Forum » Loža » Ukrajina Part IV
Ukrajina Part IV
![](https://static.slo-tech.com/stili/avatar_gray.gif)
TezkoDihanje ::
Nevem zakaj bi Rus sel do Lvova, ce ga bo prepustil Poljakom ko jim namigne da je cas.
mhhmmmm
Zdaj moramo sam še ugotovt, zakaj jih Poljaki futrajo non stop s svojim orožjem:
Heavy weaponry supplied to Ukraine by Poland
- 230+ T-72M and T-72M1(R) MBTs
- 40 BWP-1 IFVs
- AMZ Dzik-2 IMVs
- 20+ 122mm 2S1 Goździk SPGs
- 18 155mm AHS Krab SPGs
- 20+ 122mm BM-21 Grad MRLs
- WB Electronics FlyEye UAVs
- 100 R-73 AAMs
+ Češka
Heavy weaponry pledged or already supplied to Ukraine by Czechia
- 40~ T-72M1 MBTs
- 5+ BVP-1 IFVs
- 56 Pbv 501A IFVs
- Unknown Howitzers
- 20+ DANA SPGs
- 2S1 Gvozdika SPGs
- 20+ RM-70 MRLs
- Strela-10 SAMs
- Mi-24V attack helicopters
- spremenil: TezkoDihanje ()
TezkoDihanje ::
https://twitter.com/AggregateOsint/stat...
#Kherson Axis - The first videos are coming out from the #Ukrainian counteroffensive in Davydiv Brid. The extent of newly captured terrain is unclear but #UAF is moving heavy equipment & troops across the Inhulets River to attack #Russian forces in the area. Videos in next tweet.
This video shows #Ukrainian troops moving into an already liberated settlement of Davydiv Brid. The lack of fighting or tactical posture means the frontlines are likely far away from this position.
Senior White House officials have clarified #UnitedStates Pres. #Bidens's comment today regarding MLRS, HIMARS & #Ukraine. The official explained that #Biden was referring to long range strike munitions (likely ATACMS missiles and not MLRS rockets) that were not being considered.
kopriwa ::
Dobro, dogovor je sprejet, še malo bolj bomo zategnili vratove podgan. Orban sicer veka, ker je pač obstranski "vodja" blejoč v luno in ga nihče ne opazi. Ne vem pa zakaj se pogojuje končanje vojne za odpravo sankcij, sankcije se odpravijo samo in samo takrat, ko je Ukrajina osvobojena in še bolj pomembno, obnovljena. Sicer jih sankcije ne prizadanejo, ampak za sprostitev odvoza žit glavna podgana vseeno zahteva odpravo le-teh. Prava tragikomedija z njihove strani.
TezkoDihanje je izjavil:
mhhmmmm
To se ve, zakaj.
Čehi in Slovaki so fasali od Sovjetske zveze v Praški pomladi, ko so jih Sovjeti nasilno zatrli. Za občutek - Čehslovaki so bili pred 2. sv.v. eden najbolj razvitih narodov v Evropi.
Kar se pa Poljakov tiče, pa imajo kup zamer do Sovjetov (Rusov). Od tega, da so jim za časa 2.sv.v. pobrali polovico ozemlja, do Katinskega gozda, kjer so jim pobili oficirje brez sojenja in v nasprotju z vsemi konvencijami.
Pa ne gre za to, da so Sovjeti zatirali vzhodnoevropske narode. Imam sodelavca, Slovaka, katerega stari starši so bili udeleženi v Praški pomladi, pa mi je pripovedoval, kak je bil filing.
V grobem, Češkoslovaški je šlo čedalje bolje, imeli so tudi(kot eni redkih) dosti strank na Zahodu, njim ni bilo težko dobiti nič - ne materiala, ne deviz, ne nič. Ukazi, ki so padali s strani Partije Češkoslovaške, ki pa je vedno imela kljukico Kremlja, so bili čedalje manj razumljivi. Zdaj bi lahko celi post napisal, zakaj manj razumljivi - samo brezveze. Recimo Mercedez-Benz je zanimalo 8-osno podvozje z dvojnim krmiljenjem, kar je izumila Tatra. To se ni smelo izvažati, čeprav so to bile čiste devize. Sovjeti pa tega niso hoteli/mogli kupovati.
