dspam
dspam
korenje3 ::
A kdo ve, če rabim še kej drugega poleg dspam na linuxu, da mi začne filtrirat spam? Ponekod berem da rabim še spamassassin ali pa antispam ipd.
Kaj dejansko počne dspam?
boogie_xlr ::
The DSPAM agent provides a direct interface to mail servers for command-line spam filtering. The agent can masquerade as the mail server's local delivery agent and will process any email passed to it. The agent will then call whatever delivery agent was specified at compile time or quarantine/tag/drop messages identified as spam. The DSPAM agent can function locally or as a proxy. It is also responsible for processing classification errors so that DSPAM can learn from its mistakes.
RTFM ;)
korenje3 ::
ne kapiram angle tolk dobr... v bistvu sploh ne razumem kva pomen.
GTX970 ::
Če gledaš kakšne install howto, potem je potrebuješ drugega.
https://help.ubuntu.com/community/Postf...
  • spremenilo: GTX970 ()
Odvisno, kaj želiš početi.
Pred 12 leti, ko sem se nazadnje aktivno ukvarjal z dspamom, je bil kot samostojen izdelek precej betežen, čeprav je bilo samo jedro odlično. Danes je verjetno ravnotako najbolj primeren kot klasifikator znotraj spamassassina in prek njega amavisa? Mogoče pa so infrastrukturo okrog dspam statističnega jedra že dovolj naštrikali, da je uporaben tudi kot standalone.
korenje3 ::
torej dspam samo kasificira emaile, kako jih klasificira pa določa drugi program?
korenje3 ::
V glavnem a kdo ve kako to rešit:
Jun 30 21:11:56 the-nox postfix/smtpd[28148]: connect from gcvozaue7.omitz.in.net[104.151.26.68]
Jun 30 21:11:57 the-nox postfix/smtpd[28148]: NOQUEUE: filter: RCPT from gcvozaue7.omitz.in.net[104.151.26.68]: <gcvozaue7.omitz.in.net[104.151.26.68]>: Client host triggers FILTER dspam:dspam; from=<SurfaceGiant@omitz.in.net> to=<korenje@the-nox.com> proto=ESMTP helo=<gcvozaue7.omitz.in.net>
Jun 30 21:11:57 the-nox postfix/smtpd[28148]: 6FCCB3C07BA: client=gcvozaue7.omitz.in.net[104.151.26.68]
Jun 30 21:11:57 the-nox postfix/cleanup[28155]: 6FCCB3C07BA: message-id=<393523910152340393517365233522@gcvozaue7.omitz.in.net>
Jun 30 21:11:57 the-nox postfix/qmgr[28133]: 6FCCB3C07BA: from=<SurfaceGiant@omitz.in.net>, size=6265, nrcpt=1 (queue active)
Jun 30 21:11:57 the-nox postfix/qmgr[28133]: warning: connect to transport private/dspam: Connection refused
Jun 30 21:11:57 the-nox postfix/error[28156]: 6FCCB3C07BA: to=<korenje@the-nox.com>, relay=none, delay=0.67, delays=0.63/0/0/0.04, dsn=4.3.0, status=deferred (mail transport unavailable)
Jun 30 21:11:59 the-nox postfix/smtpd[28148]: disconnect from gcvozaue7.omitz.in.net[104.151.26.68]
Oziroma kaj to pomeni. Sem skonfiguriral po tem: https://help.ubuntu.com/community/Postf...
Pa izgleda da nekaj ne dela.
email antispam - linux
Oddelek: Programska oprema
5849 (821) pegasus
Lastni poštni strežnik(kako ne biti označen kot spam)
Oddelek: Omrežja in internet
214185 (3745) BlackPanx
Ubuntu 9.04->10.04 = Mail ne dela več
Oddelek: Operacijski sistemi
61372 (1289) Icematxyz
[Ubuntu server] mail poslan iz serverja zazna kot vsiljeno pošto (strani: 1 2 )
7911026 (9996) shorvat
postfix problemi! (fedora)
61372 (1277) drola
