Forum » Pomoč in nasveti » Problem z e-mulo
Problem z e-mulo
glista1 ::
Pozdravljeni!
Lepo bi prosil, da mi pomagate pri problemu, ki ga imam z downloadanjem filmov.....s shareconnectorja.
Imam ADSL, mašina je celeron 2.8, windows xp SP2. Imam instalirano emulo plus 1.1a. Ko grema na shareconnector pod recimo filme, poklikam link , ki bi se moral avtomatsko prenesti v mulo pod transfer. Vendar se to ne zgodi. V explorerju se odpre prazen display s pripisom:
The page cannot be displayed
The page you are looking for might have been removed or had its name changed.
Please try the following:
Open the |file|Deep.In.The.Woods.(Promenons-nous.dans.les.bois).2000.DVDRip.XviD.=STR=.ShareConnector.avi|731009024|D9021347E16A81338EFAEC6B58D5F3B3| home page, and then look for links to the information you want.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
If you still cannot open the page, click the Internet Explorer
Search button to look for similar sites.
Internet Explorer
Zanima me, kaj narediti. Hvala za odgovor
Internet Explorer
- zaklenil: gkovac ()
gkovac ::
Za vsa vprašanja na temo emule in podobnih se obrni na tale link. Tema zaklenjena!
lp,
____________________________________________
"Left to themselves, things tend to go from bad to worse."
| » | telemach ga biksa zadnje dni ?Oddelek: Omrežja in internet | 5601 (4990) | #000000 |
| » | Koliko placa za Visto?Oddelek: Operacijski sistemi | 2226 (1876) | Pesimist |
| » | localhostOddelek: Izdelava spletišč | 1441 (1310) | CWIZO |
| » | Kako narediti redirect, če uporabnik vpiše napačno ime .htmlOddelek: Izdelava spletišč | 1782 (1683) | darh |
| » | Internet Explorer in crvOddelek: Pomoč in nasveti | 1595 (1457) | Border |
