špekuliranje cen kriptovalut in ICO-jev
Vazelin ::
dogecoin of exchanges?:))
Zeitgeist ::
a trinity.tech ico ste gledali kaj?
jaz nameravam par neotov noter počit.
hovti980 ::
Še ena špekulacija: PRL, nabavil ravnokar
Zeitgeist je izjavil:
NE... ker ni niti 50% v token salu... tole mi nikoli ni všeč! Vi pa po želji!
Available for Token Sale: 33,33%
boro10 ::
XSPEC nova spletna stran
https://spectreproject.io/
Po roadmapu plan Februar:
Migration to the latest version of Qt with a revamped native wallet UI using QtQuick, which will be simple to port to Android in order to make a mobile wallet
Major improvements to stealth coins including a new splitting/combining algorithm and automatic ring size
Major sync performance improvements
Memory use reduction through the removal of QtWebKit (important for the performance of the Android wallet)
Packages for popular Linux distributions
Sicer ne razumem kaj vse to pomen :/
boro10 je izjavil:
Xspec je morda najbolj perspektiven coin ki ni na exchangih ala Kucoin, Binance, Bittrex :) Mi je žal da ga nimam ampak nekje je treba nardit stop :) Če ga mate ga držite ene 3 mesece, imo lep gain!
Blazz ::
jaz sem z 1 eth kupil ICO car Vertical (cV) . Suppoman ga je čist pofomal :) zelo long term je
Samuel ::
stric razloži nekaj od Ripplu:
od 1:45 naprej
noticably not worth noticing.
Zeitgeist ::
Mato989 je izjavil:
računam na azijski hype ob exchange listingu :)
velikan ::
opa po enem mesecu branja se mi je uspel prijavit. sem pisal suportu pa brez odg.... zdej sem z novim mailom noter in začnem težit....
Mato989 je izjavil:
Ja saj zna bit, itak pride takoj na kucoin, skratka jaz pasam, token sale ratio mi ni všeč, četudi je lockano v "escrow" za 1-3 leta.... preveč je stashano za nadaljnje manipuliranje :D
Red Pulse is presenting at Dublin meet up
  • spremenilo: Mato989 ()
Mani ::
a je že kdo dal kej v hoqu?
Pomagajmo si med samo :)
KUCOIN Exchange: https://www.kucoin.com/#/?r=1bf2f
BINANCE Exchange: https://www.binance.com/?ref=16629068
punisher10 ::
Ok, eno vprašanje. V ker coin zdele dat jurja ta moment pa da se drži notri max kakšen mesec za lep gain? :) še vedno Nebl / RPX?
Rok Woot ::
Jaz v majnših količinah držim še ENG, ETC, OMG, NEO, UBQ, XLM in DGB. (50% je pa RPX, oziroma sedaj še več ...)
Sedaj moram nekaj prodati, katero predlagate?
  • spremenilo: Rok Woot ()
punisher10 je izjavil:
RPX... vsaj do 15.1.+kak dan... pol pa menjava.
Rok Woot je izjavil:
Ne poznam vseh gibanj... prodaj tisto kar nima največjega upanja za next 2 months... jaz bi definitivno ETC (LOL) verjetno tudi OMG in DGB... ampak nisem nihanj pogledal...
Rok Woot ::
Jah ETC sem kupil dva dni nazaj, ker se mi je zdelo, da se nekaj dogaja. OMG je ravno zrastel, DGB pa raste že nekaj časa ... Bom prodal vse tri :)
velikan ::
kam se spravljajo kovanci: qlc,qsp,rpx,dbc, dent, kcs, nebl? obstaja enotna denarnica in ali se izplača glede na vložke 200$/kov
thx
velikan je izjavil:
thx
Obstaja, ampak še ni podrprta... NEON 0.0.08 je komaj v beti, sicer lahko vse te pošlješ na NEO address private denarnico, ampak jih NE BOŠ VIDEL, dokler ne sprogramirajo... tako da za newbe... ne obstaja... za RPX in NEO pa če hočeš pošiljat pa je NEO GUI... podpora v 0.0.08 pride za Qlink in DBC kolikor vem :)
D3m0r4l1z3d ::
NEO čez 14 dni? Ga bo thekey kaj gor pognal?
D3m0r4l1z3d je izjavil:
Ne, dol... ker bo prodaja :) ko dobijo, rabijo funds
velikan ::
Mato989 je izjavil:
velikan je izjavil:
a so kej znani kovanci:) a ti maš to kr na borzi? zaenkrat sam tvoje linke koristil nekoč bo še kakšen tringelt
punisher10 ::
Mato989 je izjavil:
Tnx king :) Kok pa ocenjuješ da gre do 15.1. RPX?
Tarzan ::
Gremo ugibat za RPX. Jaz rečem 4,63USD :)
PS: ni glih lambo je pa porš :o
  • spremenil: Tarzan ()
GaS ::
Živjo! Je RPX še aktualen za nabavit, kot pišete? A še komu zeza kucoin, da mu ne pošlje potrditvenega maila (gmail)?
