Forum » Loža » Legalizacija prostitucije in erot. masaže
GrX ::
@tikitoki Dejstvo je, da ti ne veš še manj pa razumeš zakaj so se Skandinavci odločili za sistem, kot ga imajo. V prvi vrsti so želeli, da se zmanjša številko prostitutk na ulici, da se zmanjša trgovina z ljudmi in da se zmanjša nasilje nad ženskami. In mnoge raziskave prikimavajo, da je pač njihov sistem sorazmerno uspešen.
Seveda pa obstaja tudi skrita prostitucija, ampak ta vedno je in tudi vedno bo.
Ne moreš pa pričakovati da bo katerikoli sistem, probleme s prostitucijo popolnoma odpravil. To se ne bo zgodilo. Sem mislil, da nam je to jasno, ampak sem se učitno uštel.
Ocitno imas problem z razumevanjem prebranega, ker sem bil jasen, da je cip na cesti manj. To je pa tudi vse, kar se je zanesljivo spremenilo.
Zakaj pol jokaš?
Verjame tisto, kar želi, ne pa tudi tistega kar mu ni po godu. Precej klasično...
- spremenilo: GrX ()
In cudezno, karkoli preberes o tem zakonu, poudarjajo boge zenske, ki jih izkoriscajo grozni moski.
As demonstrated above, it is difficult to assess the evidence relating to the effects of the Swedish Sex Purchase Act. Governmental and NGO reports and research describe findings that can be interpreted in different ways. If one only looks at street prostitution, it is possible to conclude that the market has declined. If one only looks at the indoor market, it seems like the market has actually increased. Similarly, looking only at the finding that support for the law is strong and increased after the inception of the law, it appears that the law strengthened the perspective that clients should be made responsible for the existence of prostitution. But when also considering levels of support for criminalising the selling of sex, it appears that the intended aim of the law to redefine prostitution and ideas around who is to blame has not succeeded.
Does not sound like a resolute victory to me.
Ampak, ampak, cip na cesti je manj!
Kdo drug pa je bogi v tej panogi? Moški, ki jih izkorišajo, pretepajo in prodajajo? Verjetno ni treba poudarjati, da v prostituciji prevladuejo ženske.
Sedaj bos pa se enacil kupce z zvodniki?
Zakaj pol jokaš?
Je treba sam prebrati kaksno studijo, kjer jasno zakljucijo, da stvar ni niti priblizno tako uspesna, k predstavljate tukaj. In vzamete zgolj en podatek, ki vam godi, a ne?
- spremenilo: tikitoki ()
zmaugy ::
Hipatija: daj povej kaj je narobe v Avstriji. Zelo malo kriminala, prostitutke so samostojne podjetnice, opravljajo obvezne teste na predpisano obdobje, morda imajo še svoj sindikat (ne vem). Laufhausi vzamejo enih 100-150eur (kot sem bral), če dela pri njih, vse ostalo je njeno. Če gre za svobodno voljo, ne vidim problema. Nekatere premami zaslužek. Nekateri(e) ne marajo biti zlorabljeni v raznih težkih proizvodnjah in low plačanih delovnih mestih.
Aha. Ziher gre pri večini klasične prostitucuje za “svobodno voljo”./s
Kar pravi Hipatija ima po mojem smisel, saj se s tem pri ženskah, ki se s tem ukvarjajo, zmanjša potreba po “zaščiti” v obliki zvodnika, ker one ne počnejo ničesar ilegalnega, tveganje je na “strankah”, ki se naj zato rajši lepo obnašajo.
GrX ::
Kot sem napisal to počneš ti. Verjameš tisto kar ti paše, ne pa tudi tistega kar ti ne. Lep primer je tisti odstavka, kjer si bistvo namenoma odstranil.
In naj povem še enkrat, ker je bilo 5 krat očitno premalo. Na svetu NE obstaja model, ki bi prostitucijo in probleme, ki so povezani z njo popolnoma odpravil. Je pa vsekakor nordic model trenutno nabolj uspešen.
stara mama ::
je izjavil:
Mislim, da bi bilo pravico do sexa treba vpisati v ustavo. Podobno, kot smo vpisali pravico do pitne vode. A ne bi bilo lepo, če bi končno seksali vsi, ki si tega želijo??
