Problem z e-mulo
Problem z e-mulo
glista1 ::
Pozdravljeni!
Lepo bi prosil, da mi pomagate pri problemu, ki ga imam z downloadanjem filmov.....s shareconnectorja.
Imam ADSL, mašina je celeron 2.8, windows xp SP2. Imam instalirano emulo plus 1.1a. Ko grema na shareconnector pod recimo filme, poklikam link , ki bi se moral avtomatsko prenesti v mulo pod transfer. Vendar se to ne zgodi. V explorerju se odpre prazen display s pripisom:
The page cannot be displayed
The page you are looking for might have been removed or had its name changed.
Please try the following:
Open the |file|Deep.In.The.Woods.(Promenons-nous.dans.les.bois).2000.DVDRip.XviD.=STR=.ShareConnector.avi|731009024|D9021347E16A81338EFAEC6B58D5F3B3| home page, and then look for links to the information you want.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
If you still cannot open the page, click the Internet Explorer
Search button to look for similar sites.
Internet Explorer
Zanima me, kaj narediti. Hvala za odgovor
  • zaklenil: gkovac ()
gkovac ::
Za vsa vprašanja na temo emule in podobnih se obrni na tale link. Tema zaklenjena!
lp,
____________________________________________
"Left to themselves, things tend to go from bad to worse."
telemach ga biksa zadnje dni ?
Oddelek: Omrežja in internet
145555 (4944) #000000
Koliko placa za Visto?
Oddelek: Operacijski sistemi
132215 (1865) Pesimist
localhost
Oddelek: Izdelava spletišč
81427 (1296) CWIZO
Kako narediti redirect, če uporabnik vpiše napačno ime .html
161769 (1670) darh
Internet Explorer in crv
101578 (1440) Border
