Forum » Strojna oprema » AMD Radeon HD 7900
AMD Radeon HD 7900
Xserces ::
jao ce bi mu dela dnar bi uzeu 580 XD se mi zdi da se splaca pa pomoje bojo se mal znizal ceno XD
- spremenil: Xserces ()
ezzy ::
Počakaj vsaj dva tedna, da prispe konkurenca(nvidia 600 serija) in bodo cene veliko nižje ;)
A že spet. Machiavelli je govoril isto, kot ti 5 tednov nazaj "počakaj še dva tedna".
BALAST ::
Še opis najhitrejše tovarniško navite MSI R7970 Lightning
Tako da MSAA je bolj zahteven in porabi več spomina, tako je tudi slika bolj čista (posebno oddaljeni predmeti so bolj ostri proti FXAA)
Odličen performance, ampak cena je pa zasoljenih 620€ v EU.
MSAA - Multisamples only near edges. Afterwards downsamples to your resolution.
FXAA - Multisamples everywhere. Basically rendering into higher resolution, and then downsampling to your resolution.
With the same amount of samples:
Quality-wise, FXAA is at least as good as MSAA.
Performance-wise, FXAA should be a little bit faster than MSAA, but it'll eat up a LOT more GPU memory.
Implementing efficient MSAA in a deferred renderer is near to impossible, hence it'll die out in about two years.
"You may fool all the people some of the time;
you can even fool some of the people all the time;
but you can't fool all of the people all the time."
Xserces ::
Xserces ::
fireX88 ::
http://www.fudzilla.com/home/item/26439...
HAHAHHAHAHA
LOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOL
uuu bojo zelini nevoscljivi:-)
Pro_moted ::
http://www.computeruniverse.net/product...
navalite
Si ziher da je to prava cena? Ker na drugem linku pri isti trgovini je cena 342 eur ! ? Plus tega so vse ostale 7870 med 330-350. Da ni to pomota in cena za 7850 ?
FlyingBee ::
da dostavijo v Slovenio pa stane 40 EUR http://www.computeruniverse.net/cart_op...
New Sphincter Kvartet:
Janac ::
in? se vseeno 30e ceneje kot v slo.
lahko pa jih vec skupaj naroci in si potem razpolovimo postnino.
Razmišljam, da bi vskočil :D (čeprav sem za zamenjavo moje 4770 mislil kupiti 7770)
- spremenilo: FireSnake ()
Moti me predvsem to, da ne izpihuje vsega vročega zraka pri zadnjih režah...
FlyingBee ::
če nas je več kot 2 potem si bolj težko razpolovimo, mar ne
kako je z garancijo?
aja, pa glej kaj je zdaj napiasano, samo varka vse skupaj
not available
Product is no longer available. Only listed for information purposes.*
gigabytov oc na dinokomp je zdaj več kot včeraj, je bil typo očitno, da ni še tako v tej nemški
- spremenil: FlyingBee ()
FlyingBee ::
ja, no kakorkoli, smrdi že od samega začetka, vmes je pisalo unavailable, ...
dobro, učinek je dober, zdaj je veliko več ljudi pogledal na njihovo stran
fireX88 ::
na hoh.de so dokaj ugodne... pa tudi 7950 je že pod 390€...
Janac ::
BALAST ::
Nvidia je splanirala do potankosti, prvo so dali paper launch z OMEJENO ZALOGO gtx680 za cirka 500€.
Zdaj večina kupcev čaka na znižanje AMD grafičnih, ker pa se bodo ti zganili šele do maja bo povpraševanje po AMD radeonih padlo za 80%.
Takrat bo prišla nova zaloga gtx680 z VIŠJO CENO od 500€. Vmes bodo pa pri Nvidiji znižali ceno starejših grafičnih za 20%, ter tako totalno uničili konkurenco.
Do začetka poletja napovedujem take (nemške/avstrijske) cene:
gtx560ti 160€----hd6870 140€
gtx570 220€----hd6970 180€
gtx580 320€----hd7970 480€
gtx680 550€----hd7990 580€
Pro_moted ::
Radeon 7870 tam okrog 275-300 evrov, bi bil bomba :D
- spremenilo: Pro_moted ()
Jakob_X ::
WTF? Zakaj bi AMD tako nizke cene napram nvidii postavil? Se posebno pri 7990 si ga hudo polomil. Pod 800EUR je ne pricakovat.(ce bo 7970 nad 400eur) Verjetno bodo pa cene 680/7970 vec ali manj identicne, ker vsaj glede na prve rezultate ni videti da bi v visokih rezolucijah bila kaksna razlika v zmogljivostih.
Zeleni dolgo niso imeli kaj konkretnega pokazati, pa jih je bilo nemogoče "totalno uničiti".
Rdeči so dolgo samo prah žrli, pa jih ni bilo mogoče "totalno uničiti".
Ali nekateri sploh kaj pomislite, preden pišete te bedarije?
BALAST ::
Niso bedarije, ampak špekulacije.
fireX88 ::
dinokomp ma serijo 78xx najdrazjo 350€ kar ni slabo..ta ista je bla vceraj se 370..
x45 ::
Niso bedarije, ampak špekulacije.![]()
Ti še nisi napisal kaj drugea kot bedarije. Prede bo 680 na volojo bo ati veselo prodajal naprej. ko bo nvidia zunaj bo najprej sebi v skledo plunla, ker starih modelov ne bo kupoval nihče ( dragi potratni )
in ko bodo končno pricurljale ostale verzije 6xx bo konkurenca zaživela na polno.
mal bolj relano od tvojih nakladanj.
filip007 ::
"In soviet Russia, Radeon hits you"
Očitno smo ljubitelji rdečih, samo nVidia je pripeljala tokrat varčno grafično, ki je malenkost hitrejša. Novih grafičnih bo še na tone z obeh taborov se mi zdi, da je to komaj začetek...
Zero games, zero talk.
freesty ::
Če ma kdo kak kuler od 7950(OC verzija) viska, pac ce je dal vodno gor. Bi bil zlo vesel ce bi zamenju z reference kulerjem+doplacam.:)
Drugace pa so tele 79xx, kar zverine. 7950 imam navito na 1175/1650@1,175mV.
V uniginu dobim 80,2fpsja, ter score 1824.
http://www.youtube.com/watch?v=5hfYJsQAhl0
freesty ::
Saj se ze dobu Accelero Xtreme sam 80€ mi je mal vlk za dat, ker so tile OC hladilniki cist dobri.
Pesimist ::
Teh sem ze 10 naroco bom probo 2x cinkve sli.
http://www.dinokomp.si/product_info.php...
69charger ::
Haha js sem naročil,če bom dobil kakšen mail da je pomota bom pa pač preklical xD
69charger ::
Ah sem že dobil mail da ni izvedljivo -.- Škoda :P
fireX88 ::
Mislite ta bi s 7850 igral na resoluciji 1600x1050 bf3? z i2500k in 8gb rama?
bi! high/ultra z manj glajenja!
| » | Grafična kartica (strani: 1 2 )Oddelek: Kaj kupiti | 15832 (13943) | Brias |
| » | Najboljša grafična kartica pod 200EUR.Oddelek: Kaj kupiti | 6434 (5784) | Brias |
