Tasmota - rules
Tasmota - rules
Matko ::
https://tasmota.github.io/docs/Commands...
Se je kdo že igral s pravili na Tasmoti?
Imam:
Sonoff MiniR2 https://templates.blakadder.com/sonoff_...
naloženo Tasmota 12.3.1.
ne dela OK :(
recimo, čisto enostavni primer
Time-delayed Auto-off Switch
Rule:
Rule1
  on button1#state do backlog power1 %value%; RuleTimer1 600 endon
  on Rules#Timer=1 do power1 off endon
Result:
    On Button press the Light will toggle on/off
    Additionally RuleTimer1 will begin to countdown 10 minutes
    After the RuleTimer1 expires the light will be turned off (if you forgot to turn it off)
Delphi - izdelava igre
Oddelek: Programiranje
81535 (1308) Nextor
C# Pomoč
131818 (1643) jizzer
[C++] izris v [x,y]
131617 (1319) DuleKrtola
c# ... kako je to mozno da Windows.Forms.Timer na istem threadu vec msg boxov pozene
51604 (1563) Vapo1
VB6 kako uporabiti
81323 (1185) Area_51
