Wired racunalnik se mi ne poveze na router
dotArj ::
Zivijo
Problem imam z novim Tp Link wr740n routerjem ki sem ga dobil ob napkupu T2 TVja. Do sedaj sem imel linksys wrt54gl in je vse delalo v redu, odkar imam nov router se pa prek glavnega (ozicenega) racunalnika ne morem povezat. Imam se 2 laptopa ki sta povezana preko wifija in z njim preko 192.168.0.1 pridem do nastavitev, preko ozicenega pa nikakor ne morem.
Tukaj je ipcofing /all wired racunalnika
Windows IP Configuration
Host Name . . . . . . . . . . . . : PC-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : t-2.net
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : t-2.net
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : C8-60-00-69-C9-24
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::b009:19cf:20a7:972b%12(Preferred)
IPv4 Address. . . . . . . . . . . : 93.103.225.170(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Lease Obtained. . . . . . . . . . : 3. maj 2015 18:25:23
Lease Expires . . . . . . . . . . : 4. maj 2015 18:25:23
Default Gateway . . . . . . . . . : 93.103.0.1
DHCP Server . . . . . . . . . . . : 188.230.128.1
DHCPv6 IAID . . . . . . . . . . . : 264790016
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1C-D2-65-02-C8-60-00-69-C9-24
DNS Servers . . . . . . . . . . . : 84.255.209.79
84.255.210.79
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.t-2.net:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fd:38c7:3b52:a298:1e55(Pref
erred)
Link-local IPv6 Address . . . . . : fe80::38c7:3b52:a298:1e55%11(Preferred)
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter 6TO4 Adapter:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter
IPv6 Address. . . . . . . . . . . : 2002:5d67:e1aa::5d67:e1aa(Preferred)
84.255.210.79
Ce se s tem rac. provam povezati preko 93.103.0.1 (default gateway) sekudno brska in nato napise da stran ni na voljo (ce provam preko 192.168.0.1 in 1.1 isce skoraj minuto in nato vrze isti error). Proval sem dnsflush, ipv4, ipv6 in winsock reset ter ip reset in nic ni delovalo. Sklepam da je default gateway ip napacen ker na obeh laptopih imam default gateway 192.168.0.1 in zato se lahko povezem pri tem imam pa ta cudn ip ki sem ga nekako dobil ko so mi zamenjali router.
Nekaj sem bral da bi moral kloniram mac naslov ampak ko grem v nastavitve preko enega od laptopou mi z rdecim napise da naj kloniram samo ce sem trenutno preko ozicenega racunalnika povezan na router in ne wireless. V glavnem to glede mac addressov ne razumem popolnoma in res rabim to resitev ker se zaradi tega racunalniki tudi v homegroupu ne vidijo (laptopa se, ozicenega pa ne). Proval sem tudi ekstrem ponovno nalozit windowse, ker ko so mi zamenjali router se je network preimenoval v network 2 v network and sharing center nastavitvah windowsev.
Hvala
crniangeo ::
v bistvu je problem , da imas zgleda ta port na katerega si poovezan nastavljen, da ti dobi direkten ip. poglej preko wifija kaksne nastavitve portov imas..
Convictions are more dangerous foes of truth than lies.
dotArj ::
hmm lahko malo boljse opises kaj moram pogledat ker kar gledam zdaj v nastavitvah routerja (Network, DHCP, Forwarding, IP & mac binding) ni nikjer nobene nastavitve kako dobiti IP. Vmes sem tudi resetiral router na fabriske nastavitve in je bilo se vedno isto, ker se mislil da to nastavi na najbolj optimalne nstvitve.
hvala
Han ::
Pravilno sklepaš - gateway in IP računalnika sta čudna. Preveri Windows mrežne nastavitve... Kako imaš povezan računalnik? Na router ali na modem?
solatko ::
Slišal sem, da T2 spusti skozi samo 2 računalnika, oziroma 2x lahko zamenjaš mašino, pri 3-ji pa moraš poklicati podporo, da ti povežejo MAC naslov (baje je to zato, da nebi mogel sosedom dajati zastonj internetne povezave). Na wi-fi ni omejitve.
Če si že imel dva različna računalnika in je ta tretji, pokliči T2 in bodo poštimali. Poseg je brezplačen.
Lahko pa iz starega routerja prekopiraš - clone MAC adreso in bo zadeva delovala.
Routar se namreč modemu predstavi s svojo adreso, enako kot mrežna kartica računalnika.
Delo krepa človeka
  • spremenil: solatko ()
dotArj ::
Zivijo spet
na Han-ov predlog sem sel pogledat kako imam pravzaprav vezano komp-router-modem ker me ni bilo doma ko so to delali. Na koncu se je izkazalo da je bil rac. dejansko priklopljen direkt na modem namesto na router in neumen jaz tega nisem sel gledat ker sem mislil da so mi prilopili vse kot je bilo. Zdaj tudi razumem kaj je crniangeo mislil s tem da dobim direkten ip. No, zdaj vse dela kot je treba.
hvala vsem trem za trud :)
Težave - internet
Oddelek: Omrežja in internet
302231 (1969) megy
Problem z internetom
473818 (3369) RuskiSnajper
Problem router/mordem
153202 (2889) gorenjc
PROSIM ZA POMOČ!!!!Nestabilna povezava z Internetom.
82327 (2218) McMallar
vista in dve mrežni kartici - problem
63057 (2883) sosko1
