MS Access 2003 problem
mov ax 0x7c0 ::
Zdravo!
Imam en velik problem... V Accessu hočem importirati podatke iz excelove preglednice (File->Get External Data->Import)... Ko zberem preglednico in stisnem na gumb Import mi javi tole:
ko pa tukaj stisnem Ok mi pa javi tole:
kaj je tukaj narobe???? Prosim pomagajte
Vsak dan nekaj novega :)
gkovac ::
Excelov file shrani kot TXT (Tab delimited) in probi spet uvozit. Če ti to ne bo delal pa še enkrat naloži import module od Accessa... daš CD not in izbereš da ti popravi inštalacijo in pogledaš tam kjer maš inport / export tools
lp,
____________________________________________
"Left to themselves, things tend to go from bad to worse."
Rok Nemec ::
Mislim da je tole narobe:
Cause: DAO Is Not Properly Registered
Resolution
1. On the computer that hosts Microsoft Windows Terminal Server or the computer on which Microsoft Access is installed, click Start, and then click Run.
2. Type regsvr32 followed by the path to your DAO file. Enclose this path in quotation marks. For example, to register the DAO 3.5 library, use the following command:
regsvr32 "C:\Program Files\Common Files\Microsoft Shared\DAO\DAO350.DLL"
Hrupna grafična kartica
102634 (2382) RiNC
MSN Messanger
Oddelek: Programska oprema
81529 (1196) kilergas
16 bit Windows Subsystem???
71292 (1160) Rok Nemec
Stack Overflow?!?
Oddelek: Programiranje
71631 (1452) Gundolf
Kje pri nas do vodnih blokov za Xein procesorje?
182411 (2087) tiborrr
