Loop pixel v tabeli
Loop pixel v tabeli
space ::
Tukaj je link: Web
Zanima pa me, kako bi resil ta problem z loopanjem bg slike. Rad bi naredil da ko pride text do konca tabele da samo loopa zadnjih par pixlov pred koncem rdecega okvirja. Ce bi imel enobarvno ozadje za tabelo ni problema, ker pa imam sliko pa ne najdem resitve. Se komu sanja kak bi to resil na cist ueasy resitev ?
Aja, tabelo sem zanalasc pustil narisano da je priblizen obcutek kak zgleda stvar.
Hvala za pomoc.
lp, space
darh ::
’background-repeat’
Value: repeat | repeat-x | repeat-y | no-repeat | inherit
Initial: repeat
Applies to: all elements
Inherited: no
Percentages: N/A
Media: visual
If a background image is specified, this property specifies whether the image is
repeated (tiled), and how. All tiling covers the content and padding areas of a box. Values have the following meanings:
repeat
The image is repeated both horizontally and vertically.
repeat-x
The image is repeated horizontally only.
repeat-y
The image is repeated vertically only.
no-repeat
The image is not repeated: only one copy of the image is drawn.
Example(s):
BODY {
background: white url("pendant.gif");
background-repeat: repeat-y;
background-position: center;
Excuses are useless! Results are priceless!
space ::
xbite: danke. Sam to se vedno ni bla resitev za page. Sicer mi je tudi pomagalo da sem fixiral zgornjo sliko. Zdaj pa sem tak naredil, da v tabeli ko je bg sem fadeal v crnino spodaj, tako da se mi ponavlja rdeca crta ob strani ter crnina in pride superca ven. Ko bo page online bom dal link da bos videl kak sem resil. Ce te bo zanimalo seveda.
Drugace pa hvala za pomoc.
lp, space
Ziga Dolhar ::
Uporabiš 2 slikci.
https://dolhar.si/
sopex ::
pa ne pretiravat s slikami..ker se stran ful počas nalaga...mam dial-up in sm rabu najmanj 50sekund da se je v celoti naložila :)
čimveč fotk notr fukneš, tok počasnejš se nelaga stran
space ::
V bistvu to so VSE slike kaj so. Res da sem pretiraval z s kakovostjo slike, sam smo nekak v sodobnem casu pa predvidevam da se vec ne uporablja dial-up povezava ;)
Podrta oblika strani
Oddelek: Izdelava spletišč
131753 (1432) echoman
[CSS]Pozicioniranje footer diva
63119 (3066) amaze646
Koda za sliko
111406 (1243) Uros!no
Dreamweaver
121491 (1286) mte
Neubogljiv Dreamweaver MX
162518 (2277) Crimson_Shadow
