Tero ::
Kako to misliš? Ja 27 sem star ja
Rias Gremory ::
uf hmal bo 800 strani nakladalnice.
Lion29 ::
LinksysOne: pr meni jih je sam 200
ne sklepat, da imamo vsi isto nastimano kolko postov na stran
Founder and CTO @ News-Factory.app
IvoJan ::
Pri meni jih je 2616 ;)
Tero ::
Lion29: Torej kakšen je tvoj zaključek o meni? :)
THEjanac13 To pa ja najdeš polno po internetu. Če ne druga copy pastaš nekaj iz wikipedije
Lion29 ::
@Tero: kaksen zakljucek se rabis? NEhaj tle morit in pejt u lajf (real life)
Tero ::
Kaj pa je tvoje real life? Da si obkrožen z ljudmi?
Janac ::
@tero, recem ti da mi opises poklic, da bos imel neko delo ampak vidim da se ti neda in bos raje tle pisal kako je danes dolgočasen dan
Lion29 ::
ja, pejt MED LJUDI ja... mislim ej v kake debate se sposcam... kot da bi razlagal 5 letnemu otroku....
Tero ::
Lion29 ok recimo da bi zdaj hotel upoštevat tvoj predlog. Kaj je prvi korak? kam naj grem?
Tero ::
heh ja evo ena minuta dela. Čisti copy paste:
A programmer, computer programmer or coder is someone who writes computer software. The term computer programmer can refer to a specialist in one area of computer programming or to a generalist who writes code for many kinds of software. One who practices or professes a formal approach to programming may also be known as a programmer analyst. A programmer's primary computer language (C, C++, Java, Lisp, Delphi etc.) is often prefixed to the above titles, and those who work in a web environment often prefix their titles with web. The term programmer can be used to refer to a software developer, software engineer, computer scientist, or software analyst. However, members of these professions typically[citation needed] possess other software engineering skills, beyond programming; for this reason, the term programmer is sometimes considered an insulting or derogatory oversimplification of these other professions[citation needed]. This has sparked much debate amongst developers, analysts, computer scientists, programmers, and outsiders who continue to be puzzled at the subtle differences in the definitions of these occupations
Janac ::
ty
Lion29 ::
@Tero:
1. Poisci kako organizacijo mladih, je kr nekaj takih na stajerskem..pejdi tja pol OSEBNO
2. vpisi se na fitnes ali kaksen plesni tecaj... tako spoznas zelo velik folka
3. vpisi se v kak drug tecaj, kjer je velik mladih (pejdi malo v mesto pa poglej oglasne deske)
4. Nekdo ti je ze predlagal, da gres kelnarit (brez izgovora o nerodnosti)
5. Se redno udelezujes koncertov in raznih drugih meetingov
6. Zacni hodit na sportne prireditve
moznosti je zelo veliko... smo odlepit se mores dejansko s kavca
crazyLIKEme ::
@Tero lahko pa greš pa se ponudiš za trgatve, zdej ko so se začele. Pa za sadje pobirat, baje iščejo ful. Pač sezonsko delo. Dobil boš keš, pa še folk boš spoznal. Vse kar moraš narediti je da pokažeš zanimanje
http://crazyl1keme.deviantart.com/
Tero ::
1: Kje? sem že veliko googlov. ne pozabi da jaz se ravno nimam za mladega...
2. sovražim plesat, sovražim fitnes
3. Hmm.. kje so kake oglasne deske?!
4. Hmja... nevem no občutek imam da bi me morebitni delodajalec vrgel po par dneh...
5 ja se rad hodim na razne "koncerte" samo to stane in jaz sem brez denarja
6. Kje pa so kakšne športne priredtive? recimo zdaj vem da je v Mariboru ekomaraton ampak hočejo met 30 € za štartnino?!?
crazyLIKEme hm dobra ideja :) Bom malo poguglal za to če kje rabijo.
- spremenil: Tero ()
Lion29 ::
jap... tudi jabolka je fajn pobirat..spoznas folk...
in kot da nebi vedu, da bos nasu cel kupo izgovorov na moje predloge...
tudi ce sovrazis fitnes ali ples, se spokja tja... ce ned drugega zaradi druzbe..
oglasnih desk je cel kup... pejdi magari na avtobusno in se malo razglej okoli.. pa okoli faksov je cel kup
a ti se sekiras za naprej, da te bo delodajalec vrgel... najbolje da si prerezes zile in mrknes... sej tak in tak bos na koncu umrl... zakaj bi sploh zivel...
v google sem napisal mladi maribor, sem ze na prvi strani dobil cel kup zanimivih rezultatov...
crazyLIKEme ::
Ola, ti in tvoj google. Imenik v roke in klicat okoliške sadjarje in vinogradnike.
Tero ::
Škoda :)
Mah dovolj teh debat za danes. MI ni več. Malo sem tukaj resno mislil malo sem trolal. Ampak res pa je vsekakor da se z ljudmi ki jih ne poznam ne morem pogovarjat, da nujno iščem službo in da sem geek :)
Gladi ::
crazyLIKEme je izjavil:
@tero saj imaš tukaj crazyLIKEme, ti sam zapeci
No go. Zasedena. Next
Fixed.
Zasedenost je samo ovira
Rias Gremory ::
A kdo ve kdaj se izdihne pri sklecah? Ko greš dol ali ko se dvigneš?
Lion29 ::
meni logika pravi ko gres gor... ampak prosim ne me drzat za besedo
PrimozR ::
Jep, ko izvajaš obremenitev izdihneš, ko sproščaš pa vdihneš. Valda je obremenitev, ko dvigaš :)
imgburn
galu ::
Rias Gremory je izjavil:
Jaz zadržujem dih... Najbol da narediš kolko jih lahko, pa potem vdihneš ko maš čas :)
Tako to gre.
gendale ::
evo, če normalno temo odprem, mi gamad moderatorska takoj zbriše, tko da morm sm dat zgleda:
tko je mel en kolega piknik in mi tam začne en model težit
jst ga vprašam, če so kaki problemi, on me pa odrine
no pol sem mu zlomil nos in par reber
kasneje sem ugotovil, da je tip mislil, da ga njegova punca vara z mano
lol
lol
welcome troll
Tero ::
Če je to res kaj praviš se mi zdi to tako neumno. Nasilje ni rešitev. Sam še nikoli v življenju nisem reševal konfliktov z nasiljem. Pač upam(morda naivno) da je večina ljudi dandanes nad tem. Da smo to pustili v zgodovini.
Tero ::
eo ubuntu zapeko s hitrostjo 3x in je se vedno isto
Kakšne probleme pa imaš? Nevem sicer kaj hočeš naredit, ampak ubuntu lahko instaliras tudi iz USB ključka. Jaz tako vedno naredim ko rabim.
Janac ::
crazyLIKEme ::
Odvisno od števila prikazanih objav ;))
Drugače pa šiht :D http://www.bolha.com/racunalnistvo-prog...
Piggykiller ::
800. stran (vsaj pri meni).
Vse najbolše za xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx strani!![]()
Fixed!
ko bo 100000000000000000000000 bom nazdravil
