Problem z računalnikom
miha121 ::
Pozdravljeni!
Torej,zadnje čase ko igram euro truck simulator 2 mi računalnik zamrzne,zvok pa zatrokira. Na vseh opcijah (low,medium...). nakar mi pokaže bluescreen ter ga resetiram. To mi je naredilo že 3x v tem tednu.
Testiral sem ga z burnintest-om,ki je napisal:
BurnInTest results
BurnInTest Version V7.0 Std 1016
Date 12/11/12 13:34:08
Logging level Normal
Licenced *** Unlicensed trial version ***
System summary
System summary
Windows XP Professional Service Pack 3 build 2600 (32-bit),
1 x Pentium(R) Dual-Core CPU E5300 @ 2.60GHz,
2.0GB RAM,
AMD Radeon HD 6450,
298GB HDD,
General
System Name: ....
Motherboard Manufacturer: BIOSTAR Group
Motherboard Name: G31-M7 TE
Motherboard Serial Number: None
BIOS Manufacturer: American Megatrends Inc.
BIOS Version: 080014
BIOS Release Date: 04/10/2009
CPU
CPU manufacturer: GenuineIntel
CPU Type: Pentium(R) Dual-Core CPU E5300 @ 2.60GHz
Codename: Wolfdale
CPUID Family 6, Model 17, Stepping A, Revision R0
Socket: LGA775
Lithography: 45nm
Physical CPU's: 1
Cores per CPU: 2
Hyperthreading: Not capable
CPU features: MMX SSE SSE2 SSE3 SSSE3 DEP PAE Intel64 VMX
Clock frequencies:
- Measured CPU speed: 2615.3 MHz
- Multiplier: x13.0
- Scalable Bus Speed: 200.0 MHz
- Front Side Bus: 804.7 MHz
Cache per CPU package:
- L1 Instruction Cache: 2 x 32 KB
- L1 data cache: 2 x 32 KB
- L2 cache: 1 x 2 MB
- L3 cache: Not applicable
Memory
Total Physical Memory: 2047MB
Available Physical Memory: 1670MB
Memory devices:
Slot 1: 2GB DDR2 SDRAM PC2-6400
OCZ OCZ2N800SR2G
SSTL 1.8V, Clk: 400.0MHz, Timings 6-6-6-18 (@ Max. freq.)
Slot 2: Not populated
Slot 3: Not populated
Slot 4: Not populated
Virtual memory: C:\pagefile.sys (allocated base size 2046MB)
Graphics
AMD Radeon HD 6450
Chip Type: ATI display adapter (0x6779)
DAC Type: Internal DAC(400MHz)
Memory: 1024MB
BIOS: 113-xxx-xxx
Driver provider: ATI Technologies Inc.
Driver version: 8.830.0.0
Driver date: 2-9-2011
Monitor 1: 1360x768x32 60Hz (Primary monitor)
Disk volumes
A: Floppy
C: Local drive, NTFS, (149.04GB total, 74.83GB free)
D: Local drive, NTFS, (149.04GB total, 148.77GB free)
E: Optical drive
F: Optical drive
G: Removable
H: Removable
I: Removable
J: Removable
K: Removable
Disk drives
Disk drive: Model: WDC WD3200AAKS-75L9A0 Serial: WD-WMAV2H579911 (Disk: 0, Size: 298.09GB, Volumes: C D)
Optical drives
Optiarc DVD RW AD-5240S
Network
Realtek RTL8102E/RTL8103E Family PCI-E Fast Ethernet NIC (MAC: 00:30:67:10:6E:C1)
Ports
Communications Port: COM1 - RS232 Serial Port (max Baud rate: 115200)
Parallel port: LPT1
USB
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8
- Microsoft Microsoft
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB
- USB,12-Button Wheel
Standard Enhanced PCI to USB Host Controller
- Generic Mass Storage Device (SN: 058F312D81B)
- ZTE,Incorporated ZTE WCDMA Technologies MSM (SN: P680A1ZTED010000)
Result summary
Test Start time Tue Dec 11 13:18:10 2012
Test Stop time Tue Dec 11 13:33:13 2012
Test Duration 000h 15m 03s
Temperature HDD 0 (WDC WD3200AAKS-75L9A0) (Min/Current/Max) 28.0C / 28.0C / 29.0C
Temperature GPU 0 (AMD RADEON HD 6450) (Min/Current/Max) NA / NA / NA
Test Cycles Operations Result Errors Last Error
CPU 55 190 Billion PASS 0 No errors
Memory (RAM) 10 28.705 Billion PASS 0 No errors
2D Graphics 1 7980 PASS 0 No errors
Temperature - - PASS 0 No errors
Optical disk (E:) 0 0 FAIL 30 Error while searching for files on optical data disk
Optical disk (F:) 0 0 FAIL 30 Error while searching for files on optical data disk
Sound 9 15.744 Million PASS 0 No errors
Disk (C:) 0 2.357 Billion PASS 0 No errors
Network 1 3 133520 PASS 0 No errors
TEST RUN FAILED
Detailed event log
Event
LOG NOTE: 2012-12-11 13:18:11, Status, Main Tests started
LOG NOTE: 2012-12-11 13:18:11, CPU, 3DNow! SSE4.1 SSE4.2 SSE4a test(s) selected, but CPU feature not detected
SERIOUS: 2012-12-11 13:18:13, Optical disk, F: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:18:13, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:18:13, Optical disk, E: Error while searching for files on optical data disk
SERIOUS: 2012-12-11 13:18:44, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:18:44, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:18:44, Optical disk, F: Error while searching for files on optical data disk
SERIOUS: 2012-12-11 13:19:14, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:19:14, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:19:15, Optical disk, F: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:19:15, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:19:45, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:19:45, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:19:45, Optical disk, F: Error while searching for files on optical data disk
SERIOUS: 2012-12-11 13:20:16, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:20:16, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:20:16, Optical disk, F: Error while searching for files on optical data disk
SERIOUS: 2012-12-11 13:20:47, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:20:47, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:20:47, Optical disk, F: Error while searching for files on optical data disk
SERIOUS: 2012-12-11 13:21:17, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:21:17, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:21:18, Optical disk, F: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:21:18, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:21:48, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:21:48, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:21:48, Optical disk, F: Error while searching for files on optical data disk
SERIOUS: 2012-12-11 13:22:19, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:22:19, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:22:19, Optical disk, F: Error while searching for files on optical data disk
SERIOUS: 2012-12-11 13:22:49, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:22:49, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:22:50, Optical disk, F: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:22:50, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:23:20, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:23:20, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:23:21, Optical disk, F: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:23:21, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:23:51, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:23:51, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:23:51, Optical disk, F: Error while searching for files on optical data disk
SERIOUS: 2012-12-11 13:24:22, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:24:22, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:24:22, Optical disk, F: Error while searching for files on optical data disk
SERIOUS: 2012-12-11 13:24:52, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:24:52, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:24:53, Optical disk, F: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:24:53, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:25:23, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:25:23, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:25:23, Optical disk, F: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:25:50, 2D Graphics, Surface lost: Restoring.
