Forum » Strojna oprema » AMD R3xx series
AMD R3xx series
Jst ::
En zanimiv excerpt iz GameWorks controversy:
Podčrtal jaz.
Če je to res, potem za slabo delovanje "GameWorks iger" ni kriva samo nvidia, ampak je krivec bolj na strani game developerja. (Kar ne pomeni, da GameWorks sam ni "shady business".)
Again we wanted to make sure there was no ambiguity with regards to any sort of limitation that a GameWorks partnership would entail. The GameWorks program itself does not inherently preclude game developers from working with AMD to implement AMD specific technologies.
A GameWorks partnership isn't equivalent to an exclusive The Way Its Meant To Be Played co-marketing partnership for example. Where it is naturally expected that Nvidia technologies would exclusively be incorporated into the game. Or on the other end of the scale an exclusive AMD Gaming Evolved partnership, where tech from AMD would exclusively be incorporated into the game. GameWorks itself is an enablement tool, it could be used in a game that's subject to an exclusive Nvidia co-marketing deal or equally end up in a game that is not.
Podčrtal jaz.
Senitel ::
neverjetni99 ::
Pa informacij fali, drugače je pa lep boost za vse pri Anno.
Pa vprašanje, če ni ovira 4GB proti 6GB.
|HP EliteBook|R5 6650U|
- spremenil: D3m ()
V povprečju se obnese kar dobro. R9 390 > GTX 970. Se vidi, da so optimizirali za maxwella.
m0LN4r ::
Pr anno jje problem to, da ima Fury 0.5 HBMa preveč xD
https://ref.trade.re/38mvdvxm
Trade Republic 38MVDVXM
PredatorX ::
Pa zakaj nonstop vlečeš debato?
NVIDIA vs AMD
Eto vsi vemo, da je AMD skoraj v bankrotu. Vendar stvari gredo na bolje.
http://finance.yahoo.com/q?s=AMD
GCN vs KEPLER
GCN je veliko boljša architektura. Če se spomnimo GTX 780TI in R9 290X, ja okey GTX 780TI je bila hitrejša, ampak ali je primerjava fer. Berem kake so pisali po slepu , ko je bila GTX 980 releasana. GTX 980 midrange vs High end R9 290X... pa niti 10% večjega die siza nima R9 290X. Ja maxwell je navdušil nad resno optimizacijo za DX11, tudi NVIDIA je pokazala nov CPU overhead driver (že prej z GTX 780TI).
Recimo po die sizu je Fury X primeren nasprotnik za GTX 780TI. V primerjavi z GTX 980TI je pa lepo gledat, če ni CPu overheada sta kr na istiem pri 1080P. Ja odvisno od špila. GTX 980TI ima definitivno večji OC potencijal.
Rebrandane R9 300* je pa večji odgovor, da AMD ni še imel pripravljene arhitekture oziroma ni bilo financ ali optimizacija za 14/16nm. Vseeno pa delajo lepo konkurenco maxwellu. Da nebo slučjano fury X dobila še 10% boosta na DX12 zaradi async shaderjev ali pa boljše optimizacije.
No, če pa že vlečeš debato in iščeš napake pri AMD-ju. Zdej je tole "in"
http://www.tweaktown.com/news/48970/amd...
Uporabniki kažejo, da jim je underclock celo zažgal kartice.
- spremenilo: PredatorX ()
SuperVeloce ::
how the hell is that supposed to work?! Dvomim v avtentičnost. A so istočasno forcali višje napetosti?
Buggy ::
ehh pol pri nama hojnikb sploh ni problema, ker imava narejen overclock in istocasno se undervolt
m0LN4r ::
NVIDIA vs AMD
GCN vs KEPLER
Od kod si teh 20 vrstic skopiral ? Overclocker, WCtech ali en izmed tvojih bivši posto?
Torej če prav razumem je DIE size kriv za težave zle?
Maš kako rešitev? Mrom kej izklopit v CCC oz. C?
