Forum » Šola » Kako se orientiraš po soncu in uri?
WildTHink ::
V angleščini:
If you have an analog wrist watch, you can use the time to find north. Hold your watch up in front of you, and let the short hand, red on the figure, that indicates hours point at the sun. While holding it like this, cut the angle between the red arrow and 12 o'clock in two, (noonwards if the time is before 6am or after 6pm), that way is south. (The reason you need to cut it in two, is because the clock takes two rotations while the sun takes one around the earth, it is of course the other way around, but never mind.)
Many people wear digital watches these days (I do myself, if I wear one at all). If you do, draw an analog watch face on a piece of paper, and then mark the hour hand on using the digital watch. The rest of the method is identical.
This method can be used even when it is pretty foggy. Although you may not be able to see the sun, it may still cast a shadow. If you take up a straw or a tiny stick, and you may see a shadow. You just have to remember that the shadow points the opposite way from the sun, but the rest of it is quite similar as above.
So... are you red or blue?
| » | Manj znane igre (strani: 1 2 3 4 )Oddelek: Igre | 49177 (21917) | D3m |
| » | citati za tiste k znate angleško (strani: 1 2 3 )Oddelek: Loža | 14979 (3904) | yansek |
| » | HellionOddelek: Igre | 2637 (2195) | oo7 |
| ⊘ | Washa playlista (mp3)Oddelek: Loža | 140420 (138762) | Lord650 |
| » | GTA3 DodoOddelek: Igre | 3590 (3117) | burekar |
