špekuliranje cen kriptovalut in ICO-jev
A SEC-approved custody solution and ETF backed by physical $BTC is coming and will be the single most bullish event in #Bitcoin history.
Timeline 3 mesece... pa da vidimo.
European Speed Trader Begins Trading Bitcoin And Ethereum Exchange Traded Notes (ETN)
Ena dobra analiza za prebrat...correlation drugih coinov z ceno bitcoina
https://blog.hodlbot.io/how-many-crypto...
Pa še nekaj zgodovine... pred enim letom
This Time Last Year... AntShares, ICOs & Segwit2x
This time last year ASIC said they would be unlikely to regulate ICOs. How quickly that changed!
Bitcoin was trading at $2500 as fears of the chain split loomed surrounding the Segwit2x hard fork.
One of the few coins holding up well was AntShares as excitement started building for the NEO rebrand.
  • spremenilo: Mato989 ()
Kje so zdaj tisti ki so šli v Tezos? A ni bil jype tole?
Tezos je betanet live, in je na CMC na 18tem mestu... zrastel 33% v 24urah...
https://coinmarketcap.com/currencies/te...
Največji ICO v zgodovini kripta je half live =)
Vazelin ::
All in v tezos?
neverlucky ::
Mato989 je izjavil:
Ampak je tudi padel za 50% v zadnjih 5 dneh pred današnjim.
Vazelin ::
Me zanima koliko 1000 procentov plusa ima jype na Tezosu:D
janig ::
Fak verjetno niti Epl ni imel take valuacije ob IPO. Tezos, to je to, ce zelite obogatet.
Vazelin ::
Čemu na trgu trenutno je tezos konkurent?
profdoktor ::
Spet shillate kakeckojne. Ko pa se bo vrednost delila s 50 še letos, bo pa spet jokanje. Marketcap gre pod 100mrd do začetka leta 2019.
Dtrader ::
Kdor ima BCD, naj malo ceno pogleda. Skače kot zajec :)
Bolje da nimaš, ko gre gor, kot da imaš, pa gre dol :)
Zeitgeist ::
Tezos is live and kickin. moj ICO vlozek sem se dopolnil z all in pri 1.60$. Kovanci so delegirani, zdaj pa se samo cakam penzijo :D
Kako se bodo se jezili vsi anti tezos strokovnjaki na tem forumu, ki so nabijali kak shit je to :D :D :D
Vazelin je izjavil:
direktno bi lahko rekli da cardano. S tem da ima tezos to implementirano že v beti, kar ima cardano še v roadmapu
tryhard ::
Tko kot pri koki je vse odvisno, kolk strihnina je not. Pa kolk idiota je v porabniku.
No ja če pomislimo kaj vse si lahko s tem kešom nardil od takrat ko je bil Tezos ICO, je tole kar na mestu =)
Zeitgeist ::
poudarek je na kaj vse bi LAHKO....
Zeitgeist je izjavil:
In nekaj tudi verjetno vsakdo je, vsaj tisti ki so bili v cryptu iz tistih časov =) ne pozabimo Tezos ICO je bil lani poleti! Že če si takrat samo pustil v BTCju si danes up cca. 350%-400%, če si pa investiral in je kaj poskočio pa si gladko 700%, tudi po tem padcu... Kako je pa Tezos?
Da bi vsaj tale Tezos prišel na Kucoin ali kaj podobnega, da lahko kupim =)
profdoktor ::
Mato, ti raje NEBL dokupi dokler je še pod 300$.
Zeitgeist ::
Mato989 je izjavil:
Ti vedno govoriš kaj vse bi lahko... tisti, ki so hodlerji v btc so itak hodlerji in ne vlagajo v raznorazne icote. za 700% pa je tudi bilo miljon ICOjev...my ass...
A še nisi v penziji z vsemi temi bajnimi dobički?
Ne boj pa se za menjalnice. ko starta mainnet boš ga lahko kupoval vsepovsod, verjetno pa po malo višji ceni.
Predlagam pa da si vsak prebere, kaj sploh je Tezos blockchain, da še kakšen kripto strokovnjak tukaj slučajno ne začne primerjave s kakšnimi žetončki :)):)):))
Jih ni bilo? Prosim če malo pogledaš... Vsak ki je 1. jul lani bil na kriptosceni je naredil bolje v 95% če je kupil karkoli drugega kot Tezos.... pač izvzamemo teh 5% Bitconnectov ipd...
Tezos je trenutno 1,73x BTCja... kar ni slabo, ampak to pomeni če si vložil 1. jul 2017 1 BTC v Tezos dobiš danes nazaj 1,73BTCja...
