Forum » Strojna oprema » AMD Bulldozer
AMD Bulldozer
jest10 ::
x45, v katerem vzporednem vesolju ti živiš?
v tistem ki ima teste tanove, ti pa si v letu 1525...![]()
Misliš tiste teste, v katerih je BD v celih 10% testov pred Inteli?
Kjer je 2500 v večini testov pred BD? Kjer je od BD v vsaj 50% hitrejši tudi X6? In ti kekec ti upaš trditi, da je ta zajeb od BD super nakup
eieieie1 ::
V idle je super
. Ko mu pa kaj daš za futrat pa žre, ampak ni tako hudo, da nebi preživel.
filip007 ::
Intel bo spustil ceno za 2500k in tako drektno tekmuje s FX, pri AMDju je malo problem poraba, sploh pri navijanju kekci nastavljajo na 4.6GHz samo 400MHz več od Turbo frekvence, poraba pa poleti v višave. Intel wins na žalost...
B3 revizija pod nujno AMD...
Zero games, zero talk.
Bulldozer je EPIC FAIL upam, da si bo x45 že enkrat to priznal.
Neki zate.
http://thebestpageintheuniverse.net/c.c...
Tale mi je najbolj usec.
So when you miserable pieces of shit say "epic fail," what you really mean is "epic failure."
Pa lep dan.
x45 ::
Sami dojenčki ste tukaj res.
tole o porodnih težavah DB in asus bordu zadeve se bodo kmalu stabilizirale in ja BD je dober nakup.
http://us.battle.net/wow/en/forum/topic...
Isotropic ::
ce bo intel res spustil cene za 2500, ne bo vec dober nakup. BD2 bo pa novo poglavje verjetno, kot phenom2.
Rippy ::
Mogoče napačno vidim...ampak a si pravkar prilepil povezavo na World of Warcraft forum, da potrdiš svojo tezo?
x45 ::
Asusov Bios na Croshair 5 aM3+ plošči je iz septembra 2011
bistvo ki ga povdarjam:
Initial reviews left many shocked and disgusted at how poor Bulldozer performed, but as time went by, more bits of news were released that we might not be seeing the true potential of this CPU.
The review kit that AMD gave to reviewers contained an FX-8150 CPU paired up with an ASUS motherboard, and few reviewing sites that did not use the ASUS motherboard noted that FX-8150 actually performs equal or better than i5-2500k, and definitely match or better than i7-2600k in gaming.
Some are now guessing that ASUS motherboard must have some sort of an issue that prevents FX-8150 from working correctly. It appears BIOS update is necessary for few of those AM3+ motherboards.
Bulldozer's L1 shared cache will often work double to fetch the data from it, if programs / OS does not properly interact with it -- which slows down the CPU. Apparently, this is causing ~10% performance loss for Bulldozer CPUs. Microsoft is supposed to have made a patch for this recently.
Therefore, it looks like the dust needs to settle a bit to see true, final performance capacity of Bulldozer before writing it off of as a revival of Agena.
Thanks for the post, Kalganized! Hopefully these issues will be fixed soon so everyone can see the true potential of this CPU.
Jaz bi si želel, da bi že BD1 bil to, kar bo BD2 ... ampak situacija je, kakršna je
tiborrr ::
Got FX-8130P and FX-4100. Yaay, benching time. Love AMD :D
Drugače pa imam tako CHV kot Giga 990FXA-UD7. Performančnih razlik na dozerju praktično ni oz. so zanemarljive. To je bulšit. Čeprav Crosshair V je res grozno inneficient plata: http://oc-lab.si/forum/viewtopic.php?f=...
- spremenil: tiborrr ()
dexterboy ::
Žal sporočam, da bo potrebno še malo POČAKATI na fiču bagera, da se razvije in evoluira v Caterpilar rovokopača; pojavlja se BSOD in počakati moramo na B3 steping proca, več v spodnjih novicah:
http://scalibq.wordpress.com/2011/10/19...
http://www.nordichardware.com/news/69-c...
http://www.xbitlabs.com/news/cpu/displa...
Če ima kdo kristalno kuglo in zna priporočati, ali naj si nabavim plato z AM3+ socketom in počakam na proc naslednje leto ali pa naj raje počakam? Plato sicer že imam na DDR3 ramu, le ni am3+ podnožje...
PrimozR ::
V bistvu je cena od izida BD-ja 2500k zgolj zrasla... 2700k bo pa očitno zamenjal samo 2600k, ne pa zbil celo družino stopničko nižje, torej nekih pocenitev ni za pričakovati.