Seks je izvor vseh problemov! Samo poglej, kaj počnejo feministke, ker ne dobijo seksa.
Pa kakšne probleme delajo (tudi nad ženskami) vsi prepotentni moški, ker ne dobijo seksa.
Ko se enkrat izprazneš, pa ni več nobene agresije nad nikomer.
In to naši forumski feministki ne gre v račun.
Ekologija™ in Trajnost™
hamez66 ::
In zakaj, da v primeru Avstrije ne gre za prostovoljno in svobodno odločitev?
Nekaterim se pač ne da delat. Vem, da bi se tudi moški na veliko prodajali, če bi bilo le povpraševanje dovolj visoko. Ampak živimo v taki družbi, ki se dela norca iz moških prostitutov in mislim, da bi morali biti tu bolj inkluzivni.
zmaugy ::
Jap, zato pa obstajajo ilegalni bordeli, kjer so ženske zaprte in jim vzamejo potne liste, da ne pobegnejo. Ker se imajo pri tem tako fino, verjetno./s
thetech ::
Bogi ste samo tisti, ki kupujete take nebuloze in vse verjamete. Zgodovina nas uči drugače.
Ojoj... Ti pa bolj malo veš. Verjetno še nisi slišal za ljudmi. Groza!
- spremenilo: thetech ()
CoolBits ::
Saj vem... v real life je še dosti huje, večina verjame tudi vsemu kar 24kur sproducira.
hamez66 ::
Vem, da je Avstrijc zaprl svoje otroke, za ilegalne bordele v Avstriji pa nisem slišal. Da bi recimo Slovenkam, Madžarkam, Romunkam in ostalim ukradli potni list in jo prisilili v prostitucijo. S kašnim razlogom bi to počel? še tle v Sloveniji so imele prosto pot, kamor so želele. Na območju je več policijskih postaj, kjer je možna pomoč, pa azil za ljudi brez potnega lista in tako naprej.
zmaugy ::
https://punchng.com/austria-arrests-two...
https://www.thelocal.at/tag/prostitution
http://www.lefoe.at/index.php/IBF.html
https://lightup-movement.at/human-traff...
- spremenilo: zmaugy ()
hamez66 ::
Aha se pravi eno sta počela 2 Nigerijca, pri drugem primeru je šlo za Kitajko, v tretjem primeru gre link za pomoč ženskam v stiski (s target groupom migrantske populacije, ampak to tu nima veze.. je pač samo link), in četrti link je pač nek link, neko mnenje.
Tko da ne vem na kaj točno si odgovarjal. Mogoče je to argument, da je ziher večina prisiljena v prostitucijo??
zmaugy ::
Zdaj si slišal, piše v linkih.
Če bi to bil tako super “poklic”, ne bi bilo treba nikogar prisiliti v to.
PS: Glede tvojega omenjanja, da gre itak za tujke/tujce, newsflash, večina prostitutk v Avstriji je iz držav vzhodnega bloka.
PPS: Za tisto, da gre samo za link, ne vem, če problematike ne bi bilo, verjetno tudi organizacija v Avstriji namenjena tej problematiki ne bi obstajala, kaj praviš?
thetech ::
WTF.. Tukaj ne gre za to kaj kdo sproducira, ampak za čista dejstva. Misliš, da mafija z ženskami marjetke nabira? Mislim to je pa groza, da nekdo misli, da je vse skupaj hec za na 24ur. Sramota
CoolBits ::
Ne, govoril sem o drugem in sicer to da bo narocnik raziskave vedno povedal kako naj zgleda na koncu.
Enako velja za to raziskavo.
hamez66 ::
Super. Torej v čem je prednost nelegalnih bordelov v primerjavi z legalnimi? Zakaj bi biznis, ki ga lahko opravljaš legalno, opravljal na nezakonit način? Na kakšen način avstrijska legalnost poslabšuje položaj žensk? Načeloma v legalnih bordelih ne morejo delati dekleta pod prisilo, al kako?
Sej ni poanta, da ne obstaja. Vprašanje je, zakaj je v primeru Avstrije drugače ali slabše. Pa kje so podatki, da pri večini ne gre za prostovoljno dejavnost?