Ga pa spremljam podrobno, ker me res zanima kaj bodo uspeli =) Jim privoščim, to da Tezos uspe je dobro za celoten kriptotrg!
kakob ::
Mato989 je izjavil:
Ja, lahko bi spušil vse.
(disclosure: sem prispeval v tezos ico)
(disclosure 2: to je edini ico ki je odprl mojo denarnico insofar)
Never take a financial advice from someone who works for a living.
  • spremenilo: kakob ()
kakob je izjavil:
Mato989 je izjavil:
Če ti je od 1 julija lani do danes uspelo spušit vse, si zmagovalec posebne vrste =) Se je dalo nič ne rečem (Bitconnect, leveragi Bitmex ipd.) ampak je že moralo kar ratat =)
kakob ::
Mato989 je izjavil:
kakob je izjavil:
Mato989 je izjavil:
Average ICO je what, down 95%?
hamez66 ::
Mato989 je izjavil:
Sem pogledal ja. Btc je bil 1.7.2017 okoli 2500$, eth okoli 280$ in xrp okoli 0.26$. Danes je btc okoli 6750$, eth okoli 490$ in xrp okoli 0.485$. Vzel sem tvoj podatek, da je tezos naredil 1.73x več kot btc, torej je zdaj vreden 4.67x več, kot je bil 1.7. Za enako rast bi moral biti eth danes okoli 1300$ in xrp okoli 1.2$.
Zgleda je moral tisti vsak kupiti karkoli drugega, razen eth, xrp ali btc.
Evo, sem pogledal še za neo. Neo je bil okoli 8.5$. No, neo ima približno enak performance, kot tezos. (iz 8.5$ na 40$). LTC je malo več kot podvojil svojo ceno. Iz približno 40 na približno 85$.
Zagotovo pa obstjajo coini, ki so pridobili več kot 4.67 od 1.7.2017 do zdaj. Ampak kljub temu je trditev "Vsak ki je 1. jul lani bil na kriptosceni je naredil bolje v 95% če je kupil karkoli drugega kot Tezos" fake news.
kakob je izjavil:
Mato989 je izjavil:
kakob je izjavil:
Mato989 je izjavil:
In? Še vedno up par 100% od ICOja oz. od lani Julija...
Če je nekaj šlo gor 1000x in padlo 95% je še vedno x50 od vložka...
Če je nekaj šlo gor 100x in padlo 95% je še vedno x5 od vložka...
Če je nekaj šlo x50 in je padlo 95% je še vedno x2,5 od vložka...
In redkokater ICO je šel manj kot 50x od julija lani...
kakob ::
Mato989 je izjavil:
kakob je izjavil:
Mato989 je izjavil:
kakob je izjavil:
Mato989 je izjavil:
95 od ico cene.
hamez66 ::
EOS je bil 1.7. okoli 1$, je pa res, da je že 3.7.2017 potem dosegel high pri 5.4$ (CMC podatki). Danes je okoli 8.7$.
hamez66 je izjavil:
Mato989 je izjavil:
Najbolj pomembnega faktorja pa nisi upošteval... razpoložljivost denarja... Že samo to je vredno za cel Tezos vložek. Ti bom podal primer kar od mojih dveh trader kolegov... en je dal v Tezos, in do pred nekaj dnevi čakal kovance (dal je not btw 2 BTCja!) no drug je pa z 1 BTCjem vložka iz maja lani, pridelal skozi dajanje v druge ICOte in prodaje cca. 50.000EUR današnje vrednosti... pa ni glih neka uber brihta, pač je dajal v par icotov pobral ven x5-x7 in dal v drugih par ICotov... vse od julija lani do januarja letos.
Tezos je bil mrtvi kapital, z velikim vprašanjem če bo kaj iz tega, no k sreči je bilo, ker če bi Tezos šel v propad, bi to bil velik minus za celoten kripto svet, predvsem iz dejstva da je Tezos še danes največji ICO.
Pa da ne bo pomote, ful navijam da Tezosu rata... samo vlaganje v Tezos se je izkazalo za relativno slabo, če si vsaj malo vedel kaj delaš od 1. jul do konca 2017... Mogoče pa se oddolži Tezos letos =)
kakob ::
Mato je malo zmeden. Move along.
jimyboy ::
Kaj pravite za ICO EO.Trade in njihov kovanec EO coin. Je za vložit kakih 100-200 EUR ?
https://eo.trade/
Zeitgeist ::
plus tega če je že nekaj ICOjev imelo 700% donos od julija lani do danes je to totalno nerelevatno, ker velika večina(upam si trditi da preko 90 posto vseh)itak proda ob prvem večjem profitu(beri x2,x3).
pa še malos statistike, da nebomo na pamet
https://icostats.com/roi-since-ico
znova je iz tabele razvidno, da je penzija material longterm hodl v pravem kovancu z lastnim blockchainom.