- spremenil: PrimozR ()
filip007 ::
@DexterBoy
Če dovoli odklepanje jeder, potem porabi kar imaš, pri AMD nimaš kaj zbubit, ker si že na zgubi.
http://www.bolha.com/amd-phenom/proceso...
jest10 ::
Uf, slaba novička
x45 ::
am3+ plate so ugodne. če tvoja dela z bios upgradom za am3+ cpu najprej naredi to drgač pa v nakup.
Brane2 ::
IMHO zguba cajta. Današnji CPuji delajo še čisto v redu.
Brezveze menjat plato za tole, sploh ker ziher pride nov socket ven.
Poleg tega bo AMD moral pokazat neko bistveno spremembo in tanovi Piledriver bo samo zato, da popravi vtis v vmesnem času.
x45 ::
Brane2 daj malo razloži kako intel goljufa z kodo ko sem razbral iz linka onga par dni nazaj ne da se mi brat?
Inteli delujejo na SSE 2 amd ju pa vsili prastaro kodo od 386 če sme prav razumel? kako je to izvedeno in kako vse zakamuflira da skor noben ne ve?
Da je Intel goljufal je tabu tema, ker je AMD dobil poravnavo več, kot milijarda dolarjev če se ne motim.
Machiavelli ::
Procesor je šrot dej se sprijazni že matr.....
pač firma varčuje....
kako varčevati ?
Simpl:
Oskubi jedra in zlimaj v module,
Razdeli L2 na 2 jedra,
32nm process
Odpusti delavce
Prodajaj po podobni ceni kot prejšni x6 top model za enak performanc.
Res pa je da je full tranzistorjev nabitih in si nakoncu skor v istem znesku kot x6 phenom II lol
kako varčevati ?
Simpl:
32nm process
Odpusti delavce
Nigaaazz
Kako, šrot? A je na pol poti pri procesiranju izdihnil, se je zakadil bel dim iz računalnika ali kaj?
x45 ::
tole je lahko kaj drugega ne sam to intel masovno goljufa že blo velik novic... kako pa s slabšo arhitektiro zmanipulira score pa je drugo... no to se res ne nanaša na BD ampak brane je vedel nekaj o tem...
Michiavellija in podobne pa obidi - intel fun.
Ahhh to ni nič takega. Je bil en test nekaj let nazaj, ko so samo CPUID VIA Nanota spremenili v Intel in je prikazal boljše rezultate v benchmarkih, kot sicer.
Machiavelli ::
X45 trenutno si lastim AMD sistem čisto po pravici povedano dual core,ker sem zadevo dobil za smešen znesek,vsekakor pa je 1155 plošča na poti...
Dejstvo je da je fx slab neglede na to koliko boš branil,hvalil in nwm kaj še FX8 213eur in 2500k nažalost zdaj 200eur je 2500k boljša izbira....
Tud če maš 8 bogih jedričk in to razbremeniš je isti drek kokr če maš 4 močna jedra z tem da intel ima prednost za prihodnje upgrejd in to..+ manj porabi štroma.
To so dejstva in ne iluzije...
Nigaaazz
Jst ::
Brane: Še nekaj sem se spomnil glede tako velikega cache. Na štiriprocesorski plati ti to pride zelo prav, samo čudno mi je, da je poraba tako visoka. Kako mislijo hladiti štiri BDje na eni plati plus to, da bo firma, za katero sem delal, zamenjala trenutno opremo (po pogodbi) - Render Farmo, ki se uporablja primarno za cgi v reklamah. Jaz sem sicer svoj del izpolnil, ampak sem se spoprijateljil z nekaj ljudmi in jih bom vprašal, ko bo menjava...
Brane2 ::
Ne štekam zakaj. Intlovi QPI kanali omogočajo 4 sockete neposredno povezane.
Če ima vsak svoej banke RAM-a, bo dostop vedno hiter- bodisi v svojo banko bodisi čez 1 "hop".
Recimo, da imaš latenco RAM-a kajpavem, 300 ciklov. Recimo, da si sposoben v vsakem ciklu vpisato 128 bitov= 16 byteov. Če začenš z vpisom in če se cache enota odloči praktično takoj, da bo L2 prosledila v RAM, boš vpisal 300x16=bednih 4,8kB v tem času.
Kar se tega tiče, je že 256KB L2 čezinčez dost, L3 sploh rabiš ne. L3 je prišel prav v času Phenoma, da zmanjšaš navidezno latenco do RAM-a, ampak če imaš veliko jeder, who cares- bo pač eno jedro čakalo na dostop. Veliko bolj ekonomično kot da celo to površino pa še kaj zasedeš z L3 in _upaš_, da bo stvar imela iskani podatek in ga v L2 ne bo.
