[Android] HttpClient execute problem
golobich ::
Zdravo!
Delam čisto enostavno registracijo uporabnika katerega podatki se zapišejo v mysql bazo na enem serverju. Problem je ko program pride do delčka kode kjer se kliče metoda execute od httpclienta. Kakršnekoli pomoči bi bil hvaležen.
Izvedba zahteve
if(method == "POST")
    DefaultHttpClient httpClient = new DefaultHttpClient();
    HttpPost httpPost = new HttpPost(url);
    httpPost.setEntity(new UrlEncodedFormEntity(params));
    HttpResponse httpResponse = httpClient.execute(httpPost);
    HttpEntity httpEntity = httpResponse.getEntity();
    is = httpEntity.getContent();
doInBackground metoda
@Override
protected String doInBackground(String... args) {
    int success;
    String username = user.getText().toString();
    String password = pass.getText().toString();
    try {
        List<NameValuePair> params = new ArrayList<NameValuePair>();
        params.add(new BasicNameValuePair("username", username));
        params.add(new BasicNameValuePair("password", password));
        Log.d("request!", "starting");
        JSONObject json = jsonParser.makeHttpRequest(
               LOGIN_URL, "POST", params);
        Log.d("Login attempt", json.toString());
        success = json.getInt(TAG_SUCCESS);
        if (success == 1) {
        	Log.d("User Created!", json.toString());
        	finish();
        	return json.getString(TAG_MESSAGE);
        }else{
        	Log.d("Login Failure!", json.getString(TAG_MESSAGE));
    } catch (JSONException e) {
        e.printStackTrace();
    return null;
Lp, golobich
FrEaKmAn ::
kakšen problem pa je? javi napako?
golobich ::
Ah ja vidim da sm še log fajl pozabu dodat zraven.
Evo log fajla:
08-14 19:26:10.602: E/AndroidRuntime(32141): FATAL EXCEPTION: AsyncTask #3
08-14 19:26:10.602: E/AndroidRuntime(32141): Process: eu.tgsplet.kmetijstvo, PID: 32141
08-14 19:26:10.602: E/AndroidRuntime(32141): java.lang.RuntimeException: An error occured while executing doInBackground()
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at android.os.AsyncTask$3.done(AsyncTask.java:300)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at java.util.concurrent.FutureTask.finishCompletion(FutureTask.java:355)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at java.util.concurrent.FutureTask.setException(FutureTask.java:222)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at java.util.concurrent.FutureTask.run(FutureTask.java:242)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at android.os.AsyncTask$SerialExecutor$1.run(AsyncTask.java:231)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1112)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:587)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at java.lang.Thread.run(Thread.java:818)
08-14 19:26:10.602: E/AndroidRuntime(32141): Caused by: java.lang.SecurityException: Permission denied (missing INTERNET permission?)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at java.net.InetAddress.lookupHostByName(InetAddress.java:451)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at java.net.InetAddress.getAllByNameImpl(InetAddress.java:252)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at java.net.InetAddress.getAllByName(InetAddress.java:215)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:137)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at org.apache.http.impl.conn.AbstractPoolEntry.open(AbstractPoolEntry.java:164)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at org.apache.http.impl.conn.AbstractPooledConnAdapter.open(AbstractPooledConnAdapter.java:119)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:360)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:555)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:487)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:465)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at eu.tgsplet.kmetijstvo.JSONParser.makeHttpRequest(JSONParser.java:123)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at eu.tgsplet.kmetijstvo.Register$CreateUser.doInBackground(Register.java:100)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at eu.tgsplet.kmetijstvo.Register$CreateUser.doInBackground(Register.java:1)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at android.os.AsyncTask$2.call(AsyncTask.java:288)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at java.util.concurrent.FutureTask.run(FutureTask.java:237)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	... 4 more
08-14 19:26:10.602: E/AndroidRuntime(32141): Caused by: android.system.GaiException: android_getaddrinfo failed: EAI_NODATA (No address associated with hostname)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at libcore.io.Posix.android_getaddrinfo(Native Method)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at libcore.io.ForwardingOs.android_getaddrinfo(ForwardingOs.java:55)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	at java.net.InetAddress.lookupHostByName(InetAddress.java:438)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	... 18 more
08-14 19:26:10.602: E/AndroidRuntime(32141): Caused by: android.system.ErrnoException: android_getaddrinfo failed: EACCES (Permission denied)
08-14 19:26:10.602: E/AndroidRuntime(32141): 	... 21 more
Edit: Pa to nemoreš vrjet. mislim da mi je jasno kaj je narobe :)
  • spremenil: golobich ()
shadeX ::
V manifest datoteko dodaj:
<uses-permission android:name="android.permission.INTERNET"/>
FrEaKmAn ::
beri log, vse piše tam. si dodal permissione?
http://developer.android.com/reference/...
Programiranje problem android
Oddelek: Programiranje
51602 (1367) g333kk
[Android] Aplikacija se zruši
61225 (1062) g333kk
android črta
412976 (2247) g333kk
[android] vstavljanje slike
71668 (1565) messi
[android] crash
61825 (1634) messi
