Težava z login skripto - rabim pomoč
operater ::
Spodnjo skripto sem uporabljal na RH 9.0 v index.php in je normalno delovala. Sedaj sem prešel na Fedoro 2.0 in
mi omenjena skripta ne deluje. Verjetno rabim aktiviran kak service za avtorizacijo ali pa kaj drugega.
Je komu zadeva znana in bi mi podal nasvet, kje iskati napako.
Hvala za odgovore.
LPG
< ?php
// Start of admin login section //
// You must remove this section if you cannot view this file properly. //
// note! security issues arise if section removed. //
$USER = "test";
$PASS = "test";
function error ($error_message) {
echo $error_message."
exit;
if ( (!isset($PHP_AUTH_USER)) || ! (($PHP_AUTH_USER == $USER) && ( $PHP_AUTH_PW == "$PASS" )) ) {
header("WWW-Authenticate: Basic entrer=\"Form2txt admin\"");
header("HTTP/1.0 401 Unauthorized");
error("MUST LOGIN WITH USER/PASS TO VIEW CONTENTS");
// End of admin login section //
< ?php
if ($no) {
setcookie("InvoiceMaster[0]", "null", time() + 0, '/');
setcookie("InvoiceMaster[1]", "null", time() + 0, '/');
setcookie("InvoiceMaster[2]", "null", time() + 0, '/');
setcookie("InvoiceMaster[3]", "null", time() + 0, '/');
setcookie("InvoiceMaster[4]", "null", time() + 0, '/');
setcookie("InvoiceMaster[5]", "null", time() + 0, '/');
setcookie("InvoiceMaster[6]", "null", time() + 0, '/');
setcookie("InvoiceMaster[7]", "null", time() + 0, '/');
$logout_message = "
You have been successfully logged out.
\n";
Skrat ::
Kaj mislis s tem "ne deluje"??
Free software is a matter of liberty, not price.
Prenašanje cookijev med poddomenami
202331 (2046) jype
PHP cookie problem
Oddelek: Izdelava spletišč
81682 (1377) Ziga Dolhar
unset cookie
222223 (2030) tomitza
phpNuke problem s cookiji
91657 (1589) the_unborn
Tracking v PHPju
Oddelek: Programiranje
62178 (2063) darh