Ko se je Praška pomlad začela, se je zdelo, da so Sovjeti neka outdated prikazen, že čisto zblojena v tistem svojem gnezdu v Kremlju.
Nakar je prišlo vojaško posredovanje, Čehoslovakom se je zdelo škoda, vojna bi uničila vse, tovarne, avte, hiše,vse. Zato niso naredili nič.
Je pa to Čehoslovake zaustavilo za 50+ let.
Kar pa želim povedati, da se je že takrat zdelo ekstremno čudno, da bi pa sedaj nekdo vdrl s tanki v državo. Tako da, Čehi, Slovaki, Poljaki računajo eno 50-60%, da se ta greznica ruska razlije čez meje Ukrajine, če Putina ne ustavijo. Oziroma Putina in tisto kliko v Rusiji, ki si domišlja, da je leto 1953.
Zato na vse pretege pomagajo Ukrajincem.
- spremenilo: bbbbbb2015 ()
![](https://static.slo-tech.com/stili/bel_non_grata.png)
koyotee ::
Voditelji članic EU-ja dosegli dogovor o embargu na rusko nafto. Naftovod Družba izvzet.
Ruska ladja se pocasi potaplja, EU sila!
Rear DVD collector!
JTD power!
JTD power!
Bostjan_321 ::
Komaj čakam na Rusko zmago.
Pírova zmága je zmaga s pogubnimi posledicami za zmagovalca. Fraza je aluzija na epirskega kralja Pira, katerega vojska je utrpela nenadomestljive izgube, ko je premagal Rimljane med Pirovo vojno pri Herakleji leta 280 pr. n. št. in Askulu leto kasneje 279 pr. n. št.
Pirova zmaga za Ukrajino in Rusijo, prva bo fizično uničena in druga ekonomsko izčrpana. Malo kasneje pa še za cel svet, ko nas pohopsa globalno segrevanje. Res smo napredovali kot vrsta...
- spremenilo: Bostjan_321 ()
Češkoslovaška vojska je dobila navodila, da mora iz vojaških WC-jev odstraniti školjke in namesto tega izkopati latrine, da sovjetski vojaki "ne bi doživeli prevelikega kulturnega šoka". Obužčke bi kaj takega strlo.
Drugače povedano, da ne bi vedeli kakšna greznica je v resnici njihova domovina in koliko bolje živijo drugje ter zahtevati tekočo vodo in WC školjke in podobne dekadentne zahodne umotvore.
Ahahahhahhhaahahahah
Lukoil Exec: Russia Should Cut Oil Production By 30% To Get Higher Prices
Cene na borzi pa gor. :)
|HP EliteBook|R5 6650U|
- spremenil: D3m ()
Nekaj takega kot ta komedija! :D
Goodbye Lenin! (2003) - Movie Trailer
- spremenil: fur80 ()
Sigurno imajo nekega asa v roki. Da bi manjšali samo porabo, Rusom pa plačevali več, ne vem, malo čudno. Rusi bodo morali zapirati vrtine ali pa prodajati pod ceno, bomo videli kaj bo! :D
Sicer pa rok je do konca leta.
V tem času se lahko še marsikaj spremeni.
Bostjan_321 ::
Na dolgi rok je to samo dobro za vse nas. Visoke cene bodo pospešile prehod v brez ogljično družbo. Renesansa javnega prevoza in kolesa.
Naftna podjetja se zavedajo da jim bije zadnja ura in zato že tako ali tako dvigajo cene, da se maksimizira profit preden se zabava konča.
S polno ritjo je lahko govoriti.
Ko pa enkrat s tem začneš si pa anti-green v momentu. :)
Bostjan_321 ::
Pozdravljen jamski človek, kar potiskaj glavo v pesek, svet gre naprej s tabo ali brez tebe!
Naftna kriza je bila nekaj najboljšega za dance, nizozemce, ...
Poglej kako so mesta spremenili iz avtomobilskega kaosa v mesta po meri človeka.
