Forum » Igre » Battlefield 3
Battlefield 3
Skyman ::
Bom spremljal pa pridem kaj gor na server pogledat redkivca 79
- spremenil: Skyman ()
BigWhale ::
Armored warfare se ne splača, ker nebo novih pušk, pa štiri mape in vozila so premalo. Za 15 € bi moral dobit 20 map /30 pušk in 20 novih vozil.
Kwa za 20 map pa za 30 pusk pa 20 vozil je cist premal za 15 EUR... Jest cem vsaj 150 novih pusk pa 150 novih vozil! Hocem, ne hocm, ZAHTEVAM, da lahko vozim tud smetarski tovornjak pa Tomo Vinkovic traktor pa Sip Sempeter moto kultivator! Med orozji pa zahtevam tud kuhinjski mesalec in toilet plunger!
Banda lopvska!111
SlimDeluxe ::
Namesto protipehotne mine pa bananin olupek :)
Desktop: R5 3600X | MSI MPG B550 | RX580 8GB | 32GB DDR4 | be quiet! 650W
Laptop: Lenovo ThinkPad T15 G2 | i7-1165G7 | 32GB DDR4 | 15" FullHD IPS
r3dkv1c4 ::
tinlad3n ::
Česa naprimer? Vse novejše špile laufam na high nastavitvah.
specifikacije???
lahko igras samo na 20 fps in en k...kvaliteta slike na resoluciji 1280x1024 to lahko ja.
System Information
Time of this report: 7/2/2012, 17:28:54
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120503-2030)
Language: Slovenian (Regional Setting: Slovenian)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: EP45-UD3LR
BIOS: Award Modular BIOS v6.00PG
Processor: Intel(R) Core™2 Quad CPU Q9400 @ 2.66GHz (4 CPUs), ~2.7GHz
Memory: 5120MB RAM
Available OS Memory: 5118MB RAM
Page File: 2131MB used, 8103MB available
DirectX Version: DirectX 11
Display Devices
Card name: AMD Radeon HD 6850
Manufacturer: Advanced Micro Devices, Inc.
Chip type: ATI display adapter (0x6739)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_6739&SUBSYS_21F81458&REV_00
Display Memory: 3314 MB
Dedicated Memory: 1011 MB
Shared Memory: 2303 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: SMB2230H
Monitor Id: SAM0648
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Nastavitve imam na high in igram na 64 large conquest mapah z 64 folka in imam 45 - 60 fps.
Proc imam navit na 3ghz.
Happy?
- spremenil: tinlad3n ()
SloSlayer ::
Zanima me, ali so vam tistim, ki ste kupili RU verzijo igre bannali accounte ali ne, ker razmišljam o nakupu RU verzije.
Berserker ::
Banda lopvska!111
Sklepam da je to sarkazem. Ironično je da v nekaterih igrah skoraj vse tvoje "želje" dobim zastojn, medtem ko EA napove da bo veselo štancal dodatke še naprej. Seveda sem ciljal na project reality. Redkvica ti očitno kupljen izdelek rad doplačuješ, pa če bo 30 novih razširitev boš dal 450 €, samo zato da ostaneš cool kakor ea narekuje.
sennheiser ::
specifikacije???
System Information
Processor: Intel® Core™2 Quad CPU Q9400 @ 2.66GHz (4 CPUs), ~2.7GHz
Memory: 5120MB RAM
Display Devices
Monitor Id: SAM0648
Output Type: HDMI
Happy?
Če pa ti na high na full hd laufaš pa da maš 60fps... dej no :D ne se smešt... Jst mam na i7 920 4ghz pa gtx 580 pa mam na ultra 60 fps z 4xAA. Ti če maš 40 fps average si lahko veseu.
r3dkv1c4 ::
ÄŒesa naprimer? Vse novejĹĄe ĹĄpile laufam na high nastavitvah.
specifikacije???
System Information
Processor: IntelŸ Core™2 Quad CPU Q9400 @ 2.66GHz (4 CPUs), ~2.7GHz
Memory: 5120MB RAM
Display Devices
Monitor Id: SAM0648
Output Type: HDMI
Happy?
ne prodajaj buč!!!
r3dkv1c4 ::
Banda lopvska!111
Ne filozofiraj....dalec od tega....noben špil se ni mel 30 dodatkov....in malo pomisli kaj govoriš....
V primeru bf3 so ti dodatki razpotegnjeni do 3/13 ja in ne blodi o nekih 450€.
Zbudi se!!!
tinlad3n ::
sennheiser je izjavil:
specifikacije???
System Information
Memory: 5120MB RAM
Display Devices
Monitor Id: SAM0648
Output Type: HDMI
Happy?
