Hip net Sint.net povezava in delovanje e-mail ?
Lith ::
Imam resne težave s temi Sint.net internetnimi ponudniki, ker enostavno e-mail sporočil s priponkami ne gre pošiljat. Tam mi jamrajo da vse dela, a server smtp. je na pingu 20% izgubljen - ni čudno da ne morem poslat eno sporočilo s 100kB priloženim dokumentom.
Me zanima če komu deluje OK ?
Men daje linux server tole:
750 bytes from 195.246.25.63: icmp_seq=88 ttl=125 time=32.4 ms
750 bytes from 195.246.25.63: icmp_seq=94 ttl=125 time=35.3 ms
750 bytes from 195.246.25.63: icmp_seq=95 ttl=125 time=37.8 ms
750 bytes from 195.246.25.63: icmp_seq=96 ttl=125 time=48.9 ms
750 bytes from 195.246.25.63: icmp_seq=97 ttl=125 time=40.3 ms
750 bytes from 195.246.25.63: icmp_seq=98 ttl=125 time=34.3 ms
750 bytes from 195.246.25.63: icmp_seq=99 ttl=125 time=44.3 ms
750 bytes from 195.246.25.63: icmp_seq=100 ttl=125 time=38.0 ms
750 bytes from 195.246.25.63: icmp_seq=100 ttl=125 time=46.3 ms (DUP!)
750 bytes from 195.246.25.63: icmp_seq=101 ttl=125 time=42.9 ms
750 bytes from 195.246.25.63: icmp_seq=102 ttl=125 time=68.1 ms
750 bytes from 195.246.25.63: icmp_seq=103 ttl=125 time=54.5 ms
750 bytes from 195.246.25.63: icmp_seq=103 ttl=125 time=58.4 ms (DUP!)
750 bytes from 195.246.25.63: icmp_seq=104 ttl=125 time=48.5 ms
750 bytes from 195.246.25.63: icmp_seq=105 ttl=125 time=53.3 ms
750 bytes from 195.246.25.63: icmp_seq=106 ttl=125 time=72.0 ms
750 bytes from 195.246.25.63: icmp_seq=107 ttl=125 time=34.5 ms
750 bytes from 195.246.25.63: icmp_seq=108 ttl=125 time=33.3 ms
750 bytes from 195.246.25.63: icmp_seq=109 ttl=125 time=73.0 ms
--- smtp. ping statistics ---
127 packets transmitted, 102 received, +7 duplicates, 19% packet loss, time 141095ms
rtt min/avg/max/mdev = 27.165/46.910/133.449/17.507 ms
v Windowsih pa:
Reply from 195.246.25.63: bytes=742 time=34ms TTL=124
Reply from 195.246.25.63: bytes=742 time=30ms TTL=124
Request timed out.
Reply from 195.246.25.63: bytes=742 time=95ms TTL=124
Reply from 195.246.25.63: bytes=742 time=31ms TTL=124
Reply from 195.246.25.63: bytes=742 time=54ms TTL=124
Request timed out.
Request timed out.
Reply from 195.246.25.63: bytes=742 time=36ms TTL=124
Reply from 195.246.25.63: bytes=742 time=53ms TTL=124
Reply from 195.246.25.63: bytes=742 time=37ms TTL=124
Reply from 195.246.25.63: bytes=742 time=29ms TTL=124
Request timed out.
Request timed out.
Reply from 195.246.25.63: bytes=742 time=51ms TTL=124
Reply from 195.246.25.63: bytes=742 time=40ms TTL=124
Ping statistics for 195.246.25.63:
Packets: Sent = 44, Received = 35, Lost = 9 (20% loss),
Approximate round trip times in milli-seconds:
Minimum = 29ms, Maximum = 104ms, Average = 47ms
Control-C
^C
V glavnem , pi.... jim .... zaf....
Matri[X] ::
Tudi če pride do packet lossa, priponka bi se še vseeno morala poslati. Packet loss v teoriji tuki nima veze, ker se paketki, ki so izgubljeni pošljejo ponovno (velja za TCP povezave katere uporablja tudi SMTP protokol).
b ::
V praksi pa se zgodi, da ti povezavo slej ko prej timeout-a, ce je velik packet loss. 20% _je_ velik packet loss.
Nekaj se prenese, potem pa zadeva zmrzne in cez nekaj casa timeout.
Kakorkoli, vsaj od tukaj zdaj zadeva dela OK...
Visok ping ob določeni uri? (Amis)
61823 (1668) čuhalev
Amis internet - pogostost izpadov?
Oddelek: Omrežja in internet
172747 (1577) ABX
Slovenski internet ponudniki - konkurenca
72944 (2479) ThinMan
Visok ping pri adslu
325404 (4765) MOJNET.net
ADSL vs kabel
373198 (2417) Jinxy
