Forum » Kriptovalute in blockchain » debata o Bitcoinu
debata o Bitcoinu
"our opinion is we generally try to stay hands off unless they are breaking other site-wide rules"
Aha, torej ena pravila lahko kršijo, zgolj druga ne smejo?
kingsix ::
Mja, če so feeji za 1h transkacijo pod 20€ gre za shitcoin. To je kriterij, right? Neke druge razlike ni...
Samuel ::
Koji je tebi kurac? Nič drugega ne počneš, kot samo serješ proti BTCju. Ukvarjaj se raje s svojim šitkoinom (ETH).
noticably not worth noticing.
Siddh ::
Ve kdo za kakšno rešitev prenizkega feeja za transakcijo? Narobe sem preštel decimalna mesta in sem poslal transakcijo naprej. Seveda sem to ugotovil čez dva dni ko se še kar ni pokazala na krakenu.
lambda ::
Siddh > Ve kdo za kakšno rešitev prenizkega feeja za transakcijo? Narobe sem preštel decimalna mesta in sem poslal transakcijo naprej. Seveda sem to ugotovil čez dva dni ko se še kar ni pokazala na krakenu.
https://en.bitcoin.it/wiki/Transaction_...
- spremenil: lambda ()
Siddh ::
ViaBTC javi, da je prenizek fee, na confirmTX sem dal dva dni nazaj, se še ni nič zgodilo. na BTC.com pa se ne znajdem.
kingsix ::
trigger time!
https://powercompare.co.uk/bitcoin/
Future tech.
Bitcoin Mining Now Consuming More Electricity Than 159 Countries Including Ireland & Most Countries In Africa
If it keeps increasing at this rate, Bitcoin mining will consume all the world's electricity by February 2020.
Future tech.
lambda ::
kingsix > In the past month alone, Bitcoin mining electricity consumption is estimated to have increased by 29.98%. If it keeps increasing at this rate, Bitcoin mining will consume all the world's electricity by February 2020.
According to Digiconomist's Bitcoin Energy Consumption Index, as of Monday November 20th, 2017 Bitcoin's current estimated annual electricity consumption stands at 29.05TWh. That's the equivalent of 0.13% of total global electricity consumption.
Saj ne rečem, da je to ravno lepo. Ampak nihče ne ve koliko točno se zares porabi v točno določenem mesecu. Oceno razlike med dvema mesecema je nekdo iz riti potegnil in predpostavil linearno rast za vnaprej (pri tem pa zamižal glede preteklih 8 let trenda). Skratka to tvoje nabijanje veliko pove o tem, da ne premoreš nobene kritičnosti pri nabiranju informacij.
kingsix ::
still : POW je nepotrebno potraten. Treba bo najt kaj bolj učinkovitega.
Glede moje kritičnosti pri nabiranju info: take članke preletim na hitro ker me boli k* glede tega. Pravzaprav sem z pisanjem tega zdaj porabil bistveno več časa kot z branjem članka.To da je POW nepotrebno potraten vemo vsi in ni potrebe po kakršnemkoli članku. Je pa zabavno take zadeve postat tukaj malo za troll.
fun fact: Ethereum ima sedaj večje število dnevnih transakcij kot vsi ostali blockchaini skupaj, vključno z BTC. Pa ni velikih feejev in težav. Sicer je pa še vedno POW kar je crap.
- spremenilo: kingsix ()
A. Smith ::
Če je tvoja transakcija premalo plačana, da bi šla v bloke, se nahaja v t.i. mempoolu in lahko teoretično še vedno razpolagaš s temi sredstvi, odvisno od denarnice. Če lahko razpolagaš, potem še enkrat ponovi transakcijo z večjim fee-jem. Transakcija, ki pride prva skozi, obvelja, druga se razveljavi.
Če te možnosti nimaš, boš moral počakati na to, da gre transakcija skozi. Ker je mempool zelo zabasan, lahko traja več dni, žal.
Edit - tole si preberi: https://bitcointalk.org/index.php?topic...