Sedaj mora pamet srečat še preostale.
Verjamem, da za bivše kolonialce je super.
Mi moramo pa do njih še priti. :)
Američani so nekaj prepričevali OPEC, da napumpa več. Bomo videli.
@bbbbbb2015
Situacija je sledeča.
sveža novica na oilprice.com
"Saudi Arabia Set To Raise Its Oil Prices To Asia"
Dajejo pozitiven spin na sranje. Ko enkrat zapreš produkcijo jo je menda težko zagnat nazaj, sploh brez zahodnih multinacionalk.
Bostjan_321 ::
glede na to koliko časa se čaka na infrastrukturo.....ja si bom prihranil čas in se pretvarjal, da nimaš pojma. :)
Tak, da kar veselo naprej na javni prevoz hodi. :)
- spremenil: D3m ()
LOL.
MorningZ
Kaj bo dobrega? :D
Dobro jutro
![:D](https://static.slo-tech.com/smeski/icon_biggrin.gif)
Ne bo trebal čakati 2 meseca, da UA dobi M142 in M270
![:))](https://static.slo-tech.com/smeski/icon_lol.gif)
- spremenil: scythe ()
Bostjan_321 ::
Tišči glavo v pesek boomer.
Nisem rekel da bo enostavno. Bo pa z visokimi cenami nafte večja motivacija da se prekine status quo. In ko se bo enkrat to rešilo se ne bo šlo več nazaj na nafto.
Koriščenje ogljikovodikov v taki meri kot se počne danes, je kot zapijanje na puf. Da si "olajšamo" današnji dan se pufamo v upanju da bo že kako ali pa da nas pobere preden bo račun a poravnati.
Tako je. Rusi bodo prisiljeni zapreti vrtine, ker ne bodo mogli nafte procesirat z enakim rate-om kot jo crpajo. Zdaj pac delajo PR iz tega.
Zapiranje vrtine ni kot zapiranje vrtne pipe. Je bistveno bolj komplicirano in drago. Prav tako nato ponoven zagon. To jih zelo boli.
Ja, kratkorocno bo cenovni sok, dolgorocno bodo ZDA pojacale fracking (ker se izplaca) in se bo cena ustalila. Tudi bliznji vzhod bo poskusil unovciti ceno in bo crpal na polno. Bedniki pa bodo ziveli se v vecji bedi.
Bostjan_321 je izjavil:
Kar naprej v šolo hodi mladič. :)
Priporočam SGGEŠ, da te naučijo kako je glede infrastrukture in podobnega heca pri nas. :)
EU prepovedala uvoz ruske nafte, Nemci pa spustili cene tako javnega prevoza kot goriv. Zanimivo :D
Karta od 9 eura
U lipnju, srpnju i kolovozu svi mogu koristiti lokalni i regionalni prijevoz diljem Njemačke po povoljnoj cijeni od 9 eura mjesečno. Prodaja u Njemačkoj željeznici i brojnim prijevozničkim tvrtkama traje već nekoliko dana, a od 1. lipnja vrijedi karta od 9 eura.
Kartu se može koristiti mjesec dana u lokalnom i regionalnom prijevozu diljem Njemačke. Snižena ponuda bit će dostupna i u srpnju i kolovozu, no tada je potrebno kupiti novu kartu.
Željeznička podružnica DB Regio želi u startu povećati svoj kapacitet u regionalnom prometu za 250 putovanja. 50 dodatnih vlakova koristit će se prvenstveno na turističkim rutama. Željeznička tvrtka Abellio također povećava kapacitete na popularnim linijama.
Gorivo
Benzin, dizel i prirodni plin bit će jeftiniji, barem od lipnja do kolovoza. Savezna vlada ovih mjeseci smanjuje porez na energente na goriva na minimum dopušten u EU.
Prema ADAC-u bi u sljedećim mjesecima cijene bile:
Litra benzina: oko 35 centi jeftinije (30 centi smanjenje poreza na energiju plus 5 centi uštede na PDV-u)
Litra dizela: oko 17 centi jeftinije (14 centi smanjenje poreza na energiju plus 3 centa uštede na PDV-u)
Jedan megavat sat prirodnog plina: 4.54 eura manje
https://www.index.hr/vijesti/clanak/od-...
