vgradnja ssd v star prenosnik
ursula100075 ::
Pozdravljeni!
V star prenosnik HP ProBook 470 G3 bi namestila ssd disk v velikosti max 512 MB.
Je tale Samsung SSD disk 860 EVO 500 GB, 2,5, SATA3, V-NAND, MLC, 7mm kompatibilen.
Pri odprtju računalnika sem videla, da ni dodatne reže, torej moram odstraniti stari HDD - DVD še rabim.
Prosim za pomoč. Hvala.
PS. a se to sploh splača?
TOP ::
Ja odstrani hdd in ugradu ssd bo delalo,sam moraš sistem na novo.
_Denny_ ::
Ko sem videl "star", sem pričakoval nekaj med 2005 in 2010...ta zadeva je zelo daleč od tega.
Drugače pa je kompatibilno in se definitivno splača.
ursula100075 ::
Hvala.
Itak so se na disku zbrisali vsi programi, tako da bo verjetno manj dela z novim diskom, ker bo delal hitreje.
Vuli ::
bo,bo opazno hitreje.
Han ::
860 EVO je predrag in niti pod razno MLC. Enako dobra cenejša alternativa je Crucial MX500.
ursula100075 ::
pa je kompatibilen z mojim prenosnikom.
Prenosnik se uporablja za grafično risanje z autocad in solidworks.
Taip4n ::
Vsak SATA 2.5 inch disk je kompatibilen.
ST-777 ::
Han je izjavil:
860 EVO ima TLC, vendar ...
"... the MLC memory cells are reserved for the Pro version and the 860 EVO uses the cheaper TLC memory cells. This 3-bit triple-level cell flash (TLC) is generally slightly slower than 2-bit MLC memory. Wear is also slightly higher compared to MLC flash cells. However, the VNAND version of the TLC cells largely compensates for these disadvantages in terms of service life and robustness.
Like its predecessor, the 860 EVO uses an SLC (TurboWrite Cache) to compensate for the performance disadvantages of the TLC memory. Turbowrite capacity is dynamic, so it can be expanded according to demand and available residual capacity, which is why Samsung Turbowrite now calls it “intelligent”. This gives it a similar performance to the Samsung Pro series. Provided this cache is not full due to huge files. Then the write rate drops to a measly 300 MB per second, especially with the smaller models (250 & 500GB). In everyday private life, however, the cache seldom reaches its performance limits." https://www.datenreise.de/en/ssd-compar...
TOP ::
Han je izjavil:
Ja res je se nesplača,dat toliko več za Samsunga,ker razlike ne boš opazil.Vzemi Crucial še rajši pa WD.
Vzameš najcenejši SSD, ki ustreza, pa je.
Tako potem postane bottleneck ostali del hardwara...
Kingston, Sandisk, WD, Patriot, Apacer, Teamgroup ... pri nas dobiš 480 GB nekje od 50+ evrov, v tujini morda prišparaš nekaj evrov (ampak preveri poštnino).
WD 480 GB
https://funtech.si/si/vsi-oddelki/komp/...
https://www.mimovrste.com/ssd-diski/wd-...
Teamgroup 480 GB
https://www.mimovrste.com/ssd-diski/tea...
WD 500 GB
INTENSO 480 GB:
Glej, da bo hitrost pisanja in branja okoli 500 MB/s, raje prek.
SATA III vodilo omogoča okoli 600 MB/s.
  • spremenil: opeter ()
ursula100075 ::
Evo. Vgradila crucial in dela super.
Hvala za pomoc.
Super, to je dobra novica. Naj ti dobro služi!
Kateri SSD? (strani: 1 2 )
6710866 (2477) Han
Windows ob zagonu dela zelo počasi (strani: 1 2 )
5813098 (12070) oo7
Navaden ssd disk kot prenosni disk
253875 (2747) iloveboobz
Nakup ssd diska
187662 (7414) SSkruh