Hvala!
D3m0r4l1z3d ::
Mato989 je izjavil:
Bo pa do takrat šel gor, ker ga bodo kupovali za nakup tkekey?
Mato989 je izjavil:
Večina je že akumulirala za tole :)
GaS je izjavil:
Hvala!
Probaj resend !
velikan je izjavil:
Mato989 je izjavil:
velikan je izjavil:
Na borzi mam vse razen nebliov, ker jih stakam in dobivam 10% obresti :D
D3m0r4l1z3d ::
Aha, nič jaz bom 2 neota vrgel notri za približno 15k tky-ov, pa da vidimo
Jaz bom verjetno 20-30 :)
grandhaven ::
kakšne imate kaj občutke glede Thekey, ali bo tako uspešen kot naprimer red pulse??
grandhaven je izjavil:
Verjetno še bolje, ker je 1st of its kind :)
Vazelin ::
lol se grem tušira in voila red pulse skoraj na 0.8:)
damn dubai tudi gaina ko nor dans. kaj praviš mato pretvorba nebl v dubai?
  • spremenilo: Vazelin ()
Vazelin je izjavil:
Ne... jaz sem ti povedal...jazNEBLe prodajam po 1. jul NAJHITREJE... :) to bodo vsi hodlali... prej je kucoin order book že kazal po 740€ prodajni NEBL, ker folk ni prodajal... vse pokupli
NEBL je moj penzion :D
velikan ::
a tky se bo lahko samo z neo kupil? pa jih potem lahko kar iz borze pošlješ? se spomnim zajtgajsta ki je imel slogan:NIKOLI NE SODELUJ V ICOTU Z DENARNICO IZ BORZE
velikan je izjavil:
Seveda, NIKOLI ne pošiljaš v ICO iz borze...
Če komu to ni jasno, naj raje pošlje denar meni, jaz bom bolje upravljal :P
velikan ::
Mato989 je izjavil:
sry men ni jasno. kaj izdaš s tem? a neblio denarnica velja tud za neo?
kingsix ::
Samuel je izjavil:
od 1:45 naprej
Zanimivo... To kar je on povedal sem vam jaz povedal že pred tam 4 ali 5 meseci in sem seveda bil napaden.. Mislim, da celo s tvoje strani in on Mato989...lol.
Mani ::
velikan je izjavil:
Mato989 je izjavil:
tukaj imaš en neo wallet: https://neotracker.io/wallet
velikan je izjavil:
Mato989 je izjavil:
Hmmmm... si si kaj prebral preden si začel igračkat z borzo :P Sicer načeloma rad pomagam ampak to so pa zdaj osnove 1.0... tam ob bok tistemu kako narediti račun in KYC... Večina kovancev ima svojo denarnico... vsi pašejo na MEW, če so ERC20 (na ethereum platformi) vsi NEO icoti pašejo v NEO... ostalo pa preberi par strani tu, pa google prosim, ker me prsti bolijo že malo danes :(
Rok Woot ::
Ima kdo kako mnenje o https://wanchain.org/ ?
Vazelin ::
kakšen piece of shit je ethereum wallet. po par minutah neha s sinhronizacijo nodeov in skoz restartam
leil ::
@GaS
Poglej v spam :) Meni je tja zabrisalo.
Vazelin ::
mato: samo ta kukon ratuje drugi kraken:)
Vazelin je izjavil:
Ja, ko bo stagniral in štekal kot kraken bom pa verjel, dokler maš pa 40% rast tedensko al pa 50%... pa ti šteka ker ne folgaš, sem pa razumljiv :P
Saj spet upgradajo... to bo zdaj tak cel mesec :D
PrihajaNodi ::
Pozbite kriple, neote pa vibratorje (viberate;). Music coin bo šel v nebo.
cungalungaa ::
Zakaj se mi zdi, da samo uporabljajo procesorsko moč za minanje :D
Vazelin ::
PrihajaNodi je izjavil:
Pozbite kriple, neote. Music coin bo šel v nebo.
ajde bom dal 500 iz btc na bitrexu da vidmo napovedi. Upam da ne gre po poti EOT :P
Od kod vam vedno tolko btcja pa to da date 500 tu pa tam
Jaz sem kot kaže revež, ko nimam btcja že 1 mesec... :O
Vazelin ::
Traderji, DBIX bo prebil 20USD;) Zna nabit navzgor.
mato: na bitrexu mam 0.1 btc v rezervi za shill coine
Če ne bo 50% na musicu bom Nodiju dumpal EOT :D
krneki0001 ::
kingsix je izjavil:
Samuel je izjavil:
od 1:45 naprej
Ljudje so ovce in ovce so za striči. Ripple je za hiter zaslužek in potem za odmet.
boro10 ::
Sej na kukonu je normalno da bonus za držanje KCS prihaja z zamudo?
362 / 976
