Forum » Strojna oprema » temperatura racunalnika?
lebronj ::
a slucajno kdo ve kok mora imeti racunalnik temperaturo da dela normalno in ce kdo pozna program s katerim pogledam temperaturo mojga racunalnika,razn to da lohka pogledam v bios.
- premaknilo iz Pomoč in nasveti: bastadu ()
Shybby ::
Več bi ti lahko pomagali če poveš vsaj katero plato imaš!
Lahko pa snameš Everesta in ti bo vse lepo povedal
lebronj ::
to so podatki o racunalniku:
Processor a
2,15 gigahertz AMD Athlon XP
128 kilobyte primary memory cache
512 kilobyte secondary memory cache
Drives
60,01 Gigabytes Usable Hard Drive Capacity
34,14 Gigabytes Hard Drive Free Space
_NEC DV-5700B [CD-ROM drive]
AXV CD/DVD-ROM SCSI CdRom Device [CD-ROM drive]
TEAC CD-W516EB [CD-ROM drive]
3.5" format removeable media [Floppy drive]
WDC WD600BB-00DKA0 [Hard drive] (60,02 GB) -- drive 0, s/n WD-WCAHL2479545, rev 77.07W77, SMART Status: Healthy
System Model
American Megatrends Inc. 1.0
Main Circuit Board b
Board: K7S8X. 3.0
BIOS: American Megatrends Inc. P2.60 10/20/2004
Memory Modules c,d
1024 Megabytes Installed Memory
Slot '0' has 512 MB
Slot '1' has 512 MB
Slot '2' is Empty
Display
NVIDIA GeForce FX 5700LE [Display adapter]
acer FP751 [Monitor] (17,1"vis, avgust 2001)
Processor a
Drives
System Model
Board: K7S8X. 3.0
Memory Modules c,d
Slot '0' has 512 MB
Slot '1' has 512 MB
Slot '2' is Empty
Display
Shybby ::
Ja saj če te zanima temperatura ti jo Everest tud pove. Klik na Računalnik in potem še senzorji in to je to.
Pa zravn plate si ziher dobil kak cd in mora bit gor Utiliti in pogledaj malo za kakšnim programom ki prikazuje temp!
- spremenilo: Shybby ()
TaBoLjI ::
No, pa če smo ravno pri tem programu....Ali ima grafa Saphire Ati radeon 9800pro temperaturni senzor... Namreč, ta program mi normalno meri temperaturo GPUja (46°) ter "GPU ambient" (41°)
No pa še drugo vprašanje...Ali so te temperature vredu?
Hvala
edit:
Zdaj sem še malo testiral; igral cod kakih 10 min in temperature na full load narastejo na:
Grafični procesor(GPU): 55°C
GPU Ambient: 48°C
Hvala
edit:
GPU Ambient: 48°C
Kar je res je res...in to ni laž :)
- spremenil: TaBoLjI ()
| » | GonilnikiOddelek: Programska oprema | 2403 (2286) | Housy |
| » | Pomoč pri zvočni in čitalcih karticeOddelek: Programska oprema | 2821 (2725) | jan01 |
| » | stara kišta ne zazna vseh ramovOddelek: Strojna oprema | 1891 (1705) | Pyr0Beast |
| » | Igre zamrznejo računalnik, zvok gre na mini loop ali na ton, slika freezne !Oddelek: Pomoč in nasveti | 1770 (1734) | delfinus |
| » | Brand delovna postajaOddelek: Kaj kupiti | 1141 (1079) | dr.J |
