Forum » Strojna oprema » Nvidia Pascal
Nvidia Pascal
Saj je tudi večji čip BTW in testno/tehnično orientiran.
- spremenil: D3m ()
Predator X ::
AapocalypseE je izjavil:
Zdaj pa še zaključek 1060 3GB vs. 480 4GB
The GTX 1060 3GB card does have more consistent frametimes when looking at some games - like Mirror's Edge and Black Ops - but the card faces good competition from AMD. The RX 480 4GB card outperforms in averages with Black Ops III, though would require some settings tuning to eliminate that occasional hiccup. AMD is also showing significant scaling with low-level APIs that puts it in more direct competition with nVidia. The Gears of War 4 and Vulkan benchmarks prove this. Each device will allow 1080p gaming with Ultra settings, for the titles tested, and can scale to 1440p with slightly lower settings. NVidia tends to be more consistent in its driver performance for frametime consistency with the GTX 1060. The RX 480 isn't a bad option - AMD's significantly improved its drivers since our review, the company just has some more progress to make in some titles.
Pa prosim tiho zdaj glede tega, ker se govori o novi 1080 Ti in ne 1060 vs. 480
Ne, ker ti špil omeji texture, če nimaš dovolj rama.
- spremenilo: Predator X ()
AapocalypseE ::
ABX ::
Uff, nisem pričakoval 1080 TI po tej ceni.
Se bom malo razvajal :P
Cveto ::
Glede na tole (tabela spodaj) vseeno dobimo novo verzijo 1060 3GB, na GP104 jedru?
http://wccftech.com/nvidia-geforce-gtx-...
Al so se zmotili?
Al so se zmotili?
_koki_ ::
Cena 1080Ti je res mamljiva, samo cca. 100eur nad staro ceno 1080 oziroma cca. 200eur nad ceno 1080 po novem...
Cveto ::
Glede na število CUDA procesorjev ne. Je pa verjetno edini pomen uvedbe takih kartic da se rešijo defektnih 1070. Morda tudi zato ni v samem tekstu nič na to temo.
Vidim pa da ima tudi 1080Ti nekaj disablanih zadev. Se kaže novi Titan?
AapocalypseE ::
d3m, NVIDIA GeForce GTX 1060 Update - Faster 9 GB/s Memory Across All Models
Torej
1080Ti 699$
1080 499$ 11GB/s memory, prej 10GB/s
1070 349$ samo price cut
1060 6GB 249$ 9GB/s memory, prej 8GB/s
1060 3GB 199$ 9GB/s memory, prej 8GB/s
Jaz pa si bom svojo GTX 1070 kar po svoje refreshal in bo mela memory 9GB/s
Torej
1080Ti 699$
- spremenil: AapocalypseE ()
good guy nvidia, slaša cene in navija ram. Amd pa celo pusha ven modele z slabšim ramom
iloveboobz je izjavil:
good guy nvidia, slaša cene in navija ram. Amd pa celo pusha ven modele z slabšim ramom![]()
V narekovajih.
sj pr 1070 niso dvignal rama.
8000->7000Mhz.
nwm no, men se zdi to slabše.
V narekovajih.
8000->7000Mhz.
- spremenil: iloveboobz ()
a zdaj se pa na prakso zgovarjaš. Ko pa nvidia shaderje poreže, je pa hujša situacija kot izvolitev trumpa
AapocalypseE ::
1070 se že itak sama po sebi prodaja super, tako da ne rabijo sploh upgrejdat nič na njej
So pa vsaj malenkost spustili ceno, kar pa je tudi lepo.
d3m, glede rama pa je zelo odvisno od igre do igre, tako da ne trollat in podpirat amd pri nižanju vram frekvence.
Dobro zalagaj prodajalce in nehaj s fanboyizmom
_koki_ ::
Ja ampak recimo malo manj porezat čip, ki ga btw že tako imajo za prenosnike in ob napredku proizvodnega procesa jih to nebi stalo praktično nič, bi pa malo zakrpali luknjo med sedanjo 1070 in 1080, ki se bo še bolj oddaljila s hitrejšim pomnilnikom, tako da bo luknja med njima še večja!
Eno je porezati TMU in CUDA cores drugo pa znižati VRAM frekevenco, ki nima učinka na performance, kot pa pomankanje TMU in CUDA.
Se strinjaš?
tole si se pa zdaj zelo lepo zlagal.
ram frekvenca ima še kako učinek, sploh pri polarisu
Dobro zalagaj prodajalce in nehaj s fanboyizmom![]()
Če te moti frekvenca VRAMA ga povišaš (enostavno).