- spremenilo: hamez66 ()
FormerUser ::
In kako bi to uveljavili v praksi? Z "enforsed monogamy" kot predlaga Peterson, ali s seksom na napotnico iz že tako prazne zdravstvene blagajne, ki bi hkrati pomenila še več zlorab in trgovine z ljudmi, ali morda kar s state run bordeli kot so jih imeli v tretjem rajhu in kamor bi se napotovalo ljudi iz Zavoda za brezposelne, da bi bili "družbeno koristni"?
Glede na to, da predvsem dedci jamrate nad pomanjkanjem, bo najbolje, da si med sabo pomagate, tako kot je Aleksander Veliki že davno priporočil svojim vojakom.
thetech ::
FormerUser ::
stara mama je izjavil:
Jaz predlagam preprostejšo rešitev, tiste, ki delajo probleme, se zapre v kletke, da na verige ali pa uspava, tako kot to počnemo z vsemi ostalimi zvermi, ki niso dovolj socializirane za življenje v skupnosti.
thetech ::
FormerUser je izjavil:
V razvitem svetu se tega ne počne..
CoolBits ::
Kako raziskavo? Si sploh dosleden? Poglej prejšnje poste..
Raziskavo o prostituciji na švedskem. Raje ti poglej na kateri post sem odgovarjal.
Nacistka! Kam te zapremo ali te uspavamo?
- spremenil: CoolBits ()
thetech ::
Aja res? https://slo-tech.com/forum/t744806/p632...
hamez66 ::
Ah to sem se samo hecal. Že pravico do pitne vode je težko udejaniti.
FormerUser ::
thetech ::
Pa bi se očitno moralo ker nasilje ne pojenja.
Z nasiljem se nasilja ne rešiš, celo obratno, potenciaš ga.
FormerUser ::
Zato ker lahko več zaslužiš, zato ker lahko prodajaš žrtve trgovine z ljudmi, zato ker lahko prostitutke bolj kontroliraš....
Načeloma v bordelih delajo tujke, ki niso same od sebe prišle v te države ampak imajo za sabo pimpe, ki so jih pripeljali.
thetech ::
Ne posploševati,nima vsaka prostitutka pimpa. Marsikatera ženska se za ta posel odloči popolnoma prostovoljno.
FormerUser ::
"Večina prostitucije v Sloveniji je po naših podatkih, po naših izkušnjah z ženskami, dekleti in tudi mladoletnicami, s katerimi delamo, zvodniške. Tudi ko ne govorimo o trgovini z ljudmi, govorimo o kaznivem dejanju zlorabe prostitucije. Zvodništvo je v Sloveniji kaznivo in s tem se absolutno strinjamo," dodaja in opozarja, da legalizacija hkrati v marsikateri državi prinese legalizacijo bordelov: "Tam imaš nekega šefa, ki na ta način služi denar. To se trenutno dogaja v Sloveniji s t. i. erotičnimi masažnimi saloni, ki so v resnici bordeli." (Polona Kovač, društvo Ključ)
Ena luštna zgodbica:
In his book A Primate's Memoir, Sapolsky studied the activities and lifestyle of the Forest Troop to explore the relationship between stress and disease. In typical baboon fashion, the males behaved badly, angling either to assume or maintain dominance with higher ranking males or engaging in bloody battles with lower ranking males, which often tried to overthrow the top baboon by striking tentative alliances with fellow underlings. Females were often harassed and attacked. Internecine feuds were routine. Through a heartbreaking twist of fate, the most aggressive males in the Forest Troop were wiped out. The males, which had taken to foraging in an open garbage pit adjacent to a tourist lodge, had contracted bovine tuberculosis, and most died between 1983 and 1986. Their deaths drastically changed the gender composition of the troop, more than doubling the ratio of females to males, and by 1986 troop behavior had changed considerably as well; males were significantly less aggressive.
- spremenilo: FormerUser ()
zmaugy ::
Poanta je v tem, da sem komentiral predpostavko o tem, da naj bi se ljudje odločali na podlagi svobodne volje za ta “poklic”. Tista Avstrija nima s tem nobene zveze.
