Forum » Pomoč in nasveti » epox 8rda3+
epox 8rda3+
Jochaan ::
Ali mogoč kdo ve če podpira ta matična plošča epox 8rda3+ tudi rame na vodilih 266Mhz, ker na njihovi strani piše :
Specifications for EP-8RDA3+:
• Socket A Supporting 200/266/333/400MHz FSB AMD Processors
• NVidia NForce2 SPP / MCP Chipset
• 1 Floppy drive controller - serial port - parallel port
• AGP 8x for 1.5v graphics cards, 5 PCI slots
• 2 standard IDE ports for ATA-133, backwards compatible with ATA-100/66
• Onboard Serial ATA support for 2 drives (including RAID)
• 3 DDR SDRAM banks for Maximum 3 GB memory DDR333/400
Dual Channel DDR400 memory support for increased performance (backward compatible)
• 4 USB 2.0 ports, 4 extra by optional USB back-panel cables
• Multiphase power solution for increased stability, including 12v supply adaptation for CPU ....
jRk0 ::
podpira kakrsnekoli ddr rame. hitrost je odvisna kolko znasa fsb procesorja. pol pa lahko nastavljas se malo vecje pa manjse vrednosti od fsb-ja.
Sami ::
Seveda da podpira, tudi hitrosti do DDR500...
| » | A ma DFI NFII Ultra-A firewire?Oddelek: Strojna oprema | 1146 (1041) | Caligula |
| » | Duron 1600 in Abit kr7a "kompatibilna"???Oddelek: Navijanje | 1521 (1374) | Container |
| » | Mnenje o plati EPOX 8KRA2+Oddelek: Kaj kupiti | 1472 (1409) | Zako |
| » | Epox prenehal s proizvodnjo 8RDA+ :(Oddelek: Strojna oprema | 2636 (2214) | OwcA |
| » | Je kriva plosca za memtest errorje/nestabilnost?Oddelek: Navijanje | 2267 (2119) | AtaStrumf |
