Forum » Elektrotehnika in elektronika » Tasmota - rules
Tasmota - rules
Matko ::
https://tasmota.github.io/docs/Commands...
Se je kdo že igral s pravili na Tasmoti?
Imam:
Sonoff MiniR2 https://templates.blakadder.com/sonoff_...
naloženo Tasmota 12.3.1.
ne dela OK :(
recimo, čisto enostavni primer
Imam:
ne dela OK :(
Time-delayed Auto-off Switch
Rule:
Rule1
on button1#state do backlog power1 %value%; RuleTimer1 600 endon
on Rules#Timer=1 do power1 off endon
Result:
On Button press the Light will toggle on/off
Additionally RuleTimer1 will begin to countdown 10 minutes
After the RuleTimer1 expires the light will be turned off (if you forgot to turn it off)
| » | Delphi - izdelava igreOddelek: Programiranje | 1535 (1308) | Nextor |
| » | C# PomočOddelek: Programiranje | 1818 (1643) | jizzer |
| » | [C++] izris v [x,y]Oddelek: Programiranje | 1617 (1319) | DuleKrtola |
| » | c# ... kako je to mozno da Windows.Forms.Timer na istem threadu vec msg boxov pozeneOddelek: Programiranje | 1604 (1563) | Vapo1 |
| » | VB6 kako uporabitiOddelek: Programiranje | 1323 (1185) | Area_51 |
