Forum » Kaj kupiti » Gearbest nakupi in kuponi
Tomson ::
za Samebike LO26 26" električno kolo (699€ EU skladišče) so pravilne specifikacije, glede na teste: 10.4Ah (48V Li-ion baterija), 350W motor ...
Naletel na tale odziv uporabnika ter njegovo mnenje o kolesu, kako do navodil za sestavljanje, ki menda niso priložena ...
Hey friends, I found that if you type:
"LCD S830 Manual Control Panel User Manual" into Google you can download the manual for the bikes computer in pdf from the first link. I should also mention for y'all that the motor output is digitally limited for the UK (mine was anyway) but you can unlimit it, in terms of both max speed and acceleration, using the manual above.
The bike is bloody fantastic for me. But not without its drawbacks:
-the included pedals and mudguards are very cheap
-the cables and wires that run under the undercarriage of the frame get in the way of the battery's key opening while the bike is folded.
-the spokeless wheels have some flexibility to them, which is weird for some high speed harsh turns. You get used to it quickly anyway. Remember that having spokeless wheels is great for maintenance on the go as your hands and tools can get access without having to prop the bike on a stand.
-the front derailleur is actually the wrong shape for the bike. This is the only big problem with the thing as a product. Basically, the bike works fine in all but the very top 3/21 gears, in which the chain rubs on the derailleur. If you have some experience with this type of thing then it's not too hard to minimize the problem but it's very time consuming and, anyway, I'm not sure if any combination of derailleur positioning vs. gear cable tightening can fix this because I haven't invested the time to properly fix it. (The reason I haven't bothered is that those gears aren't really used much for me nor most cyclists).
Otherwise the bike is really great, and very well designed. I can't believe that you can pelt up a hill at 20mph with hardly any effort on it, and then fold it up and get on the fucking London tube. Great.
- spremenilo: Tomson ()
Tomson ::
uTorch UT30 Smart LED stropna luč s kodo: LIMITED062408 iz 26€ na 20€
Ulefone Power 6 EU Version 4/64GB pametni telefon s kodo: GBMPULEP6 iz 144€ na 127€
Lenovo Z6 Lite International 4/64GB pametni telefon v FlashSale za 161€
Vivo Y17 Global 4/128GB pametni telefon v FlashSale za 233€
UGOOS AM6 S922X TV Box Android 9.0 s kodo: GBCNUGAM6 iz 134€ na 107€
Q96 Smart Android 9 TV Box s kodo: GBCNQ9601 iz 22€ na 17€
AKKO 3068 Mechanical Keyboard Cherry Switch Retro s kodo: GB-CN27BLU iz 71€ na 62€
Beelink U55 i3 Mini PC s kodo: GBCNBLU55 iz 269€ na 263€
CADA C61006 Vehicle RC Block Toy 1941pcs igrača s kodo: GB$TH12CCA iz 107€ na 98€
Umper EZBook S4 14" prenosnik v FlashSale za 296€
Beyondsky Eyemind 2 Gimbal stabilizator s kodo: EYEMIND2 iz 70€ na 68€
Tomson ::
Oclean SE Sonic električna ščetka s kodo: GB-HBZOCASE iz 44€ na 40€
OClean Air Sonic električna ščetka s kodo: GB-HBZOCAAR iz 35€ na 32€
Xiaomi Mi Air 2019 13.3" prenosnik s kodo: GBNBXM02 iz 708€ na 699€
Xiaomi Redmi 7A Global 2/16GB pametni telefon v FlashSale za 69€
Xiaomi Redmi Note 7 Global 3/32GB pametni telefon v FlashSale za 125€
Xiaomi Redmi Note 7 Global 4/64GB pametni telefon v FlashSale za 146€
Xiaomi Mi Play Global 4/64GB pametni telefon v FlashSale za 102€
Creality3D Ender 3 3D tiskalnik s kodo: 6QQB3QASL0 iz 152€ na 143€
Vsi kuponi na enem mestu ...
