Forum » Sedem umetnosti » Star Wars 2021-??? (nova trilogija)
Star Wars: Disney announces new trilogy
It will be set in a different corner of the universe to the original saga
Disney has entrusted The Last Jedi director Rian Johnson with a brand new Star Wars trilogy.
The company’s CEO, Bob Iger, revealed that the writer-director Rian Johnson will tackle the new films, which will feature completely new characters in “a corner of the galaxy that Star Wars lore has never before explored”.
https://www.theguardian.com/film/2017/n...
Se pravi naj bi šlo nekako tako
2015 Star Wars: Episode VII
2016 Rogue One (Star Wars)
2017 Star Wars: Episode VIII (delovno ime Space Bear)
2018 Star wars: Han Solo
2019 Star Wars: The Rise of Skywalker [Episode IX] (2019)
2020 Star wars - Obi-Wan Kenobi - Serija
2021 naj bi se potem začela nova triologija ?
2022 samostojen film
2023 drugi del nove triologije
2024 samostojen film
2025 zadnji del nove triologije
Starodavni ::
Prava molža franšize.
Iz principa ne dam niti centa več za te filme z ogledom v kinu.
Samo še kot izposoja.
vostok_1 ::
BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOORING
(pa sem le potrošu nekaj bajtov)
There will be chutes!
It came from the lab.
- predlagal izbris: Tilen ()
FTad ::
Meni sicer ok, ce bodo filmi vsaj na nivoju Rogue One. Sicer bi pa raje videl, da naredijo vsaj en spin off film obdobja the Old Republic.
Starodavni je izjavil:
Kaj ti si mislil da bo Disney franžizo kupil za 4 miljarde $ zato, da bojo sedeli na pravicah in z njimi ne bojo delali nic?
Hvala bogu, da je tako. Naj naredijo čim več spin offov, SW vesolje ima ogromen potencial.
Lucas se je obnašak kot lastnik največega najdišča surove nafte ki je noče črpati ampak samo sedi na njej.
- spremenil: Zmajc ()
bambam20 ::
LUcas je zadevo prodal in mislim, da on nima pri tem več nobene pravice.
Ustanovil je "Jedi Academy", a je šlo vse v franže...
A ni Luke prestopil na črno stran?
- spremenilo: bambam20 ()
Starodavni ::
Od 7 dela SW dalje je šla ta franšiza samo navzdol. Kvaliteta nikakršna, sam reciklaža starih idej, da ne govorim da so EUniverse izbrisali kratkomalo in je postal nekanoničen.
Materiala je SW imel ogromno, ampak ne, so morali vse zmrcvariti in spremeniti v sranje za širše mase ljudi.
Rogue One in vmesni filmi so pa svoje pokazali, kako mislijo tole franšizo razvijati in zmolst na račun kvalitete.
Jaz tega propadanja ne podprem več in bom raje izposojal te zadeve, če bom hotel gledat, kot pa da zapravljam denar.
- spremenil: Starodavni ()
Kar je seveda tvoje subjektivno mnenje in ne fakt. Ogromno SW fanom so novi filmi ...*shock* .. všeč.
Vsakemu svoje.
Vsakemu svoje.
petrus ::
Best case scenarij filmov:
2021 Star Wars Dark Forces
2022 Jedi Knight Dark Forces II
2023 Jedi Knight Mysteries of the Sith
2024 Jedi Knight II: Jedi Outcast
2025 Star Wars Jedi Knight: Jedi Academy
stati inu obstati
gusto ::
Čar takšnih filmov je, da jih ni kot listja in trave, ampak moraš na naslednji del tudi nekaj čakati. To kot po pravilu pomeni tudi kvalitetnejši, bolj premišljen in dodelan izdelek.
Podobno je tudi recimo z igrami, cod in nfs iger je kot smeti, zato imajo igre, ki izhajajo na nekaj let (npr. gta) veliko večji čar.
Seveda pa danes vsi gledajo samo še iz $$$ vidika, jebe se jim za neko kvaliteto/umetniško vrednost.
bambam20 ::
Hudooo ...
Kot so na RTV-ju pisali komentarji, ima Disney materiala za nekaj sto let ...
- spremenil: opeter ()
Nikec3 ::
Dokler vztrajajo pri enem filmu na leto imajo mojo popolno podporo. Nočem pa da postane kot Marvel franšiza, ki ima na vsake 3 mesece nov film.
Sicer pa se bo nova trilogija dogajala v drugem delu Galaksije, tako da pričakujem povsem novo zgodbo, z novimi karakterji.
@WarpedOne o Elonu Musku:
FTad ::
Upam, da ni Rian Johnson zraven. Potem bo mogoče še okej.