Karta od 9 eura
Gorivo
VladarP ::
Zeleno what
solarni paneli proizvedejo toliko elektricne energije, da se investicija brez subvencij ne povrne nikoli. Pa vecino leta imas krajse dneve brez sonca. Splaca se namontirati na streho samo solarne kolektorje, da imas poleti toplo vodo zvecer ko se gres tusirat. Globalno segrevanje je pa itak laz, Al Gore je lepo sluzil in njegovi z predavanji, kjer je lagal o tem in se zalagal za izdajo okoljskih kuponov ipd. Ne trdim, da clovek ne unicuje okolja seveda ga. Poleg tega pa drasticno omeji sebi plinsko gorivo najbolj ekolosko kar obstaja in se spravi v situacijo, da bo moral spet izsekavati gozdove, kurit premog, koks in traktorske gume.
Zahodni svet itak hoce pelat Agendo 2030, da onemogoci ljudem nabavo vozil, omeji nakup goriva na 200 litrov letno, spravi vse na avtobuse. Na drugi strani imamo pa svobodni svet na vzhodu, ki jim je pokvaril plane.
Akhmat sila
Ena za VladarP-ja in kaj čaka Rusijo. Upam, da ima tvoja dolge lase! :D
Inflacija jih je prisilila v skrajne ukrepe
Po poročanju tujih medijev je inflacija v Iranu dosegla že 45 odstotkov. Ljudje se vse težje prebijajo skozi mesec, v državi pa so zaznali trend, ki se širi med ženskami. Viša se namreč število tistih, ki prodajajo svoje lase, z denarjem pa nato kupujejo hrano ali pa plačajo položnice.
https://cekin.si/premozenje/inflacija-j...
VladarP ::
Aja govorimo o okolju noben pa ne pove zakaj so letala med korono prazna letela, samo da obdrzijo slote na letaliscih? Opravljeno je na tisoce praznih poletov. Zelo zeleno. Ali pa so nas zaprasevali, nikoli se neve - ceprav ne vrjamem.
Mislis nas jeseni
Mislis nas jeseni
![;((](https://static.slo-tech.com/smeski/icon_mad.gif)
Akhmat sila
- spremenilo: VladarP ()
Bostjan_321 ::
Najlaže je reči nič se ne da, nič se ne splača, ...
Čimprej se stegneš tem bolje bo.
cias ::
Ukraine crisis: Zelensky says situation 'indescribably difficult' in Donbas and Kharkiv
https://www.wionews.com/world/ukraine-c...
Jaz sem mojo, oz. se je sama dala na kolo in na šiht! :D Lahko povem, da so tudi pozitivni učinki podražitev! :D
Seveda je, zato se pa havbice že skoraj same tja vozijo!
Bostjan_321 ::
Preživeli smo naftno krizo 70ih, bomo pa tudi to.
Tako kot je takrat nekaj držav srečala pamet, je vsaj malo upanja da jih bo nekaj še tokrat.
Pazi kako prečkaš cesto in ne bulji v telefon + naglavne slušalke.
DAT ASS!!!! NOICE :)))))))
- spremenil: D3m ()
VladarP ::
Ruska vojska je na Azovstalu našla miniran kombi s trupli 152 mrtvih militantov.
@anna_news
Akhmat sila
Bostjan_321 ::
Zeleno whatsolarni paneli proizvedejo toliko elektricne energije, da se investicija brez subvencij ne povrne nikoli. Pa vecino leta imas krajse dneve brez sonca. Splaca se namontirati na streho samo solarne kolektorje, da imas poleti toplo vodo zvecer ko se gres tusirat. Globalno segrevanje je pa itak laz, Al Gore je lepo sluzil in njegovi z predavanji, kjer je lagal o tem in se zalagal za izdajo okoljskih kuponov ipd. Ne trdim, da clovek ne unicuje okolja seveda ga. Poleg tega pa drasticno omeji sebi plinsko gorivo najbolj ekolosko kar obstaja in se spravi v situacijo, da bo moral spet izsekavati gozdove, kurit premog, koks in traktorske gume.