Tomson ::
OnePlus 6T International pametni telefon s kodo: GBMP6T8128 iz 376€ na 358€
AlldoCube iPlay 10 Pro 10.1" Android tablica s kodo: GBTACUBE01 iz 98€ na 94€
AOC CQ27G1 27" Monitor Curved s kodo: GB-CN25CQ27G1 iz 385€ na 367€
Meizu EP52 Bluetooth slušalke s kodo: GBBELAPR15 iz 35€ na 32€
Akko Silent Mechanical Keyboard Cherry MX Switch s kodo: GB-CN3084AKKO iz 80€ na 71€
ZTE Blade A7 International 3/64GB pametni telefon v FlashSale za 116€
ZTE Blade V10 International 4/64GB pametni telefonv FlashSale za 170€
Alfawise A9X Android TV Box s kodo: 7CD7V1TS90 iz 53€ na 44€
Chuwi Hi9 Air 10.1" Android tablica s kodo: GBNB2X04 iz 166€ na 132€
Oclean SE Sonic električna ščetka s kodo: GB-HBZOCASE iz 44€ na 40€ (popr.URL)
Oclean Air Sonic električna ščetka s kodo: GB-HBZOCAAR iz 35€ na 32€ (popr.URL)
Roborock S50 robotski sesalnik v FlashSale za 340€
Kodak High Speed U3 A1 V30 MicroSD 512GB kartica s kodo: GB-CN31KON iz 80€ na 71€
Alfawise E202 Touchscreen Fingerprint pametna ključavnica s kodo: L3BFIGPR6V iz 116€ na 107€
Alfawise U20 Large 3D tiskalnik s kodo: GBU20SPL iz 247€ na 242€ (EU skladišče)
Xiaomi Populele 2 LED Bluetooth s kodo: GB$618UDE iz 103€ na 96€
MOC 6687 Cool 1:10 Sports Car Building Blocks 2.4G RC car s kodo: GB$TH99CSC iz 98€ na 87€
Xiaomi Mi A2 Global 4/64GB pametni telefon v FlashSale za 134€
Xiaomi Mi 9 Global 6/128GB pametni telefon v FlashSale za 363€
Teclast T20 10.1" Android tablica s kodo: GBDCT20ML iz 176€ na 157€
cypena ::
Mene pa zanima, če mi lahko kdo priporoči nek soliden Bluetooth zvočnik. Da dobro špila in dela ter da ni predrag. Budget recimo okoli 40 eur, cca.
Uporabljal bi ga večinoma v navezi s telefonom zunaj pred hišo ipd. Lahko je tudi malo večji, to ni problem. Prioriteta je dober zvok in solidna glasnost.
Hvala 😊
Hvala 😊
če seješ veter, boš po vsej verjetnosti požel vihar...
pa lep dan želim :)
pa lep dan želim :)
Skylord ::
Še tukaj, ker v namenski temi itak ni kobenih odgovorov.
Kateri 13"-14" prenosnik. Samo za tekoče brskanje po netu, kakšna malenkost na EONu, kakšen filmček, bolj za na teren in tam kjer ni možno dostopat do stacijonarnega pcja. Nobenih iger in zahtevnih programov.
Gledal sem kakšne rabljene HP EliteBook 840?
voltaire ::
Živ. Kupujem en robotski sesalnik. Gledal sem točno nekaj v rangu do 350€.
Ali je vredno dati 100 ali 150€ več? V čem se najbolj razlikujejo sesalniki, da pride do take razlike v ceni?
Zakaj je model S5 dražji od S6? Kateri od teh treh je najbolj zanesljiv in preverjen?
1:
https://www.gearbest.com/robot-vacuum/p...
2:
3:
Želje:
- naj bo relativno močen
- oddaljen dostop (ko sem v službi, nastavim na čiščenje po potrebi, LDS Lidar Sensor + SLAM Planned Cleaning)
- mokro čiščenje (nisem točno informiran, a če prav razumem je to za prostore kjer je veliko prahu, v mojem stanovanju je tega na prek in bi se ga rad znebil)
- možnost čiščenja kavča, ni pa nujno
Hvala za pomoč
1:
2:
3:
Želje:
Hvala za pomoč
Tomson ::
@cypena:
nekih blazno pametnih Bluetooth zvočnikov niti, dobra opcija je npr. Xiaomi Mi BT Speaker za 30€, če glasnost ni prioriteta, sicer pa močnejša alternativa na GB Tronsmart 40W za 39€ iz EU skladišča ...
