MessengerBlocker,Messenger Stopper HELP
Twoface ::
8-O
Imam namrec se kr hudo tezavo,vsaj zame.. Pred kratkim sm formatiro disk in sedaj se mi po vsakem zagono pojavljajo "sporocila" takozvana "messenger service" in se jih toliko pojavi da se ne dajo zapreti..
NAto sm install MESSENGER Blocker ko pa je potekla verzija sm koncno nasel se MESSENGER stoper.. Problem pa je nastal ker imam le se par dni na voljo pred potekom verzije!
Sedaj pa spresujem ce pozna kdo kak program ki 100% sam zapre ta sporocil brez kaksnega piskanja ali opozarjanja! Ali pa morda serial number teh programov
10x!
ĐONI BI GUT!
ToniT ::
Start->Run->Services.msc
Potem poišči Messenger in ga daj na disabled pri startup type.
Twoface ::
Sm ponovno fomatiral pa naredo tist ko si napisl pa se vedno to dela..
Prvo opozorilo kar mi je napisalo je bilo to:
Messege from WARNING 213.161.17.130 on 4/6/2005 2.19:pm
YOUR COMUTER MIGHT ALEREADY BE INFACTED
Did you know that this very moment someone is trying hack into you com?
Are you PREPARED?
the good news is its not too late. With quuc action you can
sleep easier at night knoqing you computer and your family
are protected from all sorts of vugal internet spam
To find out now to act quickly,visit
www.Escapeads.com
PA sm instal messenger blocker in pa se messenger stoper vendar ju lahko uporablam samo 5 dni ker sta za placat..
HELP!! and
10x
ĐONI BI GUT!
SasoS ::
Inštaliraj si firewall. Messenger service nima kaj delat na netu.
Msn messenger
Oddelek: Programska oprema
61515 (1355) TheJack
MSN Messenger napaka:80072efd
93464 (3356) JC_DENTON
Msn messenger
82232 (2016) odpisani
messenger in zivcni zlom!!!!
202181 (1699) KTr1sk
Kako izklopit Windows MESSENGER ?!
172007 (1650) krucymucy