OK.
"Ki nima hudo slabega učinka na performance"
Better?
- spremenil: D3m ()
Zakaj? Če ponujajo proizvajalcu boljšo frekvenco za isti nabavno ceno.
AapocalypseE ::
Za ljudi je dost pomembno kar dobijo out of the box in kot že vemo, amd ne slovi glede tega, ker moraš vedno nekaj sam popravljat za njimi
Popravljaš tudi pri zelenem taboru to je čar PCja.
Poglej Teslo. True geek.
Za ljudi je dost pomembno kar dobijo out of the box in kot že vemo, amd ne slovi glede tega, ker moraš vedno nekaj sam popravljat za njimi![]()
thats part of the charm
_koki_ ::
Seveda manj vpliva na zmogljivost kot sam grafičen procesor ampak pri 256-bitnem vodilu ti hitrejši ram še kako pride prav!
AapocalypseE ::
Part of the charm za tiste, ki vejo kaj delajo.
Janez pa ne bo znal in ne bo tako zadovoljen
Janez pa ne bo znal in ne bo tako zadovoljen![]()
janez bo kupo ps4, ker ga ma micka in sosedov franci tut :)
AapocalypseE ::
Ali pa sestavljen PC, ker raje igra z miško in tipkovnico
Al so se zmotili?
The new GeForce GTX 1060 models will be shipping with 9 GB/s GDDR5 chips that compared to 8 GB/s, deliver 216 GB/s bandwidth. This is faster than the 192.2 GB/s on the original variants and we can also see some AIB specific price adjustments on the new models too.
Ne višja, ampak nižja.. Morjo tacklat RX480, ki je trenutno p/p king a ne.
Ja.. Sej to je ravno point..Višji performance in nižanje cen, da imajo pokrit trg vsaj za leto dni, s tem da ob izidu Vege še malo prilagodijo po potrebi. No, 1060 cen sicer nimajo kaj dost nižat, mogoče 10-20€, ali pa še to ne.
Cveto ::
Al so se zmotili?
Ok, za ram vemo, samo piše da bo tudi drugo jedro, GP104 vs GP106?
Proda kdo 1080tko z yesterday ramom za 300€? Kupim v kompletu z I7-4790k za 400€. Osebno me ne moti staro železo. :)
Mogoče bodo zdaj sledile kakšne akcije, da prodajo zaloge teh kartic s počasnim ramom.
Evo, iz mojih ust v Casekingova ušesa. GTX 1080 (EVGA) že od 519€ naprej.
AapocalypseE ::
NVIDIA to release Game Ready driver optimized for DirectX12
https://videocardz.com/66680/nvidia-to-...
D3m0r4l1z3d ::
Evo, iz mojih ust v Casekingova ušesa. GTX 1080 (EVGA) že od 519€ naprej.![]()
Ravno te ta stare evga acx 3.0 niso ravno dober nakup, zaradi znanih težav, je pa 1080 msi gaming x za 600eur in nekatere od drugih pod 600 eur.
Lepo pa da so retailerji že prvi dan znižali cene, verjetno bo 1080ti kmalu v ponudbi, verjetno od 700 eur naprej na začetku.
- spremenilo: D3m0r4l1z3d ()
D3m0r4l1z3d ::
Shit, fine wine technology tudi pri zelenih.
On top of that pa še 1080Ti, kjer prav zares niso šparali.. Pri 980Ti so dokaj pošteno posekali Titana, tokrat pa za 1080Ti niso praktično nič posekali Titan Pascala, plus boljše napajanje, hlajenje, izboljšan cache in slabih 2Ghz.. Tole bo res pravi stroj. Ko dodaš še finewine driverje, lahko zeleni mirno spimo do Volte 2018. :)
Vem.. Sicer pa 1080 tako ali tako ne bo nihče več kupil, podobno kot je 980tka padla v vodo ob splavitvi 980Ti.. Kdor ima 500EUR za grafo, ima tudi 700. :D
- spremenil: DarwiN ()
klinker ::
Ah kje. Nvidia je fail ko nima vulkana, pa se gimpano 1060ko s 3GB rama upajo prodajat
- spremenilo: klinker ()
mihco ::
1080ti je 820eur in ne 700.
http://www.nvidia.de/graphics-cards/gef...
Kdor ima 800 EUR grafo ima tudi za TitanXP.
To me spominja na Apple kupce.
http://theoatmeal.com/comics/apple