@RokFeler:
že res dober 14" prenosnik je npr. Huawei MagicBook, če ti ni predrag:
- Huawei Honor MagicBook 14" prenosnik s kodo: GBNBMG01 iz 666€ na 657€
Če pa gledaš ceneje pa je zelo dober glede na ceno Chuwi AeroBook, 13.3", FHD IPS zaslon, m3-6Y30 CPU, 8GB RAM, 256GB SSD, Windows 10 ...
- Chuwi AeroBook 13.3" prenosnik za 385€
Sicer pa je omenjeni HP EliteBook 840 odličen prenosnik overall, če najdeš rabljenega za dobro ceno je to to! ;)
@voltaire:
razlik med robotskimi sesalniki, tako naslošno, je kar nekaj. Na prvem mestu, kot smo že vajeni, znamka. Potem pa kvaliteta materialov, izdelave, dizajn, sesalna moč, število in vrsta vgrajenih senzorjev, posledično algoritem čiščenja ki vpliva na hitrost in učinkovitost čiščenja, načrtovanja in premikanja po prostoru, možnost mokrega čiščenja, nadzor preko aplikacije, glasnost in hitrost čiščenja ... Jasno, nekatere lastosti so pomembnejše, a overall, s ceno vse skupaj narašča, zmogljivejši in učinkovitejši sesalnik, boljša uporabniška izkušnja.
V omenjenem cenovnem rangu so najboljše opcije:
- 360 S6 robotski sesalnik s kodo: GB-AP360S6 iz 298€ na 271€
to je glede na ceno, kvaliteto, učinkovitost in funkcionalnost bestbuy robotski sesalnik na trgu. Praktično na nivoju Roborocks S50, a z nižjo ceno. Lahko si preberš test in primerjavo.
Model S5 je v osnovi nekaj deset € cenejši, a trenutno ni FlashSale cena, bo kmalu spet nižja cena, v primerjavi s S6 modelom pa ima rahlo višjo sesalno moč a brez funkcije mokrega čiščenja, ki je vsaj zame ultra uporabna zadeva, tako da osebno predlagam kar S6 model.
Roborock S50 je izjemno podoben 360 S6 modelu, tako po kvalitetu, dizajnu, funkcionalnosti, učinkovitosti čiščenja, je le model od drugega proizvajalca in sicer velja za enega najboljših robotskih sesalnikov na trgu. V povezavi zgoraj pa razlike med 360 S6 in Roborock S50.
- Roborock S50 robotski sesalnik v FlashSale za 340€
Na možnost čiščenja kavča pozabi, za to niso robotski sesalniki, potrebuješ klasičen ali baterijski sesalnik. Za vse ostalo kot navajaš pa sta omenjea modela odlična, z nobenim ne boš zgrešil, oba imata najsodobnejšo tehnologijo, sta izjemno učinkovita, sam že dolgo časa uporabljam oba in ju lahko samo pohvalim.
@RokFeler:
@voltaire:
darkolord ::
Tomson: pri primerjavi med S50 in S6 bi bilo mogoče dobro poudariti še eno stvar - pri S50 se prah nabira direkt na HEPA filtru, kar pomeni, da ga je treba pogosto čistiti, medtem ko ima S6 trojno filtracijo in se praktično ves prah ustavi že na mrežici pred HEPA filtrom. Na se to lepo vidi.
Meni se to zdi omembe vredna prednost.
valdo ::
Nwm,
leva slika je od S50, desna je od S6,
meni se zdi, v primeru na levi lažje za odstrani umazanija?
Tomson ::
Na levi je 360 S6, na desni strani pa Roborock S50. Težko rečem da je v praksi kakšna huda razlika kolikor imam v spominu, lahko danes zvečer preverim pri obeh modelih in sporočim ...