Jaz sem se že lani odločil, da ko pride Tezos grem na all in in longterm hodl s tezos, ter cakam na 100$ :D
s temi današnjimi ICOti pa samo mali gembling z minornimi vložki, pa še to samo v bull marketu.
perci ::
kakob je izjavil:
Predvsem ima hude probleme z matematiko prvega razreda OŠ. Uporablja raje Matomatiko.
Seveda seveda... tezos je bil best choice lol
Kaj je sedaj s Tezosi, se jih že da namazat na kruh? Pradedek jih je precej kupil, da mu posredujem news..
perci ::
Mato989 je izjavil:
Boš razložil, kako od 6.700 (cena na 1. avgust - vrhunec poletja) cena btc zraste na 6.700 (danes) in to pomeni 400% rast?
perci je izjavil:
Mato989 je izjavil:
Bom ko mi boš razložil kako je 1. jul(začetek Tezos ICO) = 1. avg
Čeprav boš prvo moral obrazložit kateri 1. avgust, in kdaj je bila 1. avgusta cena 6.700$... ampak ok. Lahko da meniš hipotetično.
Če si kupil 1 BTC Tezosa imaš danes 1,55 BTCja (trenutna cena) včeraj je bilo 1,7x... to je cca. 50% - 70% increase valuacije Tezosa. Ker pa je bitcoin danes vreden skoraj 2,5x več, pa je to v USD cca 4,4x po trenutni ceni. To je slabo za eno leto v cryptu(odlično pa za obdobje feb 2018 - maja 2018 in za obdobje po tam ene 10 jun do danes)... Sploh če vračunamo not še nedosegljivost vložka kar 1 leto!!!
Pa še 1x ponavljam upam da Tezosu rata, še jaz bi ga kaj kupil samo ne zaupam trenutnim menjalnicam... Ampak govorit kako je bil to dobra odločitev medtem ko smo gledali sodišča in ostala vprašanja ali bo sploh zalaufalo je pač denial. K sreči je zlaufalo KONČNO =)
perci ::
trollam, tako kot ti - če pa že hočeš točne številke.
1. avgusta je bila cena 2.850, danes je 6.700.
Zdej, men kalkulator kaže, da je faktor rasti 235%, ne 400%.
Se pa ne vtikam v Tezos, kažem zgolj na precejšnjo napačnost tvoje izjave, da je imel BTC 400% rast. Ki je laž ali pa velika neumnost.
Seveda lahko prestavimo datum začetka iz 1. avgusta na par dni kasneje (še vedno poletje), pa bodo tvoji rezultati še precej slabši.
Vazelin ::
Se javim za admina te izbe.:)
Tezos je imel kar dober output konec koncev. Imel si lockane resource eno leto. Itak bi jih pokuril za raznorazne shitcoine. Tako da je to lastnikom naredilo uslugo saj imajo sedaj 3/4 bitcoina več, kot bi ga imeli sicer. Seveda ob predpostavki, da svojega BTC ne bi prodali konec decembra ko je bil 20k. :D
Mato: dejstvo je, da ni bilo potrebno delati nič narobe, da je človek v minusu. Glede na padec marketa se ta meja premika iz meseca v mesec nazaj. Sedaj bodo v minusu kmalu tisti, ki so kupovali lani oktobra, čez pol leta bodo morda v minusu tisti, ki so kupovali januarja 2017 :P Če nisi imel coina, ki je šel x10 si sedaj v minusu. Recimo iconomi je eden teh primerov, pa je bil top100 coin celo leto! To je čista sreča. Po drugi strani je šel kak zclassic iz 3mio cap-a na 300 na hitrico... Luck
  • spremenilo: Vazelin ()
lambda ::
Tezos ICO je bil v razponu 0.00016667 do 0.00020000 BTC, odvisno kdaj je folk kupil.
Zeitgeist ::
Machete je izjavil:
reči pradedku, da teziji opravljajo vse funkcije nad pričakovanji, veriga laufa tako kot mora, DPOS("rudarjenje") se je začelo z drugim ciklom v velikem obsegu. Zaenkrat torej vse znotraj okvirjev in nad pričakovanji za razliko od velike večine ostalih projektov. Pradeda pa jih rajši naj v shrambo pospravi. :)
Resen nasvet? Ker je trigger happy, ko so bili toliko časa v 'vicah'.
