Forum » Strojna oprema » nov NVIDIA System Utility Version: 1.08.5
kuglvinkl ::
dl
Version: 1.08.5
File Size: 11.5 MB
Release Date: March 31, 2004
Download
» Primary Download Site «
If you are unsuccessful downloading from the primary download site please use the mirror site options below:
» Mirror Site 1
» Mirror Site 2
» Mirror Site 3
Overview:
NVIDIA® System Utility is the ultimate utility for accessing, monitoring, and adjusting your system components, including temperature and voltages with clear, user-friendly control panels. Overclock your system for highest performance or underclock it for near silent operation. All changes are performed within the Microsoft® Windows® interface – enabling full functionality without the need to make changes in the BIOS and reboot your system.
Installation Notes:
* This application package replaces all previous versions of the NVIDIA System Utility. Earlier versions of the application should be uninstalled and the system rebooted prior to installation of this package.
* Support for the advanced features of the NVIDIA System Utility requires vendor specific setup files that are not included with this package. Please contact your motherboard or system vendor for the correct files to enable this functionality.
Release Notes:
* This is a complete, updated release of the NVIDIA System Utility. You are not required to install a previous version of this application before installing the latest version.
* On nForce motherboards where specific BIOS support is not available, only basic functionality will be available.
* Supported products:
o nForce 220, nForce 220D, nForce 415 and nForce 420D
o nForce2 and nForce2 400
o nForce2 Ultra and nForce2 Ultra 400
o nForce2 400R and nForce2 Ultra 400Gb
o nForce3 150 and nForce3 PRO 150
o nForce3 250, nForce3 250Gb and nForce3 PRO 250
* Supported operating systems for this release:
o Windows XP
o Windows 2000
o Windows ME
o Windows 98SE
* There is no support for Windows XP 64-bit or Windows 2003 Server 64-bit systems at this time.
* Best when run at 1024x768 16-bit color
Products Supported
Advanced product functionality is only available on the products below. This advanced functionality requires specific vendor support files from the motherboard or system vendor. These support files can only be found at the vendor’s site. Please contact your vendor directly for these support files.
* NVIDIA nForce2:
o ASUS A7N8X-E
o Biostar M7NCG
o Epox EP-8RDA+
o Epox EP-8RDA3+
o ABIT NF7-S
* NVIDIA nForce 3:
o Gigabyte K8NNXP
o Shuttle AN50
* The most up-to-date motherboard support list can be found here.
Version: 1.08.5
File Size: 11.5 MB
Download
» Mirror Site 1
» Mirror Site 2
» Mirror Site 3
Overview:
Installation Notes:
Release Notes:
o Windows XP
o Windows 2000
o Windows ME
o Windows 98SE
Products Supported
* NVIDIA nForce2:
o ASUS A7N8X-E
o Biostar M7NCG
o Epox EP-8RDA+
o Epox EP-8RDA3+
o ABIT NF7-S
* NVIDIA nForce 3:
o Gigabyte K8NNXP
o Shuttle AN50
Caligula ::
Mimogrede, 31 marca je bil izdan tud nov IDE driver za Nforce 2, ki se ga dobi na isti strani med driverji.
Kar se tice system utilities-to je se vedno crap.
Jaz mam 8RDA+ 1.1 in se vedno ne morem stimat nic pametnega.
To je proti 8rdavcore piece of shit.
- spremenil: Caligula ()
kuglvinkl ::
No kul, ker imam tut sam 1.1, potem zadeve ne bom vleku dol.
Kaj pa 2.0? In Abitke?
Fury ::
Na NF7-S 2.0 in z nvsuoem.ini se da samo FSB, AGP clock in ram timinge (ne CAS) stimat.
8rdavcore rox
8rdavcore rox
Caligula ::
V bistvu ne vidim nobene razlike med prejsnjo verzijo in to. Obe sta useless. Kako ne rata taki firmi narest cesa tazga kokr je 8RDAvcore pa po tolkem cajtu mi ni jasno.
Namest da s tem zgublajo cas pol naj raj boljse driverje za plate delajo.
Fury ::
Verjetno zato, ker bi jih pol en tozu, da mu je njihov program skuru matično ploščo in podobno... lahko bi 100% naredil, ampak nočjo.
Caligula ::
Mah ni to, k pol bi biu tud Bios cist zajlenjen,..
Pac cepi ne znajo. Raj delajo goljufive driverje kot take, k bi bli dejansko koristni.
Premlatit vse v tej firmi
Corpse ::
js mam tud 8rda+ v1.1 pa s tastaro nism mogu nic pametnga isto stimat tanovo pa vseen dol ulecem da probam...drugace pa uporabljam 8rdavcore ce ze morm kj spreminjat iz winsov pa je zakon dela use pa spreminas use kot u biosu
Corpse ::
ze probov in takoj zbrisov...spreminjam loh sam fsb...nič voltaže procesorja in nič agp pa tko naprej. še temperature mi ne kaže pa ne voltaž pa nič sam FSB a to nj bi potem blo ql navijat. ok ne zame.
| » | Spreminjanje multiplierja in voltaže v winxp?Oddelek: Navijanje | 1354 (1264) | Poldy |
| » | ForceWare - nekaj mi ne da miruOddelek: Navijanje | 1606 (1502) | DjTonic |
| » | Nvidia System utility, kar smo čakali smo dočakali :)Oddelek: Strojna oprema | 2264 (1790) | njok |
| » | ForceWare je tuOddelek: Novice / Matične plošče | 3090 (3090) | waters |
| » | nForce 3 (PR)Oddelek: Strojna oprema | 1920 (1783) | noraguta |
