AMD Bulldozer
AMD Bulldozer
Molde321 ::
Poleti že pridejo Steamrollerji (28nm)? A se ni govorilo, da šele naslednje leto?
x45 ::
Bomo vidli, upam da čimprej.
AMD x4 965 BE, 8 gb ddr3 1600, SSD Samsung, 960 GT
Xeon x3430, 8 GB DDR3, Matrox grafa
gendale ::
jp, čim več konkurence za intel, bolje za nas
http://pastebin.com/QiWny5dV
filip007 ::
Je Fr4nc naredil GFlops test?
http://www.softpedia.com/get/System/Ben...
Sem naredil eno primerjavo med Vishero okoli 45(GFlops), Core i5 okoli 70G(Flops) in Epiphany-IV 64-core 28nm naj bil 100(GFlops) to stane dev.plata okoli 100€.
Zero games, zero talk.
AMD je najavil nove SoC čipe.
filip007 ::
No tole me je zanimalo...
"A key reason for the unmatched efficiency of the Epiphany-IV chips comes from early access to Globalfoundries leading-edge 28nm SLP technology. The industry to date has been challenged by the 28nm process node, but the Epiphany chip was able to exceed expectations in terms of performance, the two companies said."
http://www.xbitlabs.com/news/cpu/displa...
Kdaj bo kaj iz tega je vprašanje, če bo cela plata stala 100€ in bila močna kot Core i5, za 5x manjšo ceno, potem je to to.
V bistvu gre tukaj za FPU, ki ga ARM potrebuje.
gendale ::
odvisno kdaj izide in kako bo swju uspelo izkoristit 64 jeder
SuperVeloce ::
The Epiphany IV chip includes 64 independent high-performance RISC cores on a single chip that operates at up to 800MHz, effectively offering over 50GHz of achievable programmable performance...
whatever. scaling na njih ne vpliva?
Spock83 ::
Da ni spet AMDejv marketing...
Brane22 ::
Kakšen AMDjev marketing ?
Tole je zasnovala Adapteva, GloFo pa zapekel v silicij. Veze nima z AMDjem.
Spock83 ::
in kaj potem to dela v tej temi? ;)
Brane22 ::
Pojma nimam.
filip007 ::
Lahko bi ločeno temo naredil, 90(GFlops) za 150EUR, ker ga je pa naredil GloFo, sem pa tukaj, to da ven dvojno zmogljivost od Vishere, bi pa rad videl Sunspider test še gor.
http://www.racunalniske-novice.com/novi...
  • spremenil: filip007 ()
Brane22 ::
V bistvu ni tako. Stroja nista primerljiva.
Vishera je klasičen CPU, tole je bolj podobno polju shaderjev.
Stvar je rezultat prej premišljenih pazljivo zastavljenih kompromisov.
Kar pomeni, da tole niti slučajno ni nek splošen multicore, uporaben za širok spekter problemov.
Zelo zanimiva zadeva ( potencialno) ampak ni v isti dirki kot x86 stroji.
Parallela je primarno namenjena učenju paralelnega programiranja. Teh 64 jeder ni vidnih direktno OSu, da bi jih uporabljal, pač pa lahko do njih dostopaš podobno kot do npr. GPUja (OpenCL ipd). Podrobnosti bomo izvedeli, ko bodo objavili SDK in dokumentacijo, podobnosti z AMD pa res in veliko. No, mogoče bo način dela s tem primerljiv z AMDjevo HSA iniciativo. Upajmo.
AMD slashes desktop CPU prices
cca. 10-19% pocenitev.
Richland APU je pred vrati.
Janac ::
Taka cena ob splavitvi...uf
Brane22 ::
Pa ni boljši 8350 za tistih €50 več ?
Stvar je na 10% višjem taktu in nekako 10% je hitrejša na istem, torej 20% več CPUja.