Danes dobra cena za Xiaomi Wemax One Pro Android video projektor:
- Xiaomi Wemax One laserski vodeo projektor s kodo: WENMAX iz 1695€ na 1614€
jopar ::
Thomson, danes sem iz GB prejel mi9, ki pa ima bel stuck pixel. Kakšne so možnosti? Je pa zelo moteče, ker je viden tudi na črnem ozadju. Na support sem že pisal in priložil fotko.
Tomson ::
@jopar:
se bo uredilo da ga zamenjajo, če se jasno vidi napaka. Prvi korak si že opravil, če bodo težave sporoči, bom preko svojega kontakta pomagal, da se naredi zamenjava ...
Še nekaj današnjih:
Mechrevo S1 Pro Laptop 14.0" prenosnik s kodo: GBNBS1PRO01 iz 681€ na 627€
uTorch UT30 LED pametna luč s kodo: GDUT30JK iz 26€ na 24€ (EU skladišče)
Beelink J45 Mini PC s kodo: GBCNJ45128 iz 260€ na 206€
Huion GT - 156 Digital Panel 15.6" tablica s kodo: GB-CN26HUI iz 280€ na 269€
Vivibright F30UP Android video projektor s kodo: ZV9UC2NRBP iz 197€ na 188€
Oclean X Smart Sonic električna ščetka s kodo: GB-HBZOCLEAX iz 62€ na 50€
Nova3D Bene 3 Air 3D tiskalnik s kodo: L00BVCNFBV iz 358€ na 341€
Xiaomi Wemax One laserski vodeo projektor s kodo: 24HFIMIX8 iz 447€ na 357€
Še nekaj današnjih:
cypena ::
@cypena:
Tomson, hvala za predlog.
Nekaj podobnega Xiaomiju že imam, zato si ogledujem močnejšega Tronsmarta.
pa lep dan želim :)
pa lep dan želim :)
Tomson ::
@mattt:
sam bi izbiral med Xiaomi Mi AirDots, Xiaomi Redmi AirDots, QCY T2C in Alfawise V6 TWS modeli. Alfawise je npr. najcenejši, nekateri pravijo da je boljši kot Xiaomi model ...
@brkavi:
Xiaomi Mi 9T Pro je enak model, v Globalni verziji z B20 LTE, a zaenkrat ga še ni. Redmi K20 Pro sem videl da je na Aliju (CN verzija), a je kot omenjeno brez B20 ... K20 Pro bo širše dobavljiv v mesecu juliju, Global verzija, se pravi model Mi 9T Pro pa do konca poletja. Zaenkrat je na voljo navaden (ne Pro) Xiaomi Mi 9T Global model:
- Xiaomi Mi 9T Global 6/64GB pametni telefon za 329€
@brkavi:
jopar ::
@jopar:
So mi ponudili:
1. Da pošljem telefon v Španijo. Takoj ko prejmejo mi pošljejo novega. Predvidevam, da iz Kitajske in ne Španije?
2. Vrnejo kupnino. To bi bilo še boljša izbira, ker je v tem času cena padla.
V vsakem primeru bom en mesec brez telefona, razen če pošiljajo v takih primerih (pod točko 1) iz Španije?
Pa ravno, pred dopustom, ko človek rabi malo boljši fotič :S
Je možno, da telefon zaradi te napake npr pošljem nazaj čez en mesec?
Killermode ::
@jopar:
So mi ponudili:
Verjetno se bi dalo, vendar se nebi čudil če bi ti kitajci v tem primeru vrnili samo sorazmeren delež vrednosti telefona in ne celote.
Tomson ::
@jopar:
preverim še preko svojega kanala, kakšne bi bile najboljše opcije ...