- spremenil: m0LN4r ()
Senitel ::
GCN vs KEPLER
GCN je kvečjemu lepša arhitektura. Ali je boljša se lahko odločiš na podlagi performanc in tukaj Kepler marsikje povsem lepo drži svečko primerljivemu GCN hardware-u. Spet marsikje ga bosta pa GCN in Maxwell povsem povozila. Ta delitev tudi ni nekaj novega, ampak se vleče od iger, ki so bile zunaj ob prihodu obeh arhitektur do iger, ki prihajajo ven v zadnjih mesecih.
Ampak važno, da lahko trolamo kako NV ignorira Kepler čipe v novih driverjih.
GTX 780Ti ni ravno fer primerjava s Fury X. Primerjava je GTX 980 TI ali Titan X. GTX 780 Ti ima kar nekaj double precision hardware-a in če vzameš Titan izvedbo bo v DP kalkulacijah pojedla za malico tako Fury X kot Titan X.
Kaj ima AMD s fabi? Grafične čipe jim dela TSMC, če TSMC nima 14/16nm HP procesa na razpolago se lahko AMD in NV samo slikata v rit.
Kako se že AotS obnese na Fury X?
PredatorX ::
Dej senitel.
Nemoreš ti prpravt GCN za 14nm dat ga vn pa na 28nm, za to bi rabil čas da ga ponovno optimiziraš za 28nm + denar. Pa sploh ni fore, to je samo ena odmožnosti in če si opazil sem jo navedel zadnjo.
Sej maš, R9 290X ma skor tak FCAT kot GTX 980Ti. Če ti pa FPSžji pomenijo in taki bencmarki, ki tišijo TAA v neskončnost sploh pa brez opcije, ki sloh pa async shaderje. Pa če gremo po vrsti AotS sploh še ni dokončan špil. Lahko se še vse spremeni.
Glede na zadnje špile je pa AMD kr v prednosti. DX12 bo po večini popravil CPU bottleneck, že spet pa poudarim da je še zelo daleč. Upjamo, da bo BF5 DX12 only.
m0LN4r ::
Eno in isto lajno ponavlaš že 2 leti in zdaj še boš tretje leto xD Mater kok izgovorov znaš naštepat, da opravičiš nakup, ampak zdaj se pa že mal preveč ponavljaš.
bf, bf, bf, ane :)
No ti pa se tut premišluješ enkrat tko, drugič pa tako.
Kolko ? Dva? Kaj pa ostalih 10 ?
Jst sm upal, da bo Mantle že letos future... damn...
bf, bf, bf, ane :)
No no umirite se. Obe firmi sta konkurenčni. Drugače pojdite na drink.
PredatorX ::
Glede AotS, itak vemo da dokler spil ni dokoncan je vse samo "podjebavanje".
Glede gtx 780ti, ki ima okoli 550mm^2 in R9 290x 430mm^2. Gtx 780ti je prej konkurenca R9 FURY X
hojnikb ::
Ti je senitel že lepo razložil, zakaj je 780Ti die tako velik. Pa še vedno tupiš svoje
#brezpodpisa
SuperVeloce ::
Saj ti je Senitel povedal, zakaj v tem primeru tukaj ne moreš primerjati površini čipa. Boš koristil svoji kredibilnosti. Kvečjemu bi lahko ta razlog ti uporabil pri primerjavi recimo hd7970 in gtx680.
- spremenil: SuperVeloce ()
m0LN4r ::
To, da bfjaše prisiliš, da migrirajo na W10 :) Sj morš razumet, da razlika med dx11 in dx12 je lahko samo takrat velika, če si ga v dx11 popušio in še kr bo en kup dx11 iger, ki bo vzrok za nenakup radeonov. Svet se ne vrti okoli BF.
Jst ne štekam, konkurečnosti v kartici, ki rabi za 3/4 špilov neke popravke z vseh strani in na dan izida, dela k na pol cenejši konkurenci.
mhm ker average joe, bo šel specse gledat :) ta taktika je spravila amd v "bankrot"
Resnično, tvoji posti so odraz celega WC tech fanboy štaba. Enkrat ono enkrat drugo.
hojnikb ::
Ko si bo flying enkrat kupo proper grafo, nebo mel časa več bluzit po forumih
#brezpodpisa
PredatorX ::
Ne zavajaj.
m0LN4r ::
Ze spet, to je bila tista zgodba... Gtx980 je midrange ..R9 290x. Da se nebo kregali, tudi jaz mislim da sta zelo konkurencni ina da ima vsak svoje prednosti.