Dej beri človek: "in imam 45 - 60 fps"
Tole pa je tvoj prejšnji post: "lahko igras samo na 20 fps in en k...kvaliteta slike na resoluciji 1280x1024 to lahko ja."
Tole je pa tvoj zdejšnji post: "Ti če maš 40 fps average si lahko veseu."
Kdo se pol smeši.
BigWhale ::
Ne, samo ti ne razumes, da z nakupom BF3 + BF3 Premium marsikdo ne doseze cene 0.5 EUR za eno uro zabave. Kar je smesno poceni. Sedenje v gostilni te drazje pride, heck, sedenje ob pivu doma, pred televizijo te drazje pride.
Kdo se pol smeši.
Smesite se vsi, ki citirate pol metra texta in na koncu dodate eno ali dve kratki vrstici.
- spremenil: BigWhale ()
sennheiser ::
Jst ti nism reku da maš 20fps na taki resuluciji... ti mal ber. Ampak enostavno ni šanse da maš toliko average na mapi kjer je 64 igralcev. Na singlci mogoče pa na mapah kjer je 16 igralcev.
Kamorkoli se pogleda je povprečje okoli 45 na taki grafiki. Pa si sam iz glave ti to reku ali si konkretno s frapsom sprobal?
tinlad3n ::
render.drawfps 1 v konzolo.
Lej pod 45 ne pade, lahko ti pošljem kak SS, movija ti ne morem, ker mi šteka, če snemam z frapsom na teh settingsih.
cebelar123 ::
69charger ::
Eni se ne morejo sprijazniti da lahko tudi z konfiguracijo, ki je pol počasnejša od njihove spodobno goniš igro.
fireX88 ::
pa še velika verjetnost je, da si boljši
54j0 ::
Problem je prej v tem, da nimajo vsi istih standardov, kar se tiče "spodobne" zmogljivosti. Sicer pa sem imel tako HD 6850, kot gtx 580. Z obema se da lepo igrati, a hd 6850 pač ni sposobna high/ultra (+hd ločljivost..) nastavitev pri udobnih 60 fps. Ali tisti, ki to trdi, laže, ali pa ima neko čudno nastavitev, ki okrni grafične bombončke.
tinlad3n ::
Ma lej meni je čisto vseeno kaj ti verjameš.
Važno je da jaz vem kaj dogaja pri meni in to je to.
54j0 ::
Fair enough. Samo to mi še razloži, če ti ni vseeno, seveda.. Igro poganjam na high nastavitvah (in celo brez AA), aftrerburner pa mi kaže video memory usage čez 1200 Mb. Kako lahko tebi gladko teče pri istih nastavitvah, ko pa imaš le 1 Gb video ram-a (shared memory je parkrat počasnejši spomin in je samo "za silo")?
Pač, vsi nekako vemo, da se bo igra zatikala, ko ji zmanjka gpu/cpu moči, ali pa zmanjka video/sistemskega spomina.
Sicer pa niti slučajno nočem blatit hd 6850, ker je čisto spodobna kartica. Na njej mi je bf3 tekel tekoče (sepravi konstantno 60+ fps) ob mešanici medium/high nastavitev.
Če bi se nehali v tej temi prerekati kdo ima 15, 40 in kdo nemore imeti 60 fps bi bilo super, ker je to - smetenje teme z nekimi zelo osebnimi konfiguracijami posamznika..
..če si lahko dovolim dodati.. tnx
54j0 ::
Veš da si lahko dovoliš
. Samo ne pozabi, da nekateri (upam, da večina) igramo to igro na PC in je razprava glede performance čisto na mestu.
sennheiser ::
Točno tako. Zdj sam res edini razlog vidim da maš res toliko je ta, da maš sicer vse high ampak ostale nastavitve ala aa pa izkloplen... pa novi windowsi
tinlad3n ::
AA je na 6x. Motion blur disablan ker smrdi.
Zdej spet je vprašanje kaj so to high nastavitve. Lahko imaš preset high ali pa nardiš custom nastavitve na high pa se malo poigraš z aajem in ostalimi "podobnimi" zadevami.
54j0 ::
AA je v bf3 največ 4x, razen, če si nastavil v aplikaciji svoje grafične kartice (catalyst/nv cpanel). High nastavitve in AA (msaa) ti iz te kartice niti slučajno ne vržejo konstantnih 60 fps. Prej povprečnih 30 in max 60 (ko je scena res nezahtevna).