"Be professional, be polite,
- General James Mattis
- spremenil: A. Smith ()
trigger time!
To je tak, kot če rečeš, da ima ZDA več jedrskih konic, kot 159 drugih držav skupaj.
sarma832 ::
Če si dal premali fee, potem z denarnico ki omogoča double spend še enkrat pošlji ampak z višjim feejem.
BTC-ji so še vedno pod tvojo lastjo. Nepotrjene transakcije čakajo v mempoolu.
Torej lahko podpišeš(oz "pošlješ") novo transakcijo in tokrat z višjim feejem, če plačaš dovolj velik fee bo tvoja transakcija izbrana in vključena v blok.
Druga opcija je accelrator(viaBTC ga ima), v kolišni meji to deluje pa ne bi vedel, ampak glede na to da minerji lahko poljubno izberejo transakcije, bi lahko delovalo.
Edit; "double spendaj" glede na to da je to zastonjska storitev viabtcja, sem mislil da obstaja kaj proti plačilu
Sicer pa me popravite če pišem bedarije, ker tut sam čisto nevem
- spremenilo: sarma832 ()
kakob ::
Fun fact: na tem planetu vsak dan iz človeških riti prileze več kakca kot iz zemlje izkopljejo zlata. So what of it?
Mja, če so feeji za 1h transkacijo pod 20EUR gre za shitcoin. To je kriterij, right? Neke druge razlike ni...
Zadnjič sem plačal ~150eur fee za transakcijo iz offshore banke. Trajalo je en teden da se je sprocesirala.
Immutable bitcoin transakcija, 3 evre.
Nakup prepovedanih substanc na darknetu, 200 eur.
Smejanje kingsixovem idiotizmu, neprecenljivo.
Za vse ostalo je tu shitcoin.
- spremenilo: kakob ()
kakob ::
Bitcoin bo tle samo zato, ker je bil prvi. Tko kot dolar.
XRP in podobne valute se bodo pa dejansko uporabljale za transakcije, ker so dejansko cenejše in celo zmorejo prenesti promet, ki bi ga bilo potrebno pohendlat, da bi zadeva nadomestila/pocenila SWIFT/SEPA nakazila.
Bitcoin je za te zadeve prepočasen in predrag.
A tebe so ob tla metali ko si bil še otrok?
kingsix ::
Tu glede offshore bank nekaj bluziš ali pa te nekdo napizduje, da plačuješ take feeje. Simpl.
lambda ::
kingsix > Tu glede BTC nekaj bluzim ali pa me nekdo napizduje, da plačujem take feeje. Simpl.
Fixed.
Fixed.
kingsix ::
Kje pa je kaj bluzenja?
Navedel sem naslednje informacije:
- BTC ima POW
- BTC ima visoke feeje (oz govoril sem za pred časom, ko so bili še višji)
- In še oni fun fact: Ethereum ima več transakcij kot ostali (53,1% https://bitinfocharts.com/cryptocurrenc...
Prosim pojasni kaj od tega ni res ali pa take nepotrebne komentarje obdrži zase. No morda jih lahko poveš kakim otrokom, ki so na enakem razvojnem nivoju kot ti.
- BTC ima POW
lambda ::
Trdiš, da je za BTC treba plačevat 22 € feeja za transakcije.
kingsix > Ethereum ima sedaj večje število dnevnih transakcij kot vsi ostali blockchaini skupaj
Tudi to sicer ni res, ker na tistem grafu manjka kar nekaj blockchainov, ki ethereum presegajo po številu transakcij.
kingsix ::
Citiraj me kjer sem rekel, da je TREBA plačevat 22EUR za transakcije. Cite.
Naštej te blockchaine in vire informacij.
Na grafu so dejansko vsi (no pač ti znani), če klikneš tisto magično puščico pri 1/2, so še ostali.
lambda ::
Rekel si, da si plačal 22EUR za transakcijo in kasneje tudi, da je očitno kriterj za shitcoine manj kot 20EUR transakcije (kar naj bi ločevalo BTC od shitcoinov).