Much appreciated.
sivistol ::
dx exchange danes zalaufa
binance referal ( 10% off ) https://www.binance.com/en/futures/ref/38134864
Looooooka ::
O folk se zmeraj "profite" racuna v bitcoinu. Ne mores verjet :))
Zakaj pa ne? Če je to tvoja target valuta?
Zeitgeist ::
še zadnji moj post glede Tezosa in zakaj sem šel all in v njega(pa ne vlagam po 100€ v projekte) potem pa se zopet javim na temo Tezosa, tam nekje decembra :)
1. Tezos ICO je imel pravne izzive zaradi strukture, ki so jo v začetku postavili, ker je en tip Gevers postal preveč pohlepen. To je sedaj z njegovim odstopom rešeno.šlo pa se je za kontrolo nad ICO sredstvi, ki sluzijo marketingu,etc.
2. Tezos je samostojni blockchain z delujočim blockchainom, ki je v beti in je podoben Cardani(ki pa še zdaj nima implementiranih funkcij, ki jih XTZ ima v beti in trenutno delujejo nad pričakovanji)
3. Delegiran POS("rudarjenje") deluje brez posebnosti. Načrtovani donosi pri delegacijah so trenutno pri 5% letno z delegiranjem("rudarjenjem") preko delegacijskih servisov.
4. Artur Breitmann(snovalec Tezosa) je eden vodilnih na področju blockchain tehnologij in se lahko z lahkoto postavi ob bok Vitaliku.
5. Tezos community sestavljajo večinoma ljudje, ki nadpovprečno poznajo tehnologije blockchain.
6. Tezos projekt svoje nadgradnje omrežja izvaja preko votinga.
7. Delegation servisi se gibajo med 8%-15%
8. Že fazi bete so izdane odlične aplikacije in storitve, ki nudijo podporo tezosu(tezbox,baking servisi, baking SW), kar kaže na močno tehnično podporo projektu.
9. Tezos ni navaden token projekt, ki izda svoje tokene na eth ali neo.
10. pa še bi lahko našteval. Vse te stvari in še veliko več je dostopno na spletu in z lastnim researchem lahko še vsak dobi tone drugih informacij glede projekta.
Pa še dve predikciji glede cene tezosa v prihodnje. Ob Mainnet launchu okoli 10$ v prihodnosti se bo zasidral okoli 100$, kar ga glede na trenutni marketcap uvršča ob bok ETH.
Sem pa prepričan da bo tezos hitro med TOP 5 kovanci.
To je to. mojih 5 tezos cents
1pioneer ::
Težko bo XTZ imel 100$, total supply je 763.306.930 in sedaj je zunaj že 607.489.041. Če primerjaš z ETH ima te "le" 100.581.940 v cirkulaciji. Da bi XTZ šel na 100$ bi morali vsi v njega vlagat in še total marketcap se potrebuje krepko dvignit. To pomeni, da bi se kriptovalute začelo uporabljati v vsakdanjem življenju, kar pa v bližnji prihodnosti ne vidim. Mogoče 10+ let. Trenutno je v kripto sceni pod 1% populacije, poglej samo koliko malo miljonov walletov je v BTC in še te imajo ene osebe po 2 ali več. Sam imam ene 10 BTC naslovov če ne še več.
janig ::
Looooooka je izjavil:
V Jugi se je vrednosti stvari, profite itd. primerjalo z markami. Zdaj se bo z BTC.
Vazelin ::
Kdor gleda fiat ni pravi believer:D
janig ::
Predvsem pa fiat nima nobene vrednosti. Danes je kilo kave 1$, jutri lahko ze 3$. Treba je gledat v BTC za pravo vrednost.
Zeitgeist ::
1pioneer je izjavil:
s tvojo trditvijo se strinjam ob predpostavki, da razmerje med eth in xtz ostane isto. Sam sem pa mnenja da se bo to razmerje porušilo v prid XTZja in bo XTZ v prihodnosti v vrhu teh tabelic. V bistvu trdim, da bo XTZ eden izmed glavnih playerjev v kriptu :)
za dosego 100$ pa je potreben 50x trenutne cene, kar je pri projektih s samostojnim blockchainom mala malca. Seveda ob večjem splošnem marketcapu. Če ostane takšnen kot je ali še gre dol je itak brezveze na bilo kaj računat :) :) :)
838 / 976