Xiaomi Mi Band 4 pametna zapestnica s kodo: GBXMSH3149 iz 31€ na 28€
Alfawise AR182 18000Pa baterijski sesalnik s kodo: FAST2341339A iz 116€ na 107€ (EU skladišče)
Xiaomi Notebook Pro i7/16/256GB/GTX1050Q 15.6" prenosnik s kodo: GBNBXM04 iz 1076€ na 1049€
Xiaomi Notebook Pro i7/16/256GB/MX250 15.6" prenosnik s kodo: GBNGXM05 iz 923€ na 914€
Xiaomi TYY01ZM DLP 3500 video projektor s kodo: QY1XU50L34 iz 627€ na 556€
Xiaomi Amazfit Verge Lite pametna ura s kodo: NE5JROKP2H iz 89€ na 78€
Tomson ::
Gocomma G63H 4K GPS Dash Cam avto kamera s kodo: GBSZ9201 iz 69€ na 62€
Gocomma 910G elektronska tlačilka/pumpa s kodo: AMXP910G iz 30€ na 27€
2x Gocomma 10W QI Wireless avto nastavek brezžični polnilec s kodo: GBDEAL123 iz 11€ na 10€
Alfawise Handheld Mini električna tlačilka/pumpa s kodo: GBSZ4901 iz 26€ na 24€
Beelink GT Mini Android TV Box v SuperDeals za 62€
Acute Angle AA - B4 Mini PC v SuperDeals za 146€
Akku Silent Cherry MX Switch mehanska tipkovnica s kodo: GB-CN3084AKKO iz 80€ na 71€
Xiaomi Wemax One Pro laserski video projektor s kodo: WENMAX iz 1695€ na 1646€
Creality CR - 10S Pro 3D tiskalnik s kodo: T06SEHWUVX iz 529€ na 511€
Yeelight YLXD10YL Smart Square LED stropna luč v SuperDeals za 86€
Yeelight Nox Round Diamnod LED Smart stropna luč v SuperDeals za 62€
Alfawise V8S SLAM robotski sesalnik v SuperDeals za 121€ (EU skladišče)
Huawei P30 Lite Global pametni telefon v SuperDeals za 287€
Tanix TX85 Mini PC v SuperDeals za 95€
Xiaomi Mi 9 SE Global 6/64GB pametni telefon v FlashSales za 251€
Xiaomi Mi 9 Global 6/128GB pametni telefon v SuperDeals za 351€
OnePlus 7 International 8/256GB pametni telefon v FlashSale za 439€
Xiaomi Mi 9T Global 6/64GB pametni telefon v SuperDeals za 329€
Xiaomi Mi 9T Global 6/128GB pametni telefon v SuperDeals za 356€
Izak ::
Na tem linku odpre Lite verzijo (Xiaomi Mi A2 Lite Global Version 4G Phablet - Black). Je to Android One phone, torej brez MUIU? Kupujem nekaj za brata, pogoj sta čim boljša baterija in ne prevelik ekran. Android One je malo manj zahteven od MUIU, zato se mi zdi idealen zanj. Priority line še vedno pride brez carine? Ima Slovenščino? Hvala.
Tomson ::
Drži, gre za Lite verzijo, kot je razvidno na povezavi (napaka pri nazivu). Operacijski sistem je Android One (9.0), kar pomeni najbolj čist Android OS in z najboljšo podporo direktno od Googla, brez MIUIja. Glede na preference bo tole super opcija, je res odličen telefon za ceno overall. Drži, Prioirty Line, cena končna, brez dodatnih stroškov, vsi Xiaomi Global telefoni imajo slovenščino ...
