Forum » Kriptovalute in blockchain » špekuliranje cen kriptovalut in ICO-jev
![](https://static.slo-tech.com/stili/avatar_gray.gif)
lambda ::
SuperKripto je izjavil:
Je pa pomoje pametno dobit cim vec eos po cim nizji ceni, dokler se lahko.
Saj bi te še razumel, če bi tole trobil jeseni/pozimi ...
janig ::
Dej perci zbris ta shill, da ne bo slucajn kdo postal novi milijonar!
SloTech bo poln milijonarjev. HODL.
profdoktor ::
SuperKripto je vložil stotaka v EOS pri 23$, zdaj pa bi rad da pride čimveč forumašev pod njega v piramido. Normalna stvar. Vsak upa da ga nekdo porine proti vrhu.
Drugače pa samo 20 postov na dan z nebulozami skupaj ne obeta niti x5 za kakeckojne, kaj šele x10, x100 ali x1000.
![:D](https://static.slo-tech.com/smeski/icon_biggrin.gif)
profdoktor ::
BCH bo sam splezal čez 2k$, ne se bat. Nimam pa take motivacije zaradi teh x3 ali x4, da bi ljudem prodajal nebuloze. Kupite Musicoin ker bo Rihanna podpisala jutri.
![:)](https://static.slo-tech.com/smeski/icon_smile.gif)
sparovcek2 ::
tonis ::
sparovcek2 je izjavil:
Tako kot tule zagovarjate tale EOS, smo pomoje tam nekje, "return to normal".
No, morda se pa motim in bo skočil direkt na luno.
Zato pa so stop loss-i.
Kolikor sem spremljal novice je dump pred junijem pričakovan.
![](https://static.slo-tech.com/stili/bel_non_grata.png)
Aquafriend ::
kako pa ves, da nisem?
2nd acc
sam ne nubenmu povedat
- spremenilo: Aquafriend ()
ECB's Hansson says he doesn't see a big future for cryptocurrencies
The way blockchain-based cryptocurrencies are governed could soon change
Bitcoin price LIVE: BTC at $9k as crypto space becomes 'too big to ignore' for investors
"Crypto Heroes" Play the Long Game: Tim Draper
Bitcoin bull believes crypto investors need to be prepared for some short-term pain, if they want to enjoy substantial gains in the long-term.
RUSSIA: 'BLOCKCHAIN WILL BELONG TO US'
South Korean Lawmakers Introduce Bill To Legalize New ICOs
TELEGRAM CANCELS PUBLIC COIN OFFERING
One person with inside information told The Wall Street Journal that the decision to call off the public sale comes after Telegram Group Inc. raked in $1.7 billion by selling newly created cryptocurrency to only a select group of private investors.
How select a group, you ask? According to the source, fewer than 200 investors were able to take advantage of the much sought after fundraising method. Only accredited investors with a net worth over $1 million were allowed to invest in the colossal ICO, which saw $850 million raised twice in a pair of private deals -- once from 81 investors, and then again from 94 investors.
Bitcoin Is Not Used by Organized Crime Syndicates Says Hong Kong Government
sparovcek2 ::
In kje imaš postavljen stop loss?
Če vsi pričakujejo dump pred junijem, potem bo zagotovo dumpalo 31. maja. Dumpali so(smo) na vas, kmalu bo večina ugotovila da se junij bliža in v pričakovanju nadaljevanja dumpanja prodala svoje bage, pa bomo lahko spet poceni kupili!
Upam da se motim in da vsi pošteno zaslužite.
Če ste prepričani da je to naslednji ethereum in ste dobili dober entry, potem pa lahko tako mirne vesti hodlate na daljši rok in se ne obremenjujete z trenutno ceno.
- spremenilo: sparovcek2 ()
marekmarko ::
Tole zna bit spet ena pumpa za ZCL http://bitcoinist.com/a-big-forking-ann...
