 1555 15.6" LED Backlight TN+Film (1920x1080)
https://content.it4profit.com/itshop/it...
Pomislek imam le pri velikosti zaslona -- resolucija se mi zdi za pisarniško delo (word, excel) previsoka. No, jaz bi ga mel, ampak oseba za katero to je ma okice že bolj slabe.
Thx, b.
jinzo ::
Saj se da resolucija po potrebni zmajnšati. Ampak, ta sistem je primeren za bol vešče uporabnike, za nevešče je malo "overkill" pomoje no.
( jaz sem ravno ta model naročil pri Comshopu - pa še se "kregam" z njimi, ker trdijo da ni dobavljiv, FMC pa pravi da je - oz. ga imajo.)
P.S: je skrivnost, koliko je cena takega prenosnika na it4profit ?
  • spremenilo: jinzo ()
Leks ::
to je verjetno tale model DELL INSPIRON 1555 [N51428], ki očitno je dobavljiv, saj so ga v shop vnesli danes. Ali pa je mogoče šele v prihodu...
lopov ::
@Leks -- ta ima 1366x768
Če se ne motim je cena it4profit modela brez sistema in z ddv nekaj čez 1000 eur.
JayKay ::
Thx, b.
tega mam že par mesecev. fimna zadeva, resolucija primerna za grafiko, film. na veliko resolucijo se hitro navadiš.
lopov ::
A ... super. Sem kr mal fouš :)
Pa moram se popravit -- it4profit model je *skupaj* z W7 pro (dokupljeno posebej) okoli 1050 evrov.
Leks ::
Tale pa je pravi Enaa.com
kmetek ::
Izbira se med 3 prenosniki:
Prenosnik Acer AS5538G-514G50M (LX.PEA02.078)
Microsoft(R) Windows(R) 7 Home Premium Slo/Ang
procesor: AMD Athlon 64 X2 Dual-Core L510 kok dober je tale procesor?
zaslon 15,6" WXGA-HD (1366x768) Super slim
grafika ATI Radeon HD 4330 (512 MB VRAM)
pomnilnik 4 GB, disk 500 GB SATA
HDMI, Bluetooth, GLAN, Wlan b/g/n, čitalec kartic
garancija 2 leti za potrošnike
Optična enota: DVD SuperMulti Double Layer
Standardna Numerična tipkovnica
Multi-gesture touchpad
Kamera: Acer CrystalEye high-def webcam
Bluetooth: 2.1+EDR
Baterija: 6-celična KOK NAJ BI TO ZDRŽALA?
LAN: 10/100/1000Mbps Gigabit Ethernet
Brezžična Mreža: dual-band quad-mode 802.11 b/g/n
Dimenzije: 380 (W) x 259 (D) x 26/30 (H) mm
Teža: 2,4 kg
Garancija:Potrošniki 2 leti; Podjetja 1 leto
HP Compaq Presario CQ61-330EM
Procesor: AMD Turion II Dual Core M500 (2.2GHz), L2 1MB
Pomnilnik: 4096MB DDRII 800MHZ (ni proste reže) max. 8GB
Trdi disk: 500GB SMART SATA 5400rpm
Opticna enota: DVD+/- RW SuperMulti LightScribe,
Zaslon: 15.6" HD Bright View, locljivost: 1366x768, Vgrajena VGA kamera
Graficna kartica: ATI Mobility Radeon HD 4330 Graphics 512MB
Mrežne povezave: mrežna kartica 10/100
Brezžicne povezave: Integriran 802.11 b/g WLAN, Bluetooth
Vmesniki: 3xUSB2.0 (3. si deli z e-SATA), 1x
e-SATA+USB, 1xRJ45, 1xVGA, 2xAUDIO, 1xHDMI 1.3,
Citalec kartic 5 v 1
Miška: touchpad
Tipkovnica: slovenska + numericni del
Baterija: 6-cell Lithium-Ion (Li-Ion)
Operacijski sistem: FREE DOS
Dimenzije: 37.8 cm x 25.2 cm x 3.51 cm; Teža 2.68kg
Ostalo: Altec Lansing zvocniki
Garancija: 1 leto (1-1-0)
Lenovo Value Line G550G 59-027387
Intel Pentium Processor T4300
(2.10 GHz; 800MHz FSB; L2 1MB Cache)
Mobile Intel GM45 Express Chipset
RAM:3GB; 1066MHz PC3-8500 DDR3 SDRAM
HDD:320GB Serial ATA 5400rpm
DVD+/- RW Dual Layer, 5-in-1 card reader
Intel Graphics Media Accelerator X4500M
15,6'' 1366x768 (HD) LED Backlight + integr.C
Integrated Ethernet 10/100,
Wi-Fi 802.11 b/g, Bluetooth
SLO tipkovnica
BATERIJA: 6 Cell Lithium-Ion
OS Windows7 Home Premium ANG
Express Card
VMESNIKI: External Display (VGA); Headphone;
Microphone; RJ-11, RJ-45; 3 USB2.0; HDMI
TEŽA: 2,7KG; dimenzije VxŠxG; 26,5-36,2x381x2
Mednarodna GARANCIJA: 1 leto, baterija 1 leto
Najbolj se nagibam k Acerju zaradi konfiguracije in 2 letne garancije.
  • spremenil: kmetek ()
durrenmatt ::
HP ma boljši proc
kmetek ::
proc ni tok pomemben.
Zheegec ::
Acer as5542G?
kmetek ::
ni mi všeč, predebel.
184 / 675