Ahiles ::
Še večji problem je ker nej bi novo trilogijo delala David Benioff and D. B. Weiss ki sta pokopala Game of throne brez podlage iz knjig. In se je pokazalo da sta totalna debila.
Tko da ja ne pričakov ničesar dobrega.
- spremenilo: Ahiles ()
Han ::
Gnili paradajzi so pred dvema dnevoma izpljunili naslednji povzetek:
https://editorial.rottentomatoes.com/ar...
Netrunner ::
Zaradi mene lahko posnamejo vsako leto novo trilogijo. Miki miška je ubila star wars.
Zelo zelo slabe novice
Rian Johnson's Star Wars trilogy is still happening
https://www.gamesradar.com/rian-johnson...
Danes so napovedali tri nove Star Wars filme.
James Mangold (Logan, Indiana Jones, Ford v Ferrari) bo režiral film o prvem Jediju. Film se bo dogajal še pred Old Republic Eri torej več kot 3000 let pred dogodki iz filma A New Hope.
Dave Filoni bo režiral film povezan direktno s TV serijo Mandalorian.
Sharmeen Obaid-Chinoy bo režirala film kateri se bo dogajal 15 let po filmu The Rise of Skywalker. Vrnila se bo Daisy Ridley in zopet zaigrala v vlogi Rey.
Tako lepo se je začel tvoj post. Potem pa na koncu woke woke-woke, blah. Naj raje zbrišejo zadnjo trilogijo iz canona in jo ponovno posnamejo, kot da snemajo nadaljevanje.
Taika Waititi bo tudi režiral in spisal en Star wars film. Kar je naredil z zadnjima dvema Thor filmoma nimam veliko upanja.
Vsi trije filmi bodo woke tu sploh ni dvoma.
Komaj zdaj sem videl ta video:
https://www.imdb.com/video/vi3389768729/
svecka ::
Naj bi vzel lore iz iger Knight of the old republic pa bi blo zanimivo. Ne pa eno in isto fake Jedi Ray gledat. PRav bedno. Niti enga ne bomo šli v kino gledat.
Upcoming Star Wars Film Focused On Rey Will See Her Train A Female Apprentice "Destined To Emerge As The Future Leader"
https://boundingintocomics.com/2023/06/...
Zanimivo fantaziranje, kaj bi bilo, če ..?
Star Wars film kateri se bo dogajal 25 000 let v preteklosti naj bi sei menoval Jedi Prime ali pa je to samo delovno ime.
Simon Emanuel hints at a thrilling new title for the upcoming Star Wars movie, potentially revealing the origin of the Jedi Order.
Sharmeen Obaid-Chinoy Claims Rey Skywalker Is The Heart Of Star Wars And Implies Film Will Continue To Inject Feminism Into Star Wars
https://thatparkplace.com/sharmeen-obai...
Še en Star Wars projekt narejen osebno za Kathleen Kenedy
2dark ::
Še en Star Wars projekt narejen osebno za Kathleen Kenedy![]()
KOga briga. Franšiza je že zdavnaj umrla.
(\___/)
(> _ <)
(> _ <)
2dark ::
Nisem fan, mi je pa youtube serviral sazdnjič Star Wars Božični specijal iz 1978
(\___/)
(> _ <)
(> _ <)
DePalmo ::
... Naj naredijo čim več spin offov, SW vesolje ima ogromen potencial.
To je tudi mene motilo in sem si želel precej več filmov in serij. Sedaj prihajajo ven ...
In tole je problem. Ker ni več tiste karizme in pravega pripovedovanja zgodbe, katere se nato tudi držijo! Ampak je vse skupaj na hitro zmetano, samo da se proda. Če pa kaj ne štima oz. ne vedo kako bi nadaljevali, je pa prec "alternative timeline" ali pa "druga stran vesolja".
In sem se sprijaznil da ne bo več dobrih filmov iz sveta SW. In ostalih svetov ... sedaj se dela samo šodr za maso in da se proda. Tako da SW ne spremljam več, imam originalnih 6 filmov in 3 novejše (komaj prebavljive, sploh pa ker se Sith vrne??? Dfuk?), potem se pa zame SW saga zaključi.
New Star Wars Trilogy in the Works From X-Men Producer Simon Kinberg
https://www.ign.com/articles/new-star-w...
It's not, in fact, a continuation of the Skywalker Saga.
| » | Star wars (Knights Of The Old Republic) filmOddelek: Sedem umetnosti | 5045 (3194) | oo7 |
| » | Star Wars nova serija filmov (David Benioff and D.B. Weiss)Oddelek: Sedem umetnosti | 7819 (5594) | Kurzweil |
| » | Star Wars: Episode VII (strani: 1 2 3 4 … 11 12 13 14 )Oddelek: Sedem umetnosti | 203514 (160247) | D3m |