Res je da ni glih na najnižji vrednosti ampak mi je prejšni fork ZCLja prinesel 30x tako da zna še malo podivjat :-)
lambda ::
Samo zavedat se moraš, da je to greater fool igra. Nikogar ne briga novi kovanec. Airdrop se dela na dva chaina samo zato, da se enega od njih spumpa.
Serijski forker @HeyRhett. Posvarite otroke pred njim.
marekmarko ::
HeyRhett nima veze s tem forkom, je pa res da ustvarja drug fork na drugem kovancu. Je pa baje zapustil ekipo BTCP.
profdoktor ::
Aquafriend ::
Ti si se januarja sele zbudu.
ne, prej sem uporabljal drug nickname, enga za bull market enga pa za bear.
profdoktor ::
perci, moraš upoštevati vse alternativne virtualne identitete neke osebe in ne samo ene. Aquafriend, april je pri tebi bil zelo muhast. Kdo si danes?
Aquafriend ::
Sem sel gledat to temo za nazaj, ogromno postov zbrisanih, nekje celo 2 dni nobenega posta, nekje trije posti v 1 dnevu itd. In to decembra ko je bilo ogromno pisanja.
profdoktor ::
Seveda, če si takrat imel še več računov kot te dni. Za vsak kakeckojn si ustvaril novega da si lahko legitimno shillal.
- spremenilo: profdoktor ()
neverlucky ::
Zgleda je bila slava ideja, da sem prestavil 130EUR IOTE v EOS 5 dni nazaj ...
- spremenil: neverlucky ()
profdoktor ::
Aquafriend ti je prodajal EOS pri 23$. To se je videlo iz ruske vesoljske postaje. Mato = Aquafriend? Ker Mato je NEBL prodajal na forumu za 60$, zato sem potegnil to vzporednico.
Aquafriend ::
profdoktor je izjavil:
Aquafriend je izjavil:
Ja, priporocil sem ga ze zdavnaj. Pri 0.00131 smo pa dobili signal do 0.0025 btc. Prisel je do 0.00244
vpraste percija
oziroma od 11,6 usd do 23 usd
tommorrow ::
profdoktor: when ankaran or simonov zaliv?![]()
Projekt Morje 2018 je že poletel čez 8k€ čistega dobička. Smo že ven iz najhujšega.![]()
Not me... jaz čakam december.
sparovcek2 ::
Aquafriend je res že prej pisal o EOSu, samo ga je potem na vrhu prevzela evforija o naslednjem ethereumu.
Je pa možno da so v zadnjih mesecih fino akumulirali + verjetno še pokupili veliko iz ICOja. Sam upam da bo cena šla po vzoru ETHja lani, hype je, ideja je, vsakdo razume - eterium 2.0, imamo kult, upam da bo še kaka aplikacija za extra hype, dovolj ICOjev in pa airdropi ... Izgleda super. Če je možno pa nevem.
Trenutno čakam če se bo sesedlo, da dobim nazaj po diskontni ceni.
Je pa res da je od dna že x40, tako da mogoče je pa to vse se že zgodilo :D Odvisno, dokler je dotok novih "investitorjev", je še prostora za rast.
profdoktor ::
Zanimiv naslov posnetka. Če hočeš postat milijonar je treba nekomu uturit in tu je treba vpeljat Smiljan Mori metode - polne dvorane in dosti evforije. Obilo sreče pri prodaji kakeckojnov!
takšno nabijanje in hvalenje bi pričakoval od satošija, ki bi bilo vsekakor upravičeno, ne pa od nekega plagiatorja generik kojna...
slotechar ::
kiFni ::
World's first Decentralized ICO BLOCNATION is LIVE .... na KOMODO platformi.
