xml/boolean java/SOAP
BRBR ::
Namesto false sem probal 0 in vse živo, pa nič ...
WSDL: http://www.marinespecies.org/aphia.php?...
doc: http://www.marinespecies.org/aphia.php?...
test page: http://www.soapclient.com/soapmsg.html
server address:
http://www.marinespecies.org/aphia.php?p=soap
soap action: getAphiaRecordsByNames
<?xml version="1.0" encoding="UTF-8"?>
<soap:Envelope
	xmlns:soap="http://aphia/v1.0/AphiaMatches" soap:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
	<soapenv:Body>
		<message name="getAphiaRecordsByNamesRequest">
			<part name="scientificnames" type="tns:scientificnames">Unio pictorum</part>
			<part name="marine_only" type="xsd:boolean">false</part>
		</message>
	</soapenv:Body>
</soap:Envelope>
če dam
ven
potem je OK, kajpak pri kakem drugem speciesu npr "Abra alba", zato ker je marine species
Unio pictorum pa pač ni zato pri tem tudi brez part name="marine_only .. ne vrne nič, s "false" bi po moje moral kaj vrnit"
Unio pictorum je gotovo tam ker ga najdem preko web page.
  • spremenil: BRBR ()
php login s pomočjo soap-a
Oddelek: Programiranje
71976 (916) matmul
Programiranje GPIO na RaspberryPi 3
385430 (4274) slodreamer
[Java]Shranjevanje/Branje nastavitev za povezavo z podatkovno bazo
193495 (3269) KernelPanic
if(empty($_POST["vsa-polja"]))?
Oddelek: Izdelava spletišč
213422 (3037) Housy
excell formule
Oddelek: Programska oprema
182735 (2437) ZePe