Glede na to, koliko žensk je v to prisiljenih, bom sklepal, da to ni “poklic” s katerim se ženske ravno hočejo ukvarjati, za večino je ta “odločitev svobodne volje” tako “svobodna” kot ko ti prislonijo pištolo na glavo in od tebe zahtevajo denar. Imaš izbiro, lahko se odločiš tudi za metek v glavo, ampak začuda se nihče ne odloči tako.
Verjamem, da se v primeru prostitucije kakšen res minoren promil odloči iz resnične svobodne volje, mislim pa da je večina tako ali drugače prisiljenih v to.
Ker, če se vrnemo na Avstrijo, le zakaj je večina prostitutk iz drugih (revnejših) držav, zakaj se torej Avstrijke množično svobodno odločajo za drugačne poklice?
Do elaborate...
reeves ::
Tole bo najbrž kar 100%, ne le večina.
Prostitutka, ki se je sama odločila za tako pot, nima niti najmanjšega razloga ali želje, da bi iskala pomoč pri kakšnem društvu ali organih pregona in se vpisala v statistiko. To počnejo tiste, ki so v to prisiljene. Nekaterim uspe in zberejo pogum in se izpostavijo v zameno za rešitev iz pekla. Zato v statistiki tudi prevladuje zvodniška in prisilna prostitucija.
Prostovoljne prostitucije je več, kot bi si mislili. Ne vem pa katere je več.
hamez66 ::
Ja, sej zvodništvo obstaja, ampak trdit, da je več kot 99% (100% minus nekaj promilov - po zmaugiju) žensk v prostituciji pod prisilo, je butasto do amena. Npr. ena je opravljala felacijo za to, da je dobila službo v lekarni. Me zanima, na kakšen način jo je zvodnik prisilil in kako mu je odplačala.
Poleg tega se z višanjem ponujene cene zvišuje tudi število oseb, ki so pripravljene.
Pa kakšne probleme delajo (tudi nad ženskami) vsi prepotentni moški, ker ne dobijo seksa.Prepotentnim moškim se brez težav odpovemo, ker ste družbeno nekoristna golazen.
trdit, da je več kot 99% (100% minus nekaj promilov - po zmaugiju) žensk v prostituciji pod prisilo, je butasto do amenaNe, dejstvo je.
Poleg tega se z višanjem ponujene cene zvišuje tudi število oseb, ki so pripravljene.Definitivno, kapitalizem je nečloveška ideologija, ki jo je treba požgati.
- predlagalo izbris: hamez66 ()
hamez66 ::
Mirno lahko začnemo pri tebi. Se ti bomo smejali, ker si v imenu ideologije in osebne integritete svoje miljone razdelil pomoči potrebnim.
Kar pa seveda nima nobene veze s tem, da se veliko ljudi prostituira in da nekateri od tega odlično živijo in si privoščijo Gucci, delo v lekarni in podobno. Osebe, ki so daleč od tega, da bi se morale prodajat zaradi finančne stiske.
Se ti bomo smejali, ker si v imenu ideologije in osebne integritete svoje miljone razdelil pomoči potrebnim.Kar smejte se mi.
Kar pa seveda nima nobene veze s tem, da se veliko ljudi prostituira in da nekateri od tega odlično živijo in si privoščijo Gucci, delo v lekarni in podobno. Osebe, ki so daleč od tega, da bi se morale prodajat zaradi finančne stiske.Skratka, žrtve so krive, storilci so pa dobrodelneži, ki jim omogočajo boljše življenje?
Nacisti ste nepoboljšljivi.
hamez66 ::
Na koga se nanaša "nacisti ste" ter zakaj? Sklepam, da name, ampak bi bilo super, če malo boljbpodrobno razložiš.
Gagatronix ::
Aleksander Veliki je bil Makedonec, tako da ni varijante da bi predlagal, da bi se po Trojansko moski spolno zdruzevali med seboj.
Mimogrede, na Nizozemskem moskim invalidom na vozickih socialna pomoc omogoca obisk prostitutke enkrat na mesec na drzavne stroske. (Ti bom poudaril: OMOGOCA, ne predpisuje)
stara mama ::
A to je vse, kar zmoreš?