- spremenil: kiFni ()
slotechar ::
Uporabnikov ne bom omenjal, samo njihove top 3 izbire za leto 2018
Rezultati (1. januar/ 3. maj) delni izzid
NEO 75 usd/ 84 usd
ETH 747 usd/ 723 usd
XMR 345 usd/ 243 usd
DRGN 1.9 usd / 1.1 usd
NEO 75 usd/ 84 usd
LSK 20.89 usd/ 14.05 usd
rdd 0.0100 usd 0,0105 usd
burst
ltc 234 usd/ 112 usd
BTC 13.600 usd/ 9.200 usd
LTC 234 usd/ 112 usd
OMG 19,89 usd/ 18.30 usd
WTC 11.80 usd/ 17.10 usd
IFT 0.082 usd/ 0.052 usd
EOS 8.75 usd/ 18.00 usd
Jaz sem omenil samo eos, ki sem ga shillal ze nekaj mesecev pred novim letom. Vecina altcoinov je vrednih manj kot 1. januarja 2018. Nekaj jih je vredno malenkost vec kot prej. Prepricljivo najboljse se je izkazal EOS, ki je vec kot podvojil svojo vrednost kljub bear trendu. Iz 8.75 na danasnnih 18 usd. Drugi najboljsi wtc. Seveda se lahko do novega leta marsikaj spremeni.
NEO 75 usd/ 84 usd
NEO 75 usd/ 84 usd
burst
slotechar ::
Pozabil sem burst 0.045 usd/ 0.031 usd
Drugac pa je tudi takrat tekla debata kako je eos predrag. Nekateri so celo omenjali, da je scam. Torej isto kot sedaj.
@slotechar
Kolko jaz vem si ti omenjal predvsem steem =)
slotechar ::
Za leto 2018 samo eos. Sej tudi zdaj shillam vsak dan druzga.
Sem na momente zelo shillal steem, pravtako zrastu
1. januar/ 3. maj
3.13 usd/ 4.00 usd
1. januar/ 3. maj
3.13 usd/ 4.00 usd
- spremenil: slotechar ()
branef ::
branef :: 13. jan 2018, 13:28
Kupil EOS 01.01.2018 po 6.62€. Danes zjutraj pa je bil že 19.52€. Sedaj počiva. In za primerjavo okoli 9. ure zjutraj;
Binance.........................EOS............0.00125799 BTC
Live Coin Watch.................EOS............0.00161238 BTC
Zakaj takšna razlika v ceni???
Slotechar ga je omenil v debati zadnje dni starega leta z dobrimi možnostmi za lepo rast v letošnjem letu. Malce sem ga analiziral in zaenkrat ti Slotechar,hvala. (Božiček te že ima na spisku.)
h1427096 ::
slotechar ::
Se celo spominjam - omenil si ga in nič več kot to. Niti ali pričakuješ pump ali dump. Glede na to, da je bilo dnevno omenjenih vsaj 10 kovancev, pač nismo delali raziskave za vsako omembo. Tako da ni nobene potrebe po triumfiranju.
Preberi moje eos shille pred novim letom, vsak je vedel da najedam z eosom, Ni mi bilo potrebno vec kot omenit po vsem shillanju in najedanju. Internet bo sel na blockchain bla bla
Vazelin ::
Če bi imeli na izbiro, kaj bi izbrali (samo ena možnost):
1. velik in debel penis
2. ultra razvezan jezik
3. 100 BTC
3. 100 BTC
Baja ::
s 100 btcji si kupiš velik in debel penis, posledično se ti bo razvezal jezik.
edit: btc medtem proti $9500?
- spremenil: Baja ()
profdoktor ::
h1427096 ::
če ravno siliš... pred novim letom med tvojimi posti niti 1x ne najdem niti ene omembe eosa. Po novem letu pa jih je nekaj. V stilu tehle:
https://slo-tech.com/forum/t702172/p578...
pa sem mislil, da si omenjal samo eos? Naj berem dalje?
kopriwa ::
Dober ulov! Torej lahko v slotechar-jevo zbirko dodamo shillanje Gulden kovanca. Ta je bil 1.1.2018 vreden cca. 0.24$, danes 3.5.2018 cca 0.11$. Ergo, 55% padec. Ni slabo :).