Glede porabe, po moje se bo stvar bolje obnesla na nižjih frekvencah, kjer bodo nastavili delovne točke tako, da bo leaka veliko manj...
- spremenil: Brane2 ()
Jst ::
Saj po eni strani razumem, kaj misliš, ampak z toliko L3 so enote lahko bolj samostojne. Drugače pa sam buh (AMD) ve, zakaj so se šli takšno igro.
Jaz sem mnenja, da je stvar podobna sledečemu: ATI je sledil nvidijini strategiji "pumpanja" čimvečjih kartic, dokler ni en pameten inženir rekel, "zakaj pa ne bi raje delali čimmanjše enote?" In smo dobili serijo 4000, ki je bila velik uspeh; na anandtech-u sta dva zelo dobra članka o tem, "Road to success" in še eden. Z 4000 so grafične začeli delati, kot da bi sestavljal lego kocke. Zato se mi zdi, kot da je s temi moduli AMD hotel enako in mu iz prve ni ratalo.
Machiavelli je izjavil:
kako varčevati ?
Simpl:
32nm process
Odpusti delavce
Zaradi zadnjega stavka tvoja trditev ne drži vode.
Kaj je to Intel fun???? Ne spakuj se angleško, če ti intelekt ne seže do take "višine" ;)
In predvsem; zakaj bi bili AMD ritolizniki (beri: ti) kaj boljši?
Jst:
http://www.anandtech.com/show/2679
in
http://www.anandtech.com/show/2937
Legendarna članka!
Zato se mi zdi noro, da nekoga, ki lahko pride do takih informacij, kot je tole, označiš za pristranskega ... pa ne leti nate ;)
- spremenilo: FireSnake ()
Jst ::
FireSnake: What?? Anadna sem označil za pristranskega? KJE??? Še napisal sem ravno o teh dveh člankih, kako je ATI divizija AMDja začela z novo logiko delanja GPUjev.
RibicRupert ::
i5 2500K je kot Štirje Kovači, BD pa kot top 8 financiranih v SAZAS-u.
Potem pa se diskutira kdo bolje izvaja in kdo več porabi zase.
Na koncu piše, da ne leti nate ;)
Slavni x45 meni tako ..... da bo bolj eksplicitno :)
RibicRupert je izjavil:
Kera butasta primerjava. No offense.
Dejstvo je, da je treba počakati na naslednje leto. Saj tudi prvi Phenomi tudi niso bili ne vem kaj. Vsekakor pa niso bili tako "slabi", kot je aktualni buldožer. Poraba elektrike je katastrofa.
filip007 ::
Upam, da bodo ljudje spravili ven kaj se dogaja, 10% tam 20%+ tukaj, potem pa bo, samo še odklep jeder rabimo FX-4100 95W na FX-8100 95W in totalna zmaga.
Bulldozer (microarchitecture) @ Wikipedia
Brane2 ::
Stari, ni več "zmage". Ne na x86.
Ja, lahko upenalijo Piledriver in to je "zmaga" od pardeset procentov.
Če hočejo sedaj naprej, morajo v ekonomičnost. To pa ne bo šlo brez radikalnih sprememb.
Sicer bo folk imel isti proc, grafikuljo, ram in plato po 10 let.
PrimozR ::
Saj to veš da če skorajda praktično podvojiš število (pa tudi če št. povečaš samo za 25% na račun I/O modulov) delujočih tranzistorjev v čipu, da TDP ne more ostati enak? Razen če bi na FX4000 imeli tako zrelaksiran TDP. Which they don't. Nobody does that.
Machiavelli ::
pri odklepu jeder TDP posledično zraste...lahko pa se potem igraš z voltažo pa ga mal undervoltaš...
Nigaaazz
filip007 ::
AMD does that...FX-8100 je 95W
A po tvojem je potem napaka na Wikipediji...PIPI
Dejstvo je, da AMD špara pri izdelavi in ga pač ceneje pride, če naredi vse enako.
Why so serious?
Why so serious?
- spremenil: filip007 ()
PrimozR ::
x45 resno, kaj je to intel fun? :)
zakaj me sparšuješ o sebi ? .
O sebi? Potem mi pa razloži kaj jaz sem. Zanimivo je, da toliko ljudi o drugih ve tako veliko oz. še več, kot ti drugi sami o sebi! :D
Why so serious?
Nisem vedel da ima FX-8100 3,6 GHz delovno frekvenco... Oh, wait!
filip007 ::
No glavnem FX-4100 je 95W...stane 120 ceglov samo na fitnes mora.
filip007 ::
Kaj ne bo noben letel v trgovino in ga nabavil?
http://www.ceneje.si//search_new.aspx?q...