Še dobr, da ni treba štet dle kot do tri.
m0LN4r ::
Sj lahk tut kero drugo, izbire je ogromno :)
hojnikb ::
Špricaj :)
Paperlaunch ja :)
R9 Fury X2 je itak pred vrati.
Paperlaunch ja :)
#brezpodpisa
- spremenil: hojnikb ()
m0LN4r ::
Že od septembra, bo pa drugo leto sigurno xD, pol pa sam še driver fikse počakmo pa gremo v nabavo.
... jah maš prov škoda pavze in telefona.
Bi blo res veliko več dela, kot linkat bf&aots company ;)
PredatorX ::
Itak BF pa aots ti bom tu limal... ja sem si ga že ubavil, bom raje tistih 30 min porabil, da naložim in sprobam.
m0LN4r ::
Tudi mene mika Fx2, če bo mela vodno, da nebo pomote. Upam pa tudi, da bo gnala trenutne špile ceni primerno.
Joj pa tut, nebi blo švoh če recording zrihtajo, ker too much hassle otherwise.
No pol pa res nevem, zakaj bi izklopil, če pa je enostavno čudovito z ON.
Si že ene 100x, ker drugega nimaš :)
ameWorks Has Little Effect on Overall Performance
m0LN4r ::
Lani eno, letos drugo. Odvisno kaj ma PDX v mislih, ko piše.
PredatorX ::
neverjetni99 je izjavil:
pod BF mislite Battlefield al Battlefront? :o
Ne mislim sem za BF5. Resnično čakam en true DX12 špil. Pa upam, da nebo takšen polom. Tud mal več simulacije temu špilu nebo škodilo.
m0LN4r ::
Nono zle bomo pa BF5 poslušal celo 2016 sezono,
PDX probaj še kake druge vrste družabnih iger, dobro za dušo.
neverjetni99 ::
eh lahko je nevem kolk iger optimiziranih za AMD, pa bo še na koncu vedno boljša nvidia. Z 970 sem tud mel več fps v BF4 kot z 290x oc pa je špil optimiziran za AMD. Mene tudi zanima ja kdaj bo prvi DX12 špil prišo? Pa niso rekli da bo battlefront dobil dx12 z updatom?
PredatorX ::
DX11 in švoh AMD CPU overhead driverji.
neverjetni99 ::
aja pa tisti ko je reko da je gtx 980 midrange grafična bi ga mogli malo po zdravju vprašat, te je moja potem mid-high? Torej Nvidia sploh nima high end graf? :o haha
hojnikb ::
Če bi amd malo pofixal DX11 overhead (ker lets face it, dx11 je here to stay vsaj še kakih par let + ostala zaloga iger)
nebi škodl. Ne pa samo da delajo na marketingu in mešajo prazn luft.
#brezpodpisa
neverjetni99 ::
AMD fanboyi...vedno so neki izgovori :D
PredatorX ::
Kakšn fanboy... poglej te štopa proc oziroma driver. Sej tudi GTX 980TI (high OC) štopa intelov 6 jedernik (OC) v BF4, seveda ne skozi se pa pojavijo momenti, ko pade GPU usage 80%. Zdej sm pa AMD FANBOY, če si prizadevam software podoben konzolam za dekstop?!! Kaj poglej si AotS ti tale 6 jedrnik nabije 150 FPSjev. Kar je 50% več kot i7 oziroma 2x več kot FX 8350.
PredatorX ::
m0LN4r ::
Jst nimam res nič proti, ampak priplezaj že dol z tega BF drevesa. Maš še 100 drugih iger, ki jih folk polek tega igra.
To da si fanboy si pa že sam 3x povedal, citiram?