Oprosti, ampak jaz ti enostavno ne morem verjeti, da ti igra deluje gladko pri teh nastavitvah. Neizvedljivo je. Še dvema takima karticama v crossfire bi se kolcalo, že samo na račun video spomina.
tinlad3n ::
Evo moje nastavitve prepisane iz BF:
Grafhics Quality: CUSTOM
Texture Quality: HIGH
Shadow Quality: HIGH
Effects Quality: HIGH
Mesh Quality: HIGH
Terrain Quality: HIGH
Terrain Decoration: HIGH
Antialiasing Deferred: 2x MSAA
Antialising post: HIGH
Motion Blur: OFF
Motion Blur Amount: 0
Antistropic Filter: 6x
Ambient Occlusion: SSAO
In ne windowsi niso fresh ampak če človek zna vzdrževat potem ni treba na 2 tedna format narest ane ;)
Zdej pa lepo prosim dovolj ok? Misli si kar želiš, meni je vseeno.
Mesh Quality: HIGH
Motion Blur: OFF
r3dkv1c4 ::
seveda laže...sam sem imel hd5850 overclockano pa zdaj imam hd 6950 navito in proc navit na 3.5ghz in komaj dosežem 60 fps na fullhd resoluciji na 4x aa ultra nastavitve pa me ne bo prepričal da mu 6850 pele čisto....na 64 playerjev...na 60 fps...hahaha buče!!!!
posnemi špil , pokaži nastavitve pa fraps zalaufaj pa da te vidmo!!!!!
- spremenil: r3dkv1c4 ()
r3dkv1c4 ::
hvala kolega da si ga razsvetlil namesto mene.
r3dkv1c4 ::
fireX88 ::
sm za ziher..to je server insiders slovenia?? ker enkrat sem ga iskal pa nisem našel. Pa še to je hc ali normal??
Skyman ::
ja iNsIDERS SLOVENIA se imenuje server je pa normal ni hc.Tud meni se zdi da je server bil nekaj casa nazaj na bf3 sceni ker sm ga imel pod favorite potem ga ni bilo več.
fireX88 ::
ah pol si kr mejte normal... ko bo hc se kaj oglasim, prej pa ne!
BigWhale ::
Veš da si lahko dovoliš. Samo ne pozabi, da nekateri (upam, da večina) igramo to igro na PC in je razprava glede performance čisto na mestu.
Ne ni, meni dol visi kako teb dela in zakaj ti tko dela in zakaj mas ti vec FPS od "njega".
Ziga, Omy, Mavrik in jaz pridemo pogledat ce prestavite na HC.
Normal je cist brez veze. :P
54j0 ::
Jah, potem te igre in računalniki ne zanimajo in je najbolje, da pc prodaš, ter se spraviš štihat vrt.
BigWhale ::
Ne, ne razumes. Men dol visi zakaj teb dela hitrej kot njemu in zakaj potem on trdi da ti ne more delat tolk hitr (al kakrsna koli je ze situacija), me pa zanima kako lahko s tankom sestrelim helikopter.
mihec87 ::
BigWhale je hotel rečti da ga ne zanima merjenje e-penisa..tako kot še marsikoga ne..Pač pa igra oz igranje..
Tako ali pa tako če si gdo zmisli npr koliko fps ima njegov problem pač..
- spremenil: mihec87 ()
54j0 ::
Eh. Ne vem, kaj sta vidva razbrala in po pravici povedano, je to s penisom že malo čudno. Od kdaj je sporno omeniti povezavo zmogljivosti pc-ja in igro, ki je do neke mere odvisna od le-te zmogljivosti. Če se vama je slučajno zdelo, da je nekdo omenil, da je to edini faktor, pa še enkrat preberita. Če vama je težko brati, da imajo nekateri višje standarde od vaju, pa slaba sreča.
mihec87 ::
Že dobro stran se preganjate kak nemore pa kak lahko ma tok fps je že bedno..
Glede standarda pa grow up..
54j0 ::
Verjetno nisi zastopil, kateri standard sem mel v mislih :). Pač je naletelo na to temo. Namesto, da se pritožuješ, spremeni temo na nevsiljiv način, ali pa čakaj, da bo konec. Btw - iskanje prepira NI nevsiljiv način.
- spremenil: 54j0 ()
mihec87 ::
Jasno je da otroke v peskovniku moreš potegnit narazen ko se začnejo obmetavat ali pa jih zamotiš da jih pokličeš na sladoled, pa zgleda to ne drži samo za peskovnik....
Pač če laže glede fps laže tako samemu sebi, glede na to da še do sedaj ni predložil posnetka..
54j0 ::
Hočeš reči, da te omenjeni posnetek zanima?
mihec87 ::
Ne..ker je to koliko fps ima njegova stvar/težava, saj ne igram na njegovem računalniku...
Kenpachi ::
U vidm da je kar živa tema tle :)
Zgleda, da dosti stjevcev nabija bf3, the next best thing after Enemy Territory...
Zaraki Kenpachi.
- spremenil: Kenpachi ()
