Forum » Omrežja in internet » Hip net Sint.net povezava in delovanje e-mail ?
Lith ::
Imam resne težave s temi Sint.net internetnimi ponudniki, ker enostavno e-mail sporočil s priponkami ne gre pošiljat. Tam mi jamrajo da vse dela, a server smtp. je na pingu 20% izgubljen - ni čudno da ne morem poslat eno sporočilo s 100kB priloženim dokumentom.
Me zanima če komu deluje OK ?
Men daje linux server tole:
750 bytes from 195.246.25.63: icmp_seq=88 ttl=125 time=32.4 ms
750 bytes from 195.246.25.63: icmp_seq=94 ttl=125 time=35.3 ms
750 bytes from 195.246.25.63: icmp_seq=95 ttl=125 time=37.8 ms
750 bytes from 195.246.25.63: icmp_seq=96 ttl=125 time=48.9 ms
750 bytes from 195.246.25.63: icmp_seq=97 ttl=125 time=40.3 ms
750 bytes from 195.246.25.63: icmp_seq=98 ttl=125 time=34.3 ms
750 bytes from 195.246.25.63: icmp_seq=99 ttl=125 time=44.3 ms
750 bytes from 195.246.25.63: icmp_seq=100 ttl=125 time=38.0 ms
750 bytes from 195.246.25.63: icmp_seq=100 ttl=125 time=46.3 ms (DUP!)
750 bytes from 195.246.25.63: icmp_seq=101 ttl=125 time=42.9 ms
750 bytes from 195.246.25.63: icmp_seq=102 ttl=125 time=68.1 ms
750 bytes from 195.246.25.63: icmp_seq=103 ttl=125 time=54.5 ms
750 bytes from 195.246.25.63: icmp_seq=103 ttl=125 time=58.4 ms (DUP!)
750 bytes from 195.246.25.63: icmp_seq=104 ttl=125 time=48.5 ms
750 bytes from 195.246.25.63: icmp_seq=105 ttl=125 time=53.3 ms
750 bytes from 195.246.25.63: icmp_seq=106 ttl=125 time=72.0 ms
750 bytes from 195.246.25.63: icmp_seq=107 ttl=125 time=34.5 ms
750 bytes from 195.246.25.63: icmp_seq=108 ttl=125 time=33.3 ms
750 bytes from 195.246.25.63: icmp_seq=109 ttl=125 time=73.0 ms
--- smtp. ping statistics ---
127 packets transmitted, 102 received, +7 duplicates, 19% packet loss, time 141095ms
rtt min/avg/max/mdev = 27.165/46.910/133.449/17.507 ms
v Windowsih pa:
Reply from 195.246.25.63: bytes=742 time=34ms TTL=124
Reply from 195.246.25.63: bytes=742 time=30ms TTL=124
Request timed out.
Reply from 195.246.25.63: bytes=742 time=95ms TTL=124
Reply from 195.246.25.63: bytes=742 time=31ms TTL=124
Reply from 195.246.25.63: bytes=742 time=54ms TTL=124
Request timed out.
Request timed out.
Reply from 195.246.25.63: bytes=742 time=36ms TTL=124
Reply from 195.246.25.63: bytes=742 time=53ms TTL=124
Reply from 195.246.25.63: bytes=742 time=37ms TTL=124
Reply from 195.246.25.63: bytes=742 time=29ms TTL=124
Request timed out.
Request timed out.
Reply from 195.246.25.63: bytes=742 time=51ms TTL=124
Reply from 195.246.25.63: bytes=742 time=40ms TTL=124
Ping statistics for 195.246.25.63:
Packets: Sent = 44, Received = 35, Lost = 9 (20% loss),
Approximate round trip times in milli-seconds:
Minimum = 29ms, Maximum = 104ms, Average = 47ms
Control-C
^C
V glavnem , pi.... jim .... zaf....
v Windowsih pa:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Control-C
^C
Matri[X] ::
Tudi če pride do packet lossa, priponka bi se še vseeno morala poslati. Packet loss v teoriji tuki nima veze, ker se paketki, ki so izgubljeni pošljejo ponovno (velja za TCP povezave katere uporablja tudi SMTP protokol).
b ::
V praksi pa se zgodi, da ti povezavo slej ko prej timeout-a, ce je velik packet loss. 20% _je_ velik packet loss.
Nekaj se prenese, potem pa zadeva zmrzne in cez nekaj casa timeout.
Kakorkoli, vsaj od tukaj zdaj zadeva dela OK...
| » | Visok ping ob določeni uri? (Amis)Oddelek: Pomoč in nasveti | 1823 (1668) | čuhalev |
| » | Amis internet - pogostost izpadov?Oddelek: Omrežja in internet | 2747 (1577) | ABX |
| » | Slovenski internet ponudniki - konkurencaOddelek: Omrežja in internet | 2945 (2480) | ThinMan |
| » | Visok ping pri adsluOddelek: Omrežja in internet | 5404 (4765) | MOJNET.net |
| » | ADSL vs kabelOddelek: Omrežja in internet | 3198 (2417) | Jinxy |