Paš še cena bo šla verjetno te dni dol.
filip007 ::
Virtual memory? kaj je to Brane pomagi.
http://www.techspot.com/news/52415-amds...
zgleda neki podobnega kot CMA..
Brane22 ::
hUMA :)
SuperVeloce ::
Zanimivo napisan članek, glede na omejene informacije...
Isotropic ::
eh saj je znano, da bosta oba tabora prej ali slej na "heterogenem" racunanju. en bo do tega prisel pac prek grafike on-die, drugi pa verjetno prek kaksnega avx (v prihodnosti) - larrabee.
Brane22 ::
Sem že mislu vprašat o CPU nasledniku Piledriverja, pa sem našel svež odgovor:
Centurion
Centurion je za "overclock" segment. Naslednik Piledriverja je Steamroller.
Brane22 ::
Saj. Ampak bilo je rečeno, da bo zadnji CPU Piledriver, naprej pa samo APUji.
Potem je bila novička o Steamroller Opteronih, sedaj pa še o CPUjih za navadne mašine.
Zdaj vemo, da bodo na voljo vsaj high-end zadeve.
Si me pa ujel nepripravljenega. :D
Zabavno tole ... brat, kako novinarji sploh ne dojamejo, za kaj se zares gre. HPC svet že vse od pojava GPUjev zahteva skupni pomnilnik, sedaj ga bo končno tudi dobil :)
Pa še nekaj špekulacij: šušlja se že, da bo naslednji amdjev korak zamenjava x86 jedr z arm jedri v skupnem cpu+gpu čipu. Na misel mi je prišlo pa še nekaj drugega - današnji ati gpuji so vliw zadeve, da? Se še spomnite Transmete in njihovih Crusoe vliw procesorjev, ki so prevajali x86 ukaze v interne vliw? Kdo si sedaj lasti te patente? Se mi zdi, da bi se dalo na tej podlagi skuhati nekaj zanimivih izdelkov ...
Brane22 ::
Ampak tudi vsaka opcija svoj sweet spot.
APU bo nudil unificiran RAM. CPU in GPU del bosta dejanjsko posegala v isti RAM. Bo pa imel manj coreov in verjetno brez L3.
Diskretna verzija bo bogatejša na obeh koncih in vsak konec bo imel svoj RAM, ampak HT/PCIe linki med njima bodo ozko grlo, pa še koherence ne bo.
Kdaj že pride Excavator ? :D
boolsheat ::
Lastnik Transmetinih patentov je nek patent troll (Intellectual Ventures).
filip007 ::
Virtualizacija spomina za skupno delovanje CPU in GPU. Nekakšen P2P med CPU in GPU, kapo dol za AMD.
Isotropic ::
zanimivo, kako amdju zadnje case rastejo delnice. sem mislil, da je bila samo fake novica, da hoce intel kupiti amd (tocno takrat je bilo prodano 100k delnic, kar ni nakljucje), zdaj pa kar noce pasti.
(delnic zal nimam :| )
Šibajo v pravo smer.
Samo že Richland zdaj zdaj izdajo pa bo čez 4 dolarje. :)
  • spremenil: D3m ()
Isotropic ::
hud clanek
http://www.anandtech.com/show/6934/choo...
ceprav namesto unega bi jaz izbral i3 za single card system.
Samo bo še part.2 članek, model bo testiral še FX-4xxx in FX-6xxx in ostale, ki manjkajo. Mi je pa všeč tole:
A CPU for Single GPU Gaming: A8-5600K + Core Parking updates
If I were gaming today on a single GPU, the A8-5600K (or non-K equivalent) would strike me as a price competitive choice for frame rates, as long as you are not a big Civilization V player and don't mind the single threaded performance. The A8-5600K scores within a percentage point or two across the board in single GPU frame rates with both a HD7970 and a GTX580, as well as feels the same in the OS as an equivalent Intel CPU. The A8-5600K will also overclock a little, giving a boost, and comes in at a stout $110, meaning that some of those $$$ can go towards a beefier GPU or an SSD. The only downside is if you are planning some heavy OS work - if the software is Piledriver-aware all might be well, although most processing is not, and perhaps an i3-3225 or FX-8350 might be worth a look.