Tomson ::
OnePlus 7 International 8/256GB pametni telefon s kodo: GBMPOP7256 iz 439€ na 430€
Xiaomi Mi 9 Global 6/64GB pametni telefon s kodo: GBM9664B iz 367€ na 334€
Eachlink H6 Max Android 9.0 TV Box s kodo: GBCNH6MAX iz 53€ na 34€
Xiaomi Redmi AirDots Bluetooth slušalki s kodo: GBREDMI001 iz 20€ na 17€
Xiaomi Amazfit Verge Lite Global pametna ura s kodo: NE5JROKP2H iz 89€ na 78€
Bosch GBM340 električni vrtalnik s kodo: P8B6I3DZIJ iz 46€ na 43€
Zanmax R1 Smart Self Balancing Scooter JP s kodo: LIMITED062715 iz 193€ na 116€
Gocomma Multifunction kolesarska lučka/zvočnik s kodo: LIMITED062716 iz 32€ na 22€
uTorch UT30 Smart LED stropna luč s kodo: LIMITED062710 iz 26€ na 19€ (EU skladišče)
Utorch 4" 10W LED Smart vgradna lučka s kodo: LIMITED062713 iz 16€ na 9€
Mega Motion E1 Hoverboard 6.5 Self Balancing Scooter s kodo: Q3020CBBC258D001 iz 160€ na 140€
Samebike YINYU14 Smart Folding električno kolo s kodo: T302242C6AE1D001 iz 420€ na 358€ (EU skladišče)
INQMEGA HD 1080P Cloud IP kamera s kodo: P3043F6A5E18D001 iz 22€ na 18€
Xiaomi M365 električni skiro v FlashSale za 358€ (EU skladišče)
Teclast A10S 10.1" Android tablica s kodo: TEL10SML iz 99€ na 80€
Nitecore NU25 360lm LED naglavna svetilka s kodo: NITECORE0621 iz 26€ na 23€
Tomson ::
Xiaomi Mi 9T Global 6/64GB Black pametni telefon s kodo: MI9T64BLACK iz 329€ na 287€
Xiaomi Mi 9T Global 6/64GB Blue pametni telefon s kodo: MI9T64BLUE iz 329€ na 287€
Xiaomi Mi 9T Global 6/128GB Black pametni telefon s kodo: MI9T128BLACK iz 354€ na 322€
Xiaomi Mi 9T Global 6/128GB Blue pametni telefon s kodo: MI9T128BLUE iz 354€ na 322€
Tomson ::
Xiaomi Redmi 7A Global 2/16GB pametni telefon s kodo: GB7A167999 iz 98€ na 71€
Xiaomi Redmi 7A Global 2/32GB pametni telefon s kodo: GB7A328999 iz 107€ na 80€
Alfawise A80 video projektor s kodo: U6E86G9YGI iz 79€ na 73€
Alfawise U30 3D tiskalnik s kodo: ALFAU308 iz 161€ na 152€
Xiaomi FiMi A3 RC Drone s kodo: GBFIMIA3 iz 268€ na 242€
Alfawise M1 električni skiro s kodo: WEEKENDONLY1 iz 304€ na 278€
Alfawise WS960 robotski čistilec oken s kodo: GBAF234309 iz 161€ na 152€ (EU skladišče)
Tomson ::
Martrea Acute Angel AA Mini PC s kodo: MINIMACHINE1 iz 179€ na 152€
Philips Zhirui Smart LED E14 žarnica s kodo: PHILIPSDEAL iz 12€ na 8€
uTorch C12 kolesarska lučka s kodo: WEEKENDONLY2 iz 12€ na 8€
Asus MB16 IPS 15.6" prenosni monitor s kodo: GBCNMB16AP iz 340€ na 331€
AlldoCube nuVision 2v1 11.6" Win10 tablica s tipkovnico s kodo: ALDONU21 iz 206€ na 197€
gocomma Pedal High Pressure Air Pump tlačilka s kodo: WEEKENDONLY3 iz 32€ na 26€
Alfawise G70 F1.5 Car 1080p avto kamera s kodo: MAG70BPT iz 38€ na 36€
Alfawise P1 HEPA čistilec zraka s kodo: GBHS062801 iz 40€ na 26€
Gregex ::
Tole je chinese version in verjetno potem nima ang jezika?
Tomson ::
Drži, ni Global/International verzija, pod FAQ piše: it supports Chinese and English. Predvidevam, nisem pa prepričan, lahko jutri preverim, da če je telefon v ANG bo jezik ANG, sicer pa verjetno CN ...
Tomson ::
Najugodneje na Gearbest, za 131€, a dostava nekje 2tedna ...
- Xiaomi Amazfit Stratos pametna ura za 131€ (akcija v košarici, +0.57€ PrioirtyLine)
Najhitreje iz kakšnega EU/Slo skladišča:
- Xiaomi Amazfit Stratos pametna ura za 141€ (EU Spain, 1-5dni dostava, +4.70€)
- Xiaomi Amazfit Stratos pametna ura za 159€ (Slo, 2-3 dni dostava, +0€)
Tomson ::
Xiaomi X8 SE 4k GPS RC Drone s kodo: 24HFIMIX8 iz 447€ na 374€
Yeelight Smart Square LED stropna luč v akciji za 87€ (-2.5€ v košarici)
vrossi46 ::
Pozdravljeni,
katere slušalke (air dots) do nekje 50€ bi priporočali ?
