Forum » Zvok in slika » rezalnik Mp3-jev
rezalnik Mp3-jev
Olajuwon ::
Torej na internetu iščem freeware program, ki mi je sposoben rezati velike mp3 file. A pozna kakšen tak program? Jaz sem izkal, pa vsi so za plačat
Bolj pomembno je obstajati, kakor biti opazen.
- spremenil: CaqKa ()
pivmik ::
Poslušaj predatorja:
Download
Omogoča rezanje MP3 datotek brez izgube kvalitete(brez ponovnega kompresiranja). Je popolnoma zastonj.
Download
mp3DirectCut is a small tool for editing MPEG audio directly. You can remove parts, change the volume, split files or copy regions to new files. All without the need to decompress your MP3 into PCM/WAV. This saves work, encoding time and disk space. And there is no quality loss through any re-compressions. Trim your CD grabbings or directly to MP3 recorded vinyls or tapes. Cut favorite songs from long MP3 radio or live recordings. Make multiple cuts and fades. mp3DirectCut is very fast and gives you extensive control over your MP3s.
LP, Gregor GRE^
- spremenil: pivmik ()
| » | program za rezanje mp3-jevOddelek: Programska oprema | 3675 (3585) | lufthammer |
| » | Program za urejanje mp3-jov!Oddelek: Programska oprema | 3435 (3171) | jackorsen88 |
| » | Rad bi "rezal" mp3-je (kater programček?)Oddelek: Programska oprema | 2249 (1995) | Person |
| » | program za rezanje mp3-jev...Oddelek: Programska oprema | 2906 (2815) | iration |
| » | Razdeliti MP3 na deleOddelek: Zvok in slika | 1606 (1419) | _Mortal_ |