A CPU for Dual GPU Gaming: i5-2500K or FX-8350
Looking back through the results, moving to a dual GPU setup obviously has some issues. Various AMD platforms are not certified for dual NVIDIA cards for example, meaning while they may excel for AMD, you cannot recommend them for Team Green. There is also the dilemma that while in certain games you can be fairly GPU limited (Metro 2033, Sleeping Dogs), there are others were having the CPU horsepower can double the frame rate (Civilization V).
After the overview, my recommendation for dual GPU gaming comes in at the feet of the i5-2500K. This recommendation may seem odd - these chips are not the latest from Intel, but chances are that pre-owned they will be hitting a nice price point, especially if/when people move over to Haswell. If you were buying new, the obvious answer would be looking at an i5-3570K on Ivy Bridge rather than the 2500K, so consider this suggestion a minimum CPU recommendation.
On the AMD side, the FX-8350 puts up a good show across most of the benchmarks, but falls spectacularly in Civilization V. If this is not the game you are aiming for and want to invest AMD, then the FX-8350 is a good choice for dual GPU gaming.
A CPU for Tri-GPU Gaming: i7-3770K with an x8/x4/x4 (AMD) or PLX (NVIDIA) motherboard
By moving up in GPU power we also have to boost the CPU power in order to see the best scaling at 1440p. It might be a sad thing to hear but the only CPU in our testing that provides the top frame rates at this level is the top line Ivy Bridge model. For a comparison point, the Sandy Bridge-E 6-core results were often very similar, but the price jump to such as setup is prohibitive to all but the most sturdy of wallets.
As noted in the introduction, using 3-way on NVIDIA with Ivy Bridge will require a PLX motherboard in order to get enough lanes to satisfy the SLI requirement of x8 minimum per CPU. This also raises the bar in terms of price, as PLX motherboards start around the $280 mark. For a 3-way AMD setup, an x8/x4/x4 enabled motherboard performs similarly to a PLX enabled one, and ahead of the slightly crippled x8/x8 + x4 variations. However investing in a PLX board would help moving to a 4-way setup should that be your intended goal. In either scenario, at stock clocks, the i7-3770K is the processor of choice from our testing suite.
A CPU for Quad-GPU Gaming: i7-3770K with a PLX motherboard
A four-way GPU configuration is for those insane few users that have both the money and the physical requirement for pixel power. We are all aware of the law of diminishing returns, and more often than not adding that fourth GPU is taking the biscuit for most resolutions. Despite this, even at 1440p, we see awesome scaling in games like Sleeping Dogs (+73% of a single card moving from three to four cards) and more recently I have seen that four-way GTX680s help give BF3 in Ultra settings a healthy 35 FPS minimum on a 4K monitor. So while four-way setups are insane, there is clearly a usage scenario where it matters to have card number four.
Our testing was pretty clear as to what CPUs are needed at 1440p with fairly powerful GPUs. While the i7-2600K was nearly there in all our benchmarks, only two sets of CPUs made sure of the highest frame rates - the i7-3770K and any six-core Sandy Bridge-E. As mentioned in the three-way conclusion, the price barrier to SB-E is a big step for most users (even if they are splashing out $1500+ on four big cards), giving the nod to an Ivy Bridge configuration. Of course that i7-3770K CPU will have to be paired with a PLX enabled motherboard as well.
One could argue that with overclocking the i7-2600K could come into play, and I don't doubt that is the case. People building three and four way GPU monsters are more than likely to run extra cooling and overclock. Unfortunately that adds plenty of variables and extra testing which will have to be made at a later date. For now our recommendation at stock, for 4-way at 1440p, is an i7-3770K CPU.