Čisti hipokrat: Vse premoženje je od vseh, razen moje je pa samo moje!
nejcek74 ::
Hipokrat? Tipičen kapitalist, dejstva niso pomembna, oznake pa, četudi so napačne
sakralizem
I mean
sekuralizem
ups
sarkazem
Gagatronix ::
@stara_mama: Hipokrat je bil Grk. Izraz, ki si ga ti iskal/a pa je hipokrit. Oziroma po slovensko hinavec. Ce ze ne znas tujih izrazov uporabi vsaj domace. Izpades manj neumna oseba.
Tarzan ::
Nekateri ne morete skapirat, da je prvi (in edini resen) problem prostitucije kriminal, ki je posledica dejstva, da je prostitucija nelegalna.
Če bi bila legalizirana bi se jo potegnilo iz parkljev kriminala, naenkrat trgovina z belim blagom več ne bi bila konkurenčna tistim, ki se s poslom bavijo legalno. Morebitne kriminalne in podobne združbe, ki pa bi še naprej delovale po starem modelu se bi pa po mojem dosti laže razbilo, na tak način, kot da so prostitutke inkognito in jih nihče niti ne vpraša če je vse v redu. Jaz bi jim dal pa še en skrit rdeč gumb, ki pokliče policijo, ki bi bil v prostoru, namenjenem prostituciji nujen. Na ta način bi bile zaščitene pred strankami in mogoče tudi morebitnim kriminalcem.
Najbolj v nos bi šla legalizacija po mojem prav organiziranem kriminalu. Pri nas ga je precej, tako da verjetno ne bomo nikoli legalizirali ne prostitucije niti indijske konoplje, pri kateri imam podobno mišljenje.
Nekateri ne morete skapirat, da je prvi (in edini resen) problem prostitucije kriminal, ki je posledica dejstva, da je prostitucija nelegalna.Strinjam se, da bi z legalizacijo prostitucije bilo _manj_ trpljenja med tistimi, ki so v prostitucijo prisiljene, ne strinjam se pa, da bi bilo v prostitucijo prisiljenih manj žensk. Da se prostitucija lahko legalizira, je najprej treba poskrbeti za spodoben univerzalen temeljni dohodek, ker potem ženske ne morejo biti prisiljene v prostitucijo - in ker so to najpogosteje ženske iz revnih držav, ki bežijo pred revščino in nasiljem, bi morali UTD uvesti za cel planet.
Potem pa lahko brez skrbi legaliziramo.
FormerUser ::
@Tarzan
Pojma nimaš o zadevi, bi rad pa drugim pametoval.
Problem prostitucije ni samo kriminal, ampak tudi psihične travme, SPB, poškodbe, odvisnosti, nasilje s strani strank ( primer: An anonymous caseworker for women trafficked in Ireland's sex trade, says that buyers are, "increasingly influenced by what they see in pornography," and "see violence in sex as the norm.").....
Nelegalna prostitucija bo vedno konkurenčnejša od legalne, saj omogoča večje zaslužke za organizatorje in nižje cene za uporabnike. In kot že nekajkrat povedano v tej temi in podkrepljeno s študijo, legalizacija ne zmanjšuje trgovine z ljudmi ampak jo povečuje.
bambam20 ::
Kakšne nižje cene? Cena se je skozi leta višala. Ni tukaj akcijski popustov. Danes so cene na nivoju avstrijskih in če ženska misli kaj zaslužit mora biti vizuelno privlačna, ker povprečne ženske niso zanimive, zato morajo pač te hodit v službo za drobiž.
GrX ::
Govora je o nelegalnih trgih v državah, kjer je prostirtucija legalizirana. Cene na nelegalnih trgih so občutno nižje, zato je za kupce bolj privlačen.
bambam20 ::
Nočni klubi po sloveniji , tisti, ki so še , vegetirajo, ker jih je spodneslo nudenje spolnih uslug po masažnih salonih in stanovanjih.
| ⊘ | Sejem erotike Celje 2018 (strani: 1 2 3 4 5 6 7 8 )Oddelek: Loža | 102027 (93780) | BigWhale |
| ⊘ | Poslanci dekriminalizirali prostitucijo (strani: 1 2 3 4 5 )Oddelek: Loža | 35413 (28970) | bluefish |
| ⊘ | Ljubljana prostitucija (strani: 1 2 )Oddelek: Loža | 87760 (54876) | donfilipo |
