Forum » Programiranje » Java - JBoss - Servlet - getOutputStream() has already been called for this response ???
bboyspin ::
A ma kdo kako resitev za tale problemcek:
koda:
ByteArrayOutputStream baos = new ByteArrayOutputStream();
String appName = "aplikacija.zip";
String partyId = "";
String partyName = "";
String filename = "";
try {
partyId = (String) request.getParameter("partyid");
} catch(Exception e) {}
if((partyId != null) && !partyId.equals("")) {
ItemLocal party = ses.findItem(Integer.valueOf(partyId));
partyName = party.getItemName();
ImportZIP zip = new ImportZIP(appName);
zip.setOutputDir(r.getUploadPath());
zip.setWorkingDir(r.getDownloadPath());
zip.copyZIP(appName, appName);
zip.setWorkingDir(r.getUploadPath());
zip.writePartyData(partyId, partyName);
zip.addZip(appName, "partydata.txt");
try {
filename = r.getUploadPath() + "aplikacija.zip";
FileInputStream ins = new FileInputStream(filename);
int data;
byte[] buffer = new byte[4096];
while((data = ins.read(buffer)) !=-1) {
baos.write(buffer);
ins.close();
response.setContentType("application/octet-stream");
response.setHeader("Content-Disposition","attachment; filename="+appName+";");
response.setContentLength(baos.size());
ServletOutputStream output = response.getOutputStream();
baos.writeTo(output);
baos.close();
output.close();
output.flush();
catch (Exception ex) {}
hvala za pomoc, jest sm ze obupal ;)
Spin
koda:
try {
try {
int data;
baos.write(buffer);
ins.close();
baos.close();
output.close();
output.flush();
Spin
kopernik ::
Zamenjaj vrstni red vrstic:
output.close();
output.flush();
Ko stream enkrat zapreš, je konec muzike...
output.close();
output.flush();
kopernik ::
hmm, tak exception dobis, ce veckrat pises na response (torej veckrat klices getOutputStream()). Ampak iz tvoje kode to ni razvidno. Tako da nimam pojma, zakaj dobis to napako. A je to vse? vsa koda, ki ima zvezo z response-om?
kopernik ::
A lahko poveš, katera vrstica vrže exception? A dobiš exception že tukaj:
sli kasneje pri pisanju ?
bboyspin ::
Ok, sm nekak pogruntu :)
Problem pr teh servletih je to, da ti jav to napako vedno ko mu kaj ni vsec, in u bistvu potem sploh ne ves kaj je narobe... Pr men mu ni bil vsec nacin kako sem klical servlet, tako da mi zdej nekako dela...
Spin
Spin
bboyspin ::
ok mam ze nov problem :)
Ko poklicem servlet za download mi dela vse lepo, dobim datoteko, samo potem po downloadu mi pa crknejo vsi linki? samo tisti v glavnem frejmu se delajo... mam pa zgornji in desni frame (menija) ter enega glavnega kjer se izpisujejo zadeve ... (dobil sem ze narejeno aplikacijo, drugace jest ne uporabljam frejmov ;) )
Spin
Spin
kopernik ::
Žal boš moral bolj natančno razložiti. Kam kažejo tisti linki? Je njihov cilj odvisen od parametrov? Kakšen mini proxy vmes, ki forwardira naprej? itd...
Problemov je lahko več - od napačnega refresha strani do kakšnega problema pri cache-iranju na servlet containerju. Aja, ko smo že pri tem. Kateri servlet container uporabljaš v JBOSSu? Ker vem, da JBOSS podpira različne containerje - Tomcat, Resin, itd... Osebno imam največ izkušenj s Tomcatom.
Čeprav niti ni logično, da pred downloadom linki delajo, po njem pa ne ... Čudne probleme maš
| » | [JAVA] HTTPS clientOddelek: Programiranje | 3684 (2414) | peterv6i |
| » | Jasper subreportOddelek: Programiranje | 2243 (1992) | nightrage |
| » | [java] Kako v memoriji pretvoriti String objekt v File objekt ? - neka metoda ga zahtOddelek: Programiranje | 2735 (2735) | infiniteLoop |
| » | [java] Runtime.exec()Oddelek: Programiranje | 2237 (2110) | borchi |
| » | Kako pošiljanje datotek v JAVI.Oddelek: Programiranje | 2233 (2104) | kopernik |
