Forum » Na cesti » Formula 1 2021
Formula 1 2021
![](https://static.slo-tech.com/stili/avatar_gray.gif)
Če pustimo napako pri SC, potem je RBR taktično zmagal danes!
Tole bo šlo na sodišče
Ali iz strani RBR ali pa Mercedesa
![:'(](https://static.slo-tech.com/smeski/icon_cry.gif)
The latest from Sky Sports News' Craig Slater in Abu Dhabi
"My understanding is we should get a verdict here from the stewards here tonight within the next half an hour.
"I think there is an understanding that this needs to be done tonight after the race was held. It's bad enough that it's dragging on several hours after the race concluded so that should come pretty soon.
"The question is what happens after that. There is an appeals process if Mercedes or Red Bull are not happy with the decision. The loser in this case has the option to go to the FIA's Court of Appeal - but there's a cut-off for that and it's quite soon as well.
"Thursday is the FIA Prize Giving ceremony and any appeal would have to be heard and decided upon by Thursday because there is no recourse after the trophy has been handed over to the world champion."
- spremenil: scythe ()
ripmork ::
Bog pravico ljubi bi rekli stari ljudje in tole je bilo neverjetno,vse čestitke RB za njihovo pravilno in pravočasno strategijo,tukaj so Marcedes povozili na veliko.Marcedes je samo gledal na tole,da ne zgubijo mesto ne pa katera taktika je najbolša.Končno so Lojzeta vrgli s prestola in nič kriv.Marcedes bi moral na koncu menjat pnevmatike in bi zmagali,če bi Max prevzel mesto bi bila obratna situacja,kot je bila,če pa bi oba imela rdeče bi pa itak Lojze bil hitrejši,sam bi pa verjetno počilo.Super zmaga za Max in RB z odlično taktiko.
Se sicer strinjam, da je RB taktično super odpeljal in vse (da ne omenjam Perezove fantastičnosti danes, glasoval zanj za driverja dneva). Sam dejstvo ostaja: če bi po pravilih pustili, da se vsi za SC pravilno razvrstijo, bi še dlje trajalo in bi Lewis za SC-jem pripeljal čez ciljno črto kot prvi. Če bi bila pravila drugačna, bi verjetno tudi Mercedes drugače ravnal. Izigrani so bili, skratka.
Bomo videli, kaj se bo izcimilo. Škoda, ker sta se tako Max kot Lewis pošteno namučila letos in bilokomu privoščim naslov. Kakorkoli se bo tole končalo, pa žal ostaja madež.
F1 stewards reject Mercedes' first protest glede Maxa in SC
Tudi glavni bo
V vsakem primeru se bo do četrtka pritoževalo, v četrtek je podelitev pokala.
reject
![:D](https://static.slo-tech.com/smeski/icon_biggrin.gif)
TOP ::
Ja pa tole je res neverjetno,tale Wolf in Massi bi morala oba iz F1.Kako lahko Massi krši pravila pa človek božji bi mral tole znat,kot abecedo kaj in kako.Po drugi strani on je bos in tako,bi moralo ostati,če pa ne naj tole celo dirko izbrišejo in ostane Max prvak,ker ma več zmag in pika.Če bo sodišče tole odločalo,kdo je in kdo ni bo pa tole prvenstvo za pozabit in naj ga črtajo.Ja Wolf bo iskal vsako luknjo,zakona,čeprav je njegovo moštvo,tole zafrknilo.
connel ::
Huh? Od kdaj je pa Wolf direktor dirke?
Če bi bile strani zamenjane bi se tudi pritoževali, tko da,...
Pa ni luknja v zakonu ffs, procedura ob varnostnem avtu, ni lukenj, le Masi ki ne zna brati oz. poskuša ugajat vsem (kar je nemogoče), tip ma da je diktator na tem mestu, ne pa mediator.
Meizu ::
Ampak kot pravim, potemtakem bo potrebno preverit celotno sezono, ker to ni izoliran primer takšne prakse, že prejšnja dirka je lep prikaz clusterfucka.
