Forum » Programiranje » [ c# ] NullRefferenceException
atasmrk ::
Torej, sledeco kodo sem skopiral z neta (no, ne cisto vse, tisto if in naprej dol).
pred tem pa imam deklarirani strukturi v istem razredu
Ob prevajanju te kode mi javi warning
PRINTER_NOTIFY_INFO.Version' is never assigned to, and will always have its default value 0
ob izvajanju prve vrstice znotraj if-a pa tisti slavni
System.NullReferenceException: Object reference not set to an instance of an object.
Tu imam pa toliko stvari, da ne vem, kateri ogjekt zadeva misli. Se komu kaj vec sanja?
public bool startMonitoring()
IntPtr pNotifyInfo = IntPtr.Zero;
IntPtr handle = IntPtr.Zero;
int change = 0;
int waitResult = 0;
handle = FindFirstPrinterChangeNotification(hPrinter, PRINTER_CHANGE_JOB, 0, IntPtr.Zero);
waitResult = WaitForSingleObject(handle, INFINITE);
if ( FindNextPrinterChangeNotification(handle, ref change, IntPtr.Zero, out pNotifyInfo))
PRINTER_NOTIFY_INFO info = (PRINTER_NOTIFY_INFO) Marshal.PtrToStructure (pNotifyInfo, typeof (PRINTER_NOTIFY_INFO));
int pData = (int)pNotifyInfo + Marshal.SizeOf( ypeof(PRINTER_NOTIFY_INFO));
PRINTER_NOTIFY_INFO_DATA[] data = new PRINTER_NOTIFY_INFO_DATA[info.Count];
for ( uint i = 0; i < info.Count; i++ )
data[i] = (PRINTER_NOTIFY_INFO_DATA)Marshal.PtrToStructure((IntPtr)pData, typeof(PRINTER_NOTIFY_INFO_DATA));
pData += Marshal.SizeOf( typeof(PRINTER_NOTIFY_INFO_DATA));
FreePrinterNotifyInfo( pNotifyInfo );
Console.WriteLine("konec branja strukture");
return false;
struct PRINTER_NOTIFY_INFO
public uint Version;
public uint Flags;
public uint Count;
// Array of PRINTER_NOTIFY_INFO_DATA follows
struct PRINTER_NOTIFY_INFO_DATA
public ushort Type;
public ushort Field;
public uint Reserved;
public uint Id;
public uint cbBuf; // or adwData[0]
public IntPtr pBuf; // or uint adwData[1]
- spremenilo: atasmrk ()
Kekec ::
Za začetek bi lahko preveril če ti je sploh kaj dalo v pNotifyInfo, če je pa prazen pa je exception čist razumljiv!
atasmrk ::
Ja, ekekec, to je bilo to. Nic se ni tja noter zapisalo. In ko sem se se malo poglobil v MSDN, sem opazil, da s tistim IntPtr.Zero sploh ne zahtevam podatkov. Tako sem deklariral se eno strukturo PRITNER_NOTIFY_OPTIONS
in jo porinil na tisto mesto v klicu procedure, kjer je bila potrebna. tistega buf se sploh nisem dotika, ker sem flags nastavil na PRINTER_NOTIFY_OPTIONS_REFRESH, in bi torej ta funkcija morala vse druge clane te strukture ignorirati.
Sedaj pa dobim NullRefferenceException v klicu funkcije FindNexPrinterChangeNotification(). In mi se zmeraj ni jasno, kaj je narobe. Kaj bi pa sedaj, laho bilo 0?
struct PRINTER_NOTIFY_OPTIONS
public uint Flags;
public uint Count;
public IntPtr buf;
atasmrk ::
ce pa naredim
in potem klicem
pa stvar vrne false, GetLastError() pa vrne ERROR_INVALID_PARAMETER. Kaki prebliski?
PRINTER_NOTIFY_OPTIONS notifyOptions; IntPtr no = IntPtr.Zero; notifyOptions.Count = 0; notifyOptions.Flags = PRINTER_NOTIFY_OPTIONS_REFRESH; notifyOptions.Version = 2; notifyOptions.buf = IntPtr.Zero; no = Marshal.AllocCoTaskMem(Marshal.SizeOf(notifyOptions));
in potem klicem
if (FindNextPrinterChangeNotification(this.hChangeObject, ref change, no, pNotifyInfo))
| » | [C#] pixel scan z ThreadOddelek: Programiranje | 1620 (1402) | perooo25 |
| » | kako narediti program ki bere drugi programOddelek: Programiranje | 7151 (5464) | imagodei |
| » | video v c#Oddelek: Programiranje | 1857 (1397) | boss-tech |
| » | [C#] Sesutje aplikacijeOddelek: Programiranje | 2007 (1842) | Jean-Paul |
| » | [C#] unmanaged->managed codeOddelek: Programiranje | 2557 (2432) | Zzzzzzz |
