mysql problem
mysql problem
bombacina ::
Warning: mysql_connect(): Access denied for user: 'phpb2@localhost' (Using password: YES) in /home/bbb/public_html/forum/db/mysql4.php on line 48
Warning: mysql_error(): supplied argument is not a valid MySQL-Link resource in /home/bbb/public_html/forum/db/mysql4.php on line 330
Warning: mysql_errno(): supplied argument is not a valid MySQL-Link resource in /home/bbb/public_html/forum/db/mysql4.php on line 331
phpBB : Critical Error
Could not connect to the database
ka delamnapak.
Hvala
McAjvar ::
ponovno preberi zgornjo napako. najverjetneje uporabljas napacno uporabnisko ime/geslo (ali pa hostname) pri povezavi na bazo.
"[...] the advance of civilization is nothing
but an exercise in the limiting of privacy."
- Isaac Asimov
bombacina ::
hvala ti
točno tako kot si reku napačno geslo
sam vseeno čisto na koncu vrže še to napako
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, webmaster@mitjab.com and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
hvala
Senzacionale ::
isto sem mel jaz!
ne spreminjaj imena phpbb2, ce uporablas to!
pri meni je bil problem to, ko sem spremenil je javilo isto napako drugace pa je delal
http://www.dostavahrane.si
Začetniški php problem
Oddelek: Programiranje
142463 (2280) Lion29
Rolan d.o.o. spletna trgovina hack
Oddelek: Omrežja in internet
182817 (2422) Tr0n
napaka pri instalaciji foruma
Oddelek: Izdelava spletišč
81756 (1586) no_use4
Napaka pri MySQL pri postavitvi foruma
72124 (2040) DJ-DUST
PHP help!
252252 (2090) rc-car
