MySQL sql mode in dodaten auto increment pri izvozu (obrazložitev)?
Housy ::
Pozdravljeni,
bi mi lahko nekdo prosim obrazložil, kaj pomeni spodnji sql mode pri izvozu tabel:
SET SQL_MODE="NO_AUTO_VALUE_ON_ZERO";
zanima me tudi, čemu služi dodaten auto increment na koncu strukture tabel?
CREATE TABLE IF NOT EXISTS `uporabniki` (
`id` smallint(3) NOT NULL auto_increment,
`uporabnik` varchar(15) collate utf8_slovenian_ci NOT NULL,
`geslo` varchar(32) collate utf8_slovenian_ci NOT NULL,
PRIMARY KEY (`id`)
) ENGINE=MyISAM DEFAULT CHARSET=utf8 COLLATE=utf8_slovenian_ci AUTO_INCREMENT=2 ;
Lp in hvala,
Housy
overlord_tm ::
NO_AUTO_VALUE_ON_ZERO affects handling of AUTO_INCREMENT columns. Normally, you generate the next sequence number for the column by inserting either NULL or 0 into it. NO_AUTO_VALUE_ON_ZERO suppresses this behavior for 0 so that only NULL generates the next sequence number.
This mode can be useful if 0 has been stored in a table's AUTO_INCREMENT column. (Storing 0 is not a recommended practice, by the way.) For example, if you dump the table with mysqldump and then reload it, MySQL normally generates new sequence numbers when it encounters the 0 values, resulting in a table with contents different from the one that was dumped. Enabling NO_AUTO_VALUE_ON_ZERO before reloading the dump file solves this problem. mysqldump now automatically includes in its output a statement that enables NO_AUTO_VALUE_ON_ZERO, to avoid this problem.
Torej, to naredis zato, da lahko normalno uvozis obstojece podatke v tabele. Pri CREATE TABLE ti tist AUTO_INCREMENT nastavi naslednjo AI vrednost, da ne bo zopet zacelo od 1 ostevilcevati.
Housy ::
Hvala overlord :)
Lp, Housy
MySql Vprasanje - problem dupliciranih kljucev
Oddelek: Izdelava spletišč
131907 (1729) KernelPanic
FULLTEXT indeksi - problemi pri osnovnem primeru
Oddelek: Programiranje
61229 (1150) barelyLegal
mysql vnos
52033 (1998) asgard2.0
portal ostal, baza sla
62332 (2217) bombacina
SQL problem
91961 (1798) Bossek