Hvala !
Tele pravijo da so izredno dobre
https://www.gearbest.com/bluetooth-head...
Kaj praviš Tomson?
Tomson ::
Res je, tudi model od Xiaomija v ozadju pravzaprav, tudi na Amazonu imajo precej dobro oceno kupcev, le za ShipOut bi moral preverit, če bo kaj prej ...
Današnje kode:
Beelink J45 Mini PC s kodo: GBCNJ45128 iz 278€ na 206€
Beelink L55 Mini PC s kodo: GBCNBKL55 iz 331€ na 262€
Utorch Sofirn 6000lm LED ročna svetilka s kodo: GDSP36ZW iz 43€ na 39€
JJRC X8 1080p RC Drone s kodo: GBJJRCX83B iz 179€ na 164€
uTorch UT31 36W LED stropna luč s kodo: GDXPUT31 iz 27€ na 25€
Colorful Geforce GTX1060 Mini OC grafična s kodo: GBCNGTX1060 iz 152€ na 134€
360 S6 1800Pa SLAM robotski sesalnik v FlashSale za 290€ (EU skladišče)
Teclast F15 15.6" prenosnik v FlashSale za 360€
Xiaomi Mi Band 4 pametna zapestnica v FlashSale za 28€
Xiaomi Redmi Note 7 Global 3/32GB pametni telefon v FlashSale za 130€
Yeelight Yilai 480 Simple LED stropna luč v FlashSale za 53€
Xiaomi Amazfit Bip Lite pametna ura v FlashSale za 49€
Teclast Master T10 10.1" Android tablica v FlashSale za 140€
Današnje kode:
Tomson ::
Xiaomi Mi Notebook Pro i5/8/256GB 15.6" prenosnik s kodo: GBNBXM01 iz 744€ na 735€
Xiaomi Mi Air i5/8/256GB 13.3" prenosnik s kodo: GBNBXM01 iz 708€ na 699€
360 OralCleen T1 Sonic električna ščetka s kodo: GB-HBZTH360 iz 35€ na 33€
BeamDay SB-6082 2v1 Ultraviolet lučka in lopar za komarje s kodo: GDBDSBMM iz 40€ na 27€
Xiaomi 8S SE 4k GPS RC Drone s kodo: 24HFIMIX8 iz 559€ na 374€
uTorch UT30 Smart LED stropna luč s kodo: GDUT30JK iz 27€ na 24€ (EU skladišče)
Alfawise U30 TouchScreen 3D tiskalnik s kodo: GBMAYU30Q iz 161€ na 157€
Alfawise X1 7.8Ah električno kolo s kodo: ALFAWISEX1S iz 430€ na 418€
Alfawise X1 10.4Ah električno kolo s kodo: ALFAWISEX1U iz 457€ na 444€
Xiaomi Mi 9 SE Global 6/64GB pametni telefon v FlashSale za 251€
Xiaomi Zaofeng Automatic Waterproof šotor za 3-4 osebe s kodo: IL610GOOD iz 78€ na 68€
Akko Ducky Game Cherry Switch mehanska tipkovnica s kodo: GB-CN29KAK iz 61€ na 59€
Mechrevo S1 Pro i5/8/512GB 14.0" prenosnik s kodo: GBNBS1PRO01 iz 681€ na 627€
scipascapa ::
a ti novi USB 3-0 type-C ne pašejo v klasične USB 3-0 vhode? potem bo treba kak adapter vzeti? je kaj takega? :)
Lurker22 ::
Eno vprašanje glede UTorch LED luči - kako se pritrdijo? a jih je potrebno fiksno pričvrstit z vijaki ali je kakšna opcija z nalepko ali kako drugače? Rabim namreč "netrajno" opcijo.