Jih je več, za to, da pokažem, da se motiš je pa dovolj, da navedem enega:
Ethereum: Highest number of 546837 Transactions on Friday, October 20, 2017
Steemit npr se bliža milijonu:
Over and out, se mi ne da več s tabo, sem dokazal, da nimaš pojma.
kingsix ::
Kot si sam rekel: rekel sem da sem plačal toliko. Ne pa da je ptorebno toliko plačevat za vsako transakcijo. Takrat sem rabil BTC'je drugje in to zelo hitro in sem pač moral toliko plaačt, mislim da sem navedel da 10 min. Ja, shitcoini imajo veliko nižje transkacije. Nisem pa rekel da bi bilo 20EUR ptorebnih za vse transkacije na splošno, dal sem primer 1h, kar je bilo v navalu res. No navalu..nekaj več transkacij je bilo in minerji so malo preklopili na BCH..pa se že švica.
Ne polagaj mi besed v usta oz. na tipkovnico.
Steem pa ima popolnoma drug namen kot kriptoValute o katerih se mi pogovarjamo. TI nimaš pojma. Steem vključuje vse kot transkacijo, čeprav to niti niso. Polek tega pa je pol-centraliziran. Z razlogom, ga res nikjer ne štejejo, ko se govori o transkacijah. B* Please.
lambda ::
Bi te Ripple: https://xrpcharts.ripple.com/#/metrics, ali pa Bitshares, ki ga tudi presega, kaj bolj zadovoljila?
Ethereum je tudi pol-centraliziran. Forka vsakič, ko Vitalik reče.
Law_Enforcer ::
Ne vem, če je že bilo govora o tem, ampak:
Bitcoin - online od 2009, stabilen in varen ves ta čas (velika črna pika sicer dogodki avgusta 2010, ko si je nekdo uspešno naredil milijarde BTCjev, a je bilo opaženo v par urah in popravljeno)
Ethereum - online od 2015, v tem času DAO hack, $300 mio. zaklenjeno v Paritiy-u.
Vem kateremu sistemu bolj zaupam kot trajnemu hranilcu vrednosti.
Pa še: v Ethereumu je "koda zakon", Vitalik pa kralj, kar tudi ravno ne vzbuja zaupanja v trajno odpornost sistema proti cenzuri in nadzoru. IMO kriptovalutam vrednosti ne daje hitrost in nizka cena transakcij, ampak decentraliziranost, odprtost, odpornost, stabilnost, to pa izkazuje le BTC.
Law_Enforcer ::
Bitcoin kot hranilec vrednosti ima prihodnost, kot valuta pa ne preveč?
V trenutnem stanju ne. On-chain scaling je absolutno neizvedljiv v obsegu, ki bi bil potreben, da kot plačilno sredstvo konkurira plačilnim/kreditnim karticam. S povečevanjem blokov pa hitro trčiš v problem centraliziranja sistema oz. vsaj občutnega zmanjšanja trenutne decentraliziranosti. Že sedaj pa je na voljo segwit, ki kapaciteto sistema poveča za ~ 2x, težava pa je v tem, da še ni v splošni uporabi - na eni strani ga še prav ne podpira niti core client, po drugi strani pa ga ne uporabljajo nekateri veliki igralci, ki ravno jamrajo o visokih feejih in zapolnjenosti blokov (npr. Coinbase).
V delu so 2nd layer rešitve, ki pa so še v alfa ali max. beta fazi.
Pa da ne bo kdo mislil, da je težava z on-chain scalingom omejena na BTC. Je prekletstvo vseh kripotvalut.
kingsix ::
Aja ker imamo 4 ETH'je?..aja eh sem zamenjal z BTC. My bad.
Spet - Ripplesluži popolnoma drugi funkciji kot Bitcoin in ostali blockchaini. Je pre"mined", nima potrjevanja transkacij etc. na enak način "normalni" blockchaini, vprašljiva decentralizacija. Tudi XRP je nekaj povsem drugega kot BTC itd. je le medij izmenjave znotraj Ripple networka. še Ripple (podjetje) ne brandajo XRP kot nek cryptocurrency. Poslušaj kdaj Ripple CEO'ja.