Ne bo držalo.
13kWp panelov je v mesecu maju proizvedlo 1,8MW elektrike, pa je zadnji teden bolj drekasto in deževno vreme.
Globalno segrevanje ni laž. O njem so pisali že znanstveniki v 20 stoletju, že takrat so delali preračune koliko ogljika se bo izpustilo v atmosfero in kak vpliv bo to imelo. Sploh se ne gre za uničenje planeta, ta bo obstajal z nami ali brez nas, si bomo pa sebi oteškočili življenje.
Nimam problemov s tem.
Ti pa le poskrbi za svoj slušni aparat.
A maš kak konkreten primer, da je koga pamet srečala? Ker jaz imam ekselenten super extra spomin, pa se ne spomnim, da bi koga sploh pamet srečala....
Točno tako.
Če ne bo nafte ne bo LEGO kock. :D
Ga nimam mladič. :)
Prosi mami za povišico, da boš lahko imel za pingo in sendvič. xDDDDDD
- spremenil: D3m ()
Bostjan_321 ::
Francozi so šli iz naftnih elektrarn na JE.
Danci in Nizozemci so takrat začeli na veliko izganjat avtomobile iz mest in prehod na kolesarjenje.
Res ni veliko, ampak bolje kot nič. Lahko samo držimo pesti, da se bomo sedaj rešili te odvisnosti od ogljikovodikov.
Točno tako.
Ga nimam mladič. :)
Podelam se nate in na tvoj SDS.
P.S. Lego začenja z izdelavo kock iz reciklirane plastike.
P.P.S. Ko vam zmanjka argumentov, začnete na plano vleči banalne primere. Nikjer nisem pisal da sem za ukinitev nafte iz danes na jutri. Samo napisal sem, da bo visoka cena pomagala prekinit status quo.
Nekaj kar se danes ne izplača, ker je nafta prepoceni se bo jutri lahko izplačalo.
Unchancy ::
Kudos, zelo konsistentno pišeš neumnosti. 10 kW sončnih panelov pokrije hišno elektriko, ogrevanje in še kaj avtomobila. 20 kw pa še več. Cena je bila še lani precej nizka.
Globalno segrevanje povzročeno s strani človeka je dejstvo, ki je bilo jasno že zdavnaj. Če cel kup ljudi tega ne razume, še ne pomeni, da ne obstaja. Pomeni zgolj to, da je kup ljudi preveč butastih, da bi razumelo in/ali da se radi zadržujejo v deželi zanikanja resničnosti.
Bilo bi skrb vzbujajoče, če bi bil ti na strani Ukrajine, tako pa si - kot rečeno - dosleden v svojih neumnih stališčih.
Adijo mod Rdeči Kmeri.
- spremenil: Unchancy ()
Še nekdo, ki je samski in zelo verjetno iz LJ.
Ko imaš družino, nekaj km do prve AP, razmišljaš drugače.
Je pa res, da naftna industija ne želi previsokih cen, ker s tem so dražje alternative (beri EV) vedno bolj aktualne.
LOL.
MorningZ
Kaj bo dobrega? :D
Dobro jutro
Ne bo trebal čakati 2 meseca, da UA dobi M142 in M270Samo ATACMS oz. balistične rakete ne bodo dali zraven, da nebi UA napadla Rusko ozemlje, saj letijo +300km. Dobijo M30, M31 in GMLRS rakete, M30 ima kasetne bojne glave. Vprašanje je samo, ali bodo GMLRS prišle s podaljšanim dosegom do 150km. USA ima na zalogi čez 60.000 raket GMLRS, samo 2021 so jih dobila od proizvajalca 50.000 raket.
A ni bilo nekaj dni nazaj jamranje in obtoževanje RU, da so kasetne bombe prepovedane?!
- spremenilo: fikus_ ()
Bostjan_321 ::
Vse narobe.
Boštjan, spominjaš na onega zelenega inženirčka! Si našel kakšen svoj star račun?!