Jaz bi Hornerja, Wolfa in Masi skinal iz F1, bi blo bolš za ostale ![:)](https://static.slo-tech.com/smeski/icon_smile.gif)
Tak se pa dela po pravilih: https://streamable.com/9157b6
BT52 ::
Samo ne moreš dat kazni Maxu potem. Kaki šmorn. Masi bi mogel se naredit FRA in pustit SC do konca. Pa rečt, češ še majo za pomest neki tam pri ogradi. V tem primeru mu noben nebi nič oporekal.
- spremenilo: BT52 ()
Tilen88 ::
jah fia je sama sebi skuhala kar si je, že celo sezono je neke čudne odločitve sprejemala, me zanima kako se bo tole razpletlo.
Če se nebi odločalo o prvaku, nebi bilo tega sranja okrog Masija...itd. Zdaj če zavrnejo še zadnjo pritožbo, pol grem stavit, da gre Mercedes na sodišče.
springfield ::
https://twitter.com/ChrisMedlandF1/stat...
Max uradno prvak
Max uradno prvak
- spremenilo: springfield ()
Končno! Nov pir odpret!
BT52 ::
https://twitter.com/AlbertFabrega/statu...
Jup 48.13 article "safety car in this lap" m a prednost pred "unlap cars" v 48.12 . Prvič slišim za to ampak ok. Interpertacija.
springfield ::
https://twitter.com/RachelBrookesTV/sta...
Ce koga zanima obrazlozitev. Tjah, lahko bi se tudi dugace odlocli, ampak tudi ta odlocitev ni napacna.
b3D_950 ::
Tristo kosmatih medvedov, potem pa osmice ne bo še dolgo časa.
no comment ::
Eno leto ni tako dolgo.
Se mi zdi, da mi je prvič žal za Hamiltona.
- spremenilo: no comment ()
Tilen88 ::
Ja res je eno leto ni dolgo, se pa zna zgodit, da jih bomo gledali na 3-4mestu, oz da bo russel boljši.
Tilen88 ::
Potem je zaključeno. Čestitke MAX-u za WDC, in Lewisu za drugo mesto. Se veselim 2022 sezone, upam na vsaj 3-4ekipe pri vrhu.
no comment ::
Tilen88 ::
no comment je izjavil:
Lani bi mogoče še verjel, letos pa ne več. Russel se v dirki prepogosto izgubi. Tako kot Bottas.
jah pol je pa perfect #2 :D lmao
win64 ::
Če gledamo strategije, obojim ni kaj očitati. Zaradi sreče pač ne moreš šteti ene strategije boljše od druge.
Mercedes je imel pozicijo in je bil hitrejši. V takem primeru je logično da delaš enako kot izzivalec za teboj. Seveda pa to lahko storiš šele en krog kasneje. Kar je pomembno v primeru SC.
Red Bull na drugi strani v upanju, da bi se mu kaj posrečilo lahko naredi nasprotno kot Mercedes. Verjamem, da če bi Hamilton šel v bokse, Max ne bi šel.
- spremenil: win64 ()
no comment ::
Ja, pri RB so imeli "lahko" delo, ker so morali samo delati kontra kot Mercedes in upati na čudež. In se je zgodil...
BT52 ::
Plus Max je imel celotno sezono v povrečju hitrejši bolid. Tako, da oporekat bilokaj je nesmiselno. Je pa bilo zanimivo boj do konca. Ima pa Merc konstrukturskega in je nemški inžeirign še vedno najboljši do obeh dirkačev.
pirat ::
Era formule 1 kot avto moto športa se je dokončno končala danes v 29. krogu s slovesom zadnjega dirkača po srcu. Kimi, they will finally leave you alone!
Na sceni ostajajo le še hostese posameznih avtomobilskih znamk, vse skupaj pa postaja "freak show".
TOP ::
In bi imel Lojze nove gume in Max stare in bi ga Lojze na izi prehitel.
no comment ::
Evo imam končni izid vsega dogajanja, FIA ima tak spisane pravila kot švicarski sir, polno lukenj. Bila je pesta sezona, zdaj pa čakamo na testiranje 2022 pa da vidimo nove dirkalnike :) Mercedes se pa naj naspi pa preboli tole, škoda denarja za sodišča.