Off-chain rešitve so pa niso rešitve...https://medium.com/@jonaldfyookball/mat...
kingsix ::
Law_Enforcer je izjavil:
Bitcoin ima tudi community kjer se ne zmenijo glede najosnovejših in nujnih sprememb. Community ki cenzurira reddit in napada vse okrog sebe. Samo, da se še dalje drži status quo in zaslužki minerjev.
DOA hack in Parity pa nimata veze z samim Ethereum blockchainom, ampak so slabo spisani smart-contracti 3rd party developerjev. To je enako kot da bi razvil kak modul za SAP z kritičnim bugom, nato pa bi krivili sam SAP.
Sicer pa, če se zmenijo takoj povečam delež kripto v BTC. Zdaj sem sicer bolj na IOTA od 32 centov naprej. Se je zelo splačalo.
Law_Enforcer ::
Ne da se mi pisati traktatov, poleg tega pa verjetno niti nimam vseh informacij, zato le to;
Vsekakor ima Bitcoin težave, ampak rešitev po mojem ni fork, pri katerem so glavni akterji fanatik Ver, Jihan Wu (zakaj so glavnemu minerju v interesu nizki feeji pri transkacijah?) in Faketoshi Craig Wright (ki je poleg tega bojda še fake dr.).
sarma832 ::
Off-chain JE resitev. To da je Ln 'centraliziran' je vseeno, se vedno si samo ti lastnik bitcoinov. Ce hub crkne ne mores zgubiti bitcoinov, prav tako hub nima dostopa do tvojih btcjev.
LN bo integriran v wallete in bos lahko posiljal skoraj zaston transakcije in pa instant bodo.
Ce jim to rata, bodo zagotovo merchanti zaceli z tem eksperimentirat... Ce bo demand
xabre ::
A se ne zgubi pol mal bistvo blockchain tehnologije? Ker pač ne bodo več gor čisto vsi podatki, ampak samo končni rezultat.
miko22 ::
ah, ta Kraken
In zakaj?
Your order may have failed. Please refresh the page and check your orders. Contact support if necessary.
In zakaj?
DOOM_er ::
mah, vedno ko potrebuješ ne gre
 kraken pač
- spremenil: DOOM_er ()
Siddh ::
Je kaka dobra alternativa za kraken z nizkimi provizijami za trgovanje? != minut že poskušam prodat pa ne gre skozi :D
kraken je dober za tiste s šibkimi rokami; dostikrat bi taki prodali prehitro, kraken pa poskrbi da ne naredijo neumnosti...
kakob ::
slotechar ::
Danes naj bi bil nov fork. Holderji bitcoina bodo prejeli 10 bitcoin diamond za vsak bitcoin. :) kot zanimivost.Pred 495866 block
- spremenil: slotechar ()
slotechar ::
Bitcoin diamond dobite, lahk pogledate uradno stran bitcoin diamond katere borze ga podpirajo. http://www.btcd.io
slotechar ::
Bodo pa razdelili bonus 500 bitcoin diamond uporabnikom. Odvisno kolk nakazil bo :) https://gate.io/signup/619217
kingsix ::
To da kingsix nima pojma že vrabci čivkajo tu v Aziji.
Pa vendar ne znaš odgovorit na nobeno vprašanje/argument, ki ti je postavljen. Svoje neznanje in fantaziranje nadomeščaš s žaljenjem. Pravzaprav na vse odgovoriš le z tem. Bravo. Si res pravi pripadnik BTC "communitiya".
kakob ::
sarma832 ::
Kraken naj bi decembra posodobil svoje sisteme.
Sicer pa če znaš implementirat replay protection, narediš svoj Bitcoin X fork, nekaj premina pa imaš $$$... Čeprav bounty za implementacijo replay protectiona pri BTG je bil 30k$.