Hvala
Hvala
NejcSSD ::
Seveda da z vijaki. Pokitaš in pobeliš pa je :)
PC : MAG B550 Tomahawk, Ryzen 5600X, 32Gb 3200Mhz CL16, 2x 1TB NVME, MSI 1070Ti
Tomson ::
@scipascapa:
glede na prilagodljivo širino 55-100m lahko uporabiš za skoraj vsak telefon ... Med USB3 in USB Type-C je velika razlika že v velikosti in obliki, tako da potrebuješ adapter, so vse vse smeri, dobiš za drobiž ...
@Filip8:
pri teh poceni strižnikih za lase, mislim da ne bo bistvene razlike če kupiš v Slo kakšen poceni model (Hofer, Lidl) ima vsake toliko poceni modele (10-20€), od cenejših so drugače Kemei modeli kar ok, a kot gledam imajo na GB trenutno precej slabo zalogo, preveri na AE ...
@Lurker22:
vedno je opcija PataFix ali močnejše PataFix Pro, načeloma precej solidno držijo, razen če popustijo! ;) je pa strop, ker ni povsem gladka površina malo manj ugoden, ne vem, narediš poizkus s kakšnim drugim predmetom za kakšen dan, pa vidiš kako se obnese ...
@Filip8:
@Lurker22:
Nikar. Ker kakšen dan drži, potem pa čez dva tedna ali tri mesece dol pade, po možnosti komu na glavo.
Killermode ::
Tomson ::
Xiaomi Mi 9T Global 6/64GB Black pametni telefon s kodo: MI9T64BLACK iz 326€ na 284€
Xiaomi Mi 9T Global 6/128GB Black pametni telefon s kodo: MI9T128BLACK iz 350€ na 319€
Xiaomi Mi 9T Global 6/128GB Blue pametni telefon s kodo: MI9T128BLUE iz 350€ na 319€
Xiaomi Amazfit Verge Lite pametna ura s kodo: NE5JROKP2H iz 88€ na 78€
MoreFine S100 Game Mini PC s kodo: GBCNMF01 iz 392€ na 352€
rimljan ::
Hvala
pri Utorch lučeh (UT30, UT31 ) vzami v zakup, da se nastavitev barve svetlobe, ne shrani...ko prizges in ugasnes luč
rimljan
SubOrbit ::
Kakšna pa je default nastavitev toplote?
Kaj pa brightness, se shrani?
- spremenilo: SubOrbit ()
Opkow ::
Imam Utorch UT31 in si zapomne.
Nastavitev se spremeni, ce na hitro prizges in ugasnes preko stenskega stikala. Se pa spreminja od hladno bele, preko nevtralne, do tople rumene. Od oka 6000 K, 4500 K in 3000 K. Feature, ce ne uporabljas daljinca. Ce gori dalj casa in jo ugasnes, si zapomne trenutno stanje.
Brightness se spreminja preko daljinca, ce ga kupis v kompletu.
Heh. Sem sedaj hotel preverit, kako se spreminja barva svetlobe preko stikala. Jo prizgem in na hitrco bliskne in tema. Probal parkrat, tudi preko daljinca in nic. Izdihnila po priblizno mescu in pol uporabe. Zdaj pa odmontirat dol preverit, kaj je slo in odpirat ticket na GB. Sigh...
- spremenilo: Opkow ()
Tomson ::
Najprej preveri kontakte, meni se je podobno zgodilo na Yeelight, pa na koncu le žice niso bile dovolj globoko in so izgubile kontakt ... Da bi po mesecu odpovedala je pa malo prehitro, ni pa nemogoče ...
Opkow ::
Hvala Tomson.
Nekaj bo res na kontaktih. Odsrafal dol, da je visela na zici, razrukal kontakte in sedaj dela. Bom naslednje dni preveril, kje tocno je problem in ce bo potrebno zadevo modificiral, da ne bom naslednjic spet telovadil.
Se pa zadeva preko stenskega stikala spreminja 4-stopenjsko. Od 100 % hladne, 100 % Rumene in od oka 50-70 % nevtralne (tukaj gorita tako hladna kot topla ledica. S kombinacijo svetilnostih tehdveh ledic se spreminja temperatura svetlobe) in nevtralna takoimenovana midnight svetloba, kjer obe skupini ledic gorijo na minimumu.
Preko daljinca, pa imas se kup vmesnih variant.