LOG NOTE: 2012-12-11 13:25:51, 2D Graphics, Surface lost: Restoring.
LOG NOTE: 2012-12-11 13:25:52, 2D Graphics, Surface lost: Restoring.
LOG NOTE: 2012-12-11 13:25:53, 2D Graphics, Surface lost: Restoring.
LOG NOTE: 2012-12-11 13:25:54, 2D Graphics, Surface lost: Restoring.
SERIOUS: 2012-12-11 13:25:54, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:25:54, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:25:54, Optical disk, F: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:25:55, 2D Graphics, Surface lost: Restoring.
LOG NOTE: 2012-12-11 13:25:56, 2D Graphics, Surface lost: Restoring.
LOG NOTE: 2012-12-11 13:25:57, 2D Graphics, Surface lost: Restoring.
LOG NOTE: 2012-12-11 13:25:58, 2D Graphics, Surface lost: Restoring.
LOG NOTE: 2012-12-11 13:25:59, 2D Graphics, Surface lost: Restoring.
LOG NOTE: 2012-12-11 13:26:00, 2D Graphics, Surface lost: Restoring.
LOG NOTE: 2012-12-11 13:26:01, 2D Graphics, Surface lost: Restoring.
LOG NOTE: 2012-12-11 13:26:02, 2D Graphics, Surface lost: Restoring.
LOG NOTE: 2012-12-11 13:26:03, 2D Graphics, Surface lost: Restoring.
LOG NOTE: 2012-12-11 13:26:04, 2D Graphics, Surface lost: Restoring.
LOG NOTE: 2012-12-11 13:26:05, 2D Graphics, Surface lost: Restoring.
LOG NOTE: 2012-12-11 13:26:06, 2D Graphics, Surface lost: Restoring.
LOG NOTE: 2012-12-11 13:26:07, 2D Graphics, Surface lost: Restoring.
LOG NOTE: 2012-12-11 13:26:08, 2D Graphics, Surface lost: Restoring.
SERIOUS: 2012-12-11 13:26:25, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:26:25, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:26:26, Optical disk, F: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:26:26, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:26:56, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:26:56, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:26:57, Optical disk, F: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:26:57, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:27:27, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:27:27, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:27:28, Optical disk, F: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:27:28, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:27:58, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:27:58, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:27:59, Optical disk, F: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:27:59, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:28:29, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:28:29, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:28:30, Optical disk, F: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:28:30, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:28:59, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:28:59, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:29:01, Optical disk, F: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:29:01, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:29:30, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:29:30, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:29:32, Optical disk, F: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:29:32, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:30:01, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:30:01, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:30:02, Optical disk, F: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:30:02, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:30:32, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:30:32, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:30:33, Optical disk, F: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:30:33, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:31:02, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:31:02, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:31:04, Optical disk, F: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:31:04, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:31:34, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:31:34, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:31:36, Optical disk, F: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:31:36, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:32:07, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:32:07, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:32:09, Optical disk, F: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:32:09, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:32:38, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:32:38, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:32:40, Optical disk, F: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:32:40, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:33:09, Optical disk, E: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:33:09, Optical disk, Naprava ni pripravljena. (21)
SERIOUS: 2012-12-11 13:33:11, Optical disk, F: Error while searching for files on optical data disk
LOG NOTE: 2012-12-11 13:33:11, Optical disk, Naprava ni pripravljena. (21)
LOG NOTE: 2012-12-11 13:33:13, Status, Test run stopped
Report by PassMark BurnInTest V7.0 Std, www.passmark.com, Report date: 11/dec/2012
miha121 ::
miha121 ::
Ali je možno.da je premalo ram-a(1gb)Mogoče e je zapacal?
amigo_no1 ::
Star/zanič napajalnik ?
miha121 ::
Tudi možno,napajalnik je;hkc sz-430 lpdr
[Win 7 in tudi 10] CPU 100% vendar različni procesi
Oddelek: Operacijski sistemi
132393 (2053) solatko
HP Pavilion dv7 reboot problem
92656 (2589) Yacked2
Apache - localhost JA, IP naslov NE
Oddelek: Omrežja in internet
187272 (7131) ManDriver
je grafična fuč
111433 (1235) nitro2
Sesuvanje win2k - mrxsmb.sys
332756 (2279) Bx