Nič ne bodo dosegli verjemi
RBR bo govoril, da je šlampasto napisan pravilnik, Mercedes se bo pa na pravila zgovarjal. Čeprav arbitražno sodišče gleda drugače na primere...
![](https://static.slo-tech.com/stili/bel_non_grata.png)
Scaramouche ::
BLM Lojz je zgubil, moram reči da max glih ni simpatik samo Lojz je tok časa težil z neumnostmi tako da uživam v zmagi Maxa!
TOP ::
To vemo sedaj. Takrat pa je bilo zelo možno, da bo konec dirke pod SC.
Točno na to so pri Marcedesu računali in se ni izšlo.
ripmork ::
Če bi bilo več krogov do konca in bi vedeli, da bo zagotovo še dirkanje, bi Mercedes verjetno takoj Lewisa poslal v boks po nove gume. Ker je bilo le še nekaj krogov do konca so sklepali, da se bo dirka končala za SC (kot bi se tudi zgodilo, če bi proceduro pustili kot treba). A se je potem Masi nenadoma premislil in zgolj zaradi popestritve posegel nad proceduro ter izsilil hitrejši umik SC-ja.
Lewis na starih trdih gumah ni imel nikakršne šanse, dirka je bila s to odločitvijo zapečatena.
Lahko se zdaj izgovarjajo nad različne interpretacije pravil, ipd... sam škoda športu je narejena. Pa bilokaj se zgodi potem, ko primer Mercedes privleče na sodišče. Če se da v ključnih momentih standardne postopke in pravila omehčat pa mal ukrivit (ter to na koncu celo odloči naslov prvaka), tekmovanje izgubi na kredibilnosti...
Sem sicer prepričan, da bi v nasprotnem primeru RB navijači popenili, pa gledalci bi vsi bili prikrajšani za nor zadnji krog,... sam kredibilnost športa in konsistentnost pravil bi pa le ostala. Če bi vsakič zaradi popestritve takole mehčali pravila, bi stari f1 rezultati znali precej drugače izgledat.
S tem se pa popolnoma strinjam. Škoda športu je bila narejena in takšnega naslova nebi hotel imeti, vedno se bo vedelo za tole FIA neumnost oz. da je imeli FIA prste zraven. Tudi če Mercedes zmaga na sodišču, bo tole umazani naslov prvaka. Zato pravim, naj ima Max tale naslov, Mercedes pa naj drugam financira denar, ne v sodne postopke.
Scaramouche ::
Naredili so pravilno, zmaga naj šport ne pa pravilo ki bi naredilo anti klimaksno sceno!
Horas ::
joze67 ::
billy ::
Masi je tole super izpeljal, dejansko je naredil točno tako, da je zaobšel pravila.
Če je "pošteno" do lujza ali ne, niti ni tako važno, dirke se ne dobi ali izgubi v zadnjem krogu, pa čeprav je videt tako. Kar naredimo pregled celotne sezone, pa naredimo obnovo za koga bi bilo bolj pošteno, da je WC in kdo ne.
Tilen88 ::
Še bo zanimivo tokom tedna glede tožbe/pritožbe Merca nad fio. Baje so si nekega fancy odvetnika zrihtali. $$
- spremenilo: Tilen88 ()
billy ::
Valda ne bo nič iz tega, to je tako kot bi v fuzbalu naknadno spreminjali rezultate zaradi "slabega" dela sodnikov.
Postavil bi se precedens, kateri bi odprl pandorino skrinjo, zato se bo pač to v celoti zavrnilo.
Ampak naj se merc ukvarja s tem, namesto da bi se fokusirali na 2022 sezono.
Tilen88 ::
Sej ne pravim, da bo kaj iz tega, mi je sam zanimivo gledat tole "post 2021 sezona" dramo
p.s: edin massi mogoče kej nardsa :D
billy ::
Dejansko je tale masijeva odločiev včeraj ena izmed boljših, ki jih je naredil letos.
mojstrsko je zaobšel pravila, da bi se SC lahko čimprej umaknil, itak tistih nekaj voznikov, ki so sli naprej, niso imeli vpliv na ostale in so se samo med samo sfajtali. kako je v tej zmedi uspel ohraniti mirne živce pa nikomur jasno. Če gledamo na Jeddah...