Ma bolj hud je bil članek na arstechnici v dveh delih o zgodovini AMDja, vzpon in padec ... kjer vidiš, da bi moral amd najprej skrtačit marketing ekipo, ki se že ves čas obnaša kot "we're #2!".
Anyway, kolikor so poznam AMDjeve trenutne projekte, je rast cene njihovih delnic popolnoma razumljiva. Optimistično pričakujem, da se amd v nekaj letih pobere in da intlu še eno zaušnico.
Ubistvu je res. Marketing jih jebe. Od njih ni nič reklam, še na slovenskih medijih imaš na vsake kvartale eno reklamo za Intel.
marketing stane..
bolje da dajo $$$ v razvoj..
Posledica, da ima AMD foo marketing, je vidna recimo v oni temi, kjer nekdo sprašuje za amd konfiguracijo, pa mu folk takoj začne "vzami raje intel" iz razlogov, ki so primarno marketinške narave.
Videti je, da je novo vodstvo AMDja to prepoznalo in kot novo smer najavilo izdelavo semicustom rešitev za specifične stranke. V takih zgodbah se marketing dela popolnoma drugače in se ti dejansko ni treba za mindset mularije borit.
Za to je kriv ustanovitelj Jerry Sanders in zaradi njega bo AMD bo vedno #2. Pa cetudi so/bodo boljsi od konkurence, bodo vedno #2.
Dejansko jim je ves tadober kader ze pobegnil.
Napačno razmišlanje.
Brane22 ::
Sanders je kriva samo v toliko, ker je najel Hectorja Ruiza.
Slednji je hodeča katastrofa.
SuperVeloce ::
A res, ravno v tistem arstechnica članku avtor omeni, kako je vplival Sandersov odnos do zapravljanja denarja in obsesije pri (prehitrih) odločitvah, kot je bila tista s fabrikami. In to je samo ena zadeva, ena odločitev, ki jo je naredil kot šefe v mnogo letih...
Brane22 ::
Oziroma tako pravi Hector.
S to majhno razliko, da je Sanders pripeljal AMD od ničle do vrha, Ruiz pa samo navzdol.
Problem AMDja po začetnem uspehu so bili nori plani. Hoteli so premagati Intla na vseh poljih naenkrat.
Tudi tisti nakup ATIja je bila čista blesarija, ki jo zdaj PR oddelki šminkajo na take in drugačne načine.
Brane22 ::
ATI se je takrat prodal za neverjetne denarje, ni pa jasno kaj je AMD s tem dobil.
ATI ni imel svoje proizvodnje. Čiperaj je naročal pri Foundryjih, tako kot ga koneckoncev lahko ti ali pa jaz.
Večina "vrednosti" je bila v know-hhowu, patentih in SW, z ničemer od tega si pa AMD ni imel kaj pomagati.
Njihov plan je bil integracija v APU, tam je bil pa ATI bos, ravno tako kot kdorkoli drug.
To, kar danes oglašujejo kot APU bi komot lahko imeli v času prvih Phenomov recimo.
Po eni varianti bi se recimo lahko zmenili s kakim ATIjem, da jim zdilajo nov model čipa s HT namesto PCIe vmesnikom in tega bi pač lahko vdelali na novo podnožje, ravno kot to počnejo danes z Opteroni. S CPUjem bi bil povezan prek HT linka in to je to. Par DDR-3 čipov na plato ali še bolje v podnožje in piči miško.
Po drugi varianti bi pa to lahko naredili sami. Karkoli bi tako ustvarili, bi bilo lahko komot bolje kot običajna integrirana rešitev.
Brane22 ::
Brane22 je izjavil:
Se popravljam deloma. Ja, v času Phenoma, s tem da bi Phenom lahko prišel ven LETA prej.
Ja sam a ni bolje, da je stvar on-die, kot pa nekje zalotana na platki ?
sj amd je meu te "apuje" že pred atijem zalotane v čipset...
119 / 128
